Первый опыт макропрограмм FANUC 0i-MD
catiauser
Собственно возникла необходимость написания небольших макропрограмм, что бы операторы отстали)
начал с простого примера:
:6660
G0 G17 G40 G90
G0 G54
#1=1 (TOOL NO.)
#2=800 (DIAMETR OKR.)
#3=50 (TOOL DIAM)
#8=#3*0.75 (SHAG V RADIAL'NOM NAPRAVLENII)
#15=1000 (OBOROTI)
#16=300 (PODACHA)
T#1 M6
G43 H#1 Z60.
S#15 M03
F#16
M08
G0 X0 Y[#2/2+#3/2+5]
Z5
G1 Z0.
#20=#2/2+#3/2-#8
	WHILE[#20GT#8/2] DO1
	Y#20
	G2 X0 Y#20 I0 J-#20
	#20=#20-#8
	END1
G2 X0 Y#8/2 J-#8/2
G0 Z60.
M09
M05
M30
Программа фрезерует круглую заготовку по плоскости. Все как бы работает.
Но с примером посложнее
:7777
G0 G17 G40 G90
G0 G54
(----------PARAMETRI----------)
#1=1 (TOOL NO.)
#3=50 (TOOL DIAM)
#4=-5 (ABSOL. GLUBINA KARMANA)
#5=5 (TOLSCHINA SNIMAEMOGO MATERIALA)
#6=2 (GLUBINA ZA ODIN PROHOD PO Z)
#7=60 (BEZOPASNAYA PLOSKOST')
#8=#3*0.5 (SHAG V RADIAL'NOM NAPRAVLENII)
#9=0 (KOORD X CENTRA)
#10=0 (KOORD Y CENTRA)
#11=FUP[#5/#6] (ILI ROUND[#5/#6] KOL-VO PROHODOV PO Z)
#12=#3*0.8 (DIAMETR SPIRALI VREZANIYA)
#13=2*#12*TAN[1] (SHAG SPIRALI PO Z)
#14=FUP[#6/#13] (ILI ROUND[#6/#13] KOL-VO VITKOV SPIRALI PO Z)
#15=1000 (OBOROTI)
#16=300 (PODACHA)
#101=0.25 (KOEFFICIENT UVELICHENIYA SHAGA V RAD NAPRAVLENII)
#104=90 (UGOL VRASCHENIYA)
(----------PROGRAMMA----------)
IF [#2LE[6*#3]] GOTO6
T#1 M6
G43 H#1 Z#7
S#15 M03
F#16
M08
G68 X#9 Y#10 R#104
#19=#11
(----------Z CYCLE----------)
#102=[#2/4-#101*#8] (Y PERVOGO PROHODA)
WHILE[#19GT0] DO1
	#19=#19-1
	G0 X#9 Y[#10+#102]. Z#7
	G0 Z[#4+#19*#6+#13*#14+1]
	G1 Z[#4+#19*#6+#13*#14]
	#20=#14
	(----------HELIX APROACH CYCLE----------)
	WHILE[#20GT0] DO2
		#20=#20-1
		G3 X#9. Y[#10+#102] J-[#12/2] Z[#4+#19*#6+[#20*#13]]
	END2
	(----------END HELIX APROACH CYCLE----------)
	#21=[#2/4+#101*#8]
	#22=#102
	#105=#101
	(----------SPIRAL CYCLE----------)
	WHILE[#21LE[#2/2-#8]] DO3
		#23=SQRT[#21*#21-#22*#22]
		G1 X[#9+#23]
		#105=#105+0.1
		IF[#105GE1] THEN #105=1
		#24=#21+#105*#8
		#25=#22-#105*#8
		#26=SQRT[#21*#21-#25*#25]
		G3 X[#9-#26] Y[#10+#25] R#21
		#21=#24
		#22=#25
	END3
	(----------END SPIRAL CYCLE----------)
	G1 Y[#10+0.6*#8]
	G1 X[#9+[#2/2-#8]]
	G1 X[#9+[#2/2-0.5*#3]] Y#10
	G3 X[#9-[#2/2-0.5*#3]] Y#10 R[#2/2-0.5*#3]
	G1 Z10.
	G0 Z#7
END1
(----------END Z CYCLE----------)
N6
M09
M05
M30
вылетает ошибка
PS0004
Программа должна фрезеровать половину круглого кармана
Изменено пользователем catiauser
Вот, профессиональный пример как положено писать МАКРО. Это написано спецами ф.Фанук и представляет из себя системный эксекатор С.А.Р.
PD1M_CAP.RAR
15 минут назад, agering сказал:
PD1M_CAP.RAR
69 тыщ строчек кода это конечно круто. Но я не спец ф.Фанук и решить с помощью него свою проблему в ближайшем обозримом будущем не смогу.
Я понимаю, что нарушил синтаксис, но пока еще не понял где.
2 часа назад, catiauser сказал:
G0 X#9 Y[#10+#102].
Точки здесь не нужны.
Не ужели это из за них? Я не все удалил... Но почему тогда ошибка выскочила в кадре с G68?
Отправлено с моего Lenovo K10a40 через Tapatalk
Только что, catiauser сказал:
Может быть, есть еще другая причина.
Кадр с G68 - нормальный, система читает вперед, а на нем просто остановилась.
10 часов назад, AndreyChinc сказал:
А где отмена G68?
 Верно подмечено, ее нет, но мужики со стойки внесли в конец программы G69 - не помогло.
Без точек сегодня не смогли потестить.
Может, его нахлобучило при обращении к #104 параметру? Попробуйте #101, #102, #104 заменить на 28, 29, 30
O0001(MACRO B SAMPLE - CIRCLE POCKET.NC)
(TO SEE THE VARIABLES UPDATE WHILE RUNNING THIS PROGRAM)
(USE THE STEP CONTROLS ON THE VARIABLE DISPLAY WINDOW.)
(THIS WINDOW CAN BE OPENED FROM THE MENU "CALC/SHOW VARIABLES")
N1 G00 G17 G80 G40 G90
N2 M06 T01
N3 G00 G54 X0 Y0
N4 G43 H01 Z2.
N5 M03 S1500
N6 G65 P2 X0 Y0 Z-0.75 R0.25 I6. J0.375 K0.2 E0 F25.
N7 G00 Z5.
N8 M02
O0002(CIRCLE POCKET MACRO)
(#24  X POCKET CENTER)
(#25  Y POCKET CENTER)
(#18  R Z APPROACH DEPTH)
(#26  Z FINISH DEPTH)
(#6   Z STEP AMOUNT)
(#4   I POCKET DIAMETER)
(#7   D TOOL DIAMETER)
(#5   J RADIAL STEPOVER)
(#8   E CUTTING DIRECTION 0=CW, 1=CCW)
(#9   F FEEDRATE)
(#30 STARTING DEPTH)
(#31 RADIAL PASSES)
(#32 DIVIDE RADIUS INTO EVEN NUMBER OF PASSES)
N1 G00 X#24 Y#25
N2 Z#18
N3 #4=[#4/2]-[#7/2]
N4 #6=ABS[#6]
N5 #30=#18
N6 #31=FIX[#4/#5]+1
N7 #32=#4/#31
N8 #34=#32/2
N9 #30=#30-#6
N10 IF [#30LT#26] THEN #30=#26
N11 G01 Z#30 F#9
N12 #33=#32
N13 WHILE [[#33-#4]LT0.0001] DO1
N14 G01 X#24+#33
N15 IF [#8EQ0] THEN G02 X#24+#33 I-#33 J0
N16 IF [#8NE0] THEN G03 X#24+#33 I-#33 J0
N17 #33=#33+#32
N18 END1
N19 IF [#8EQ0] THEN G02 X[#24+#4-#32] I-#34 J0
N20 IF [#8NE0] THEN G03 X[#24+#4-#32] I-#34 J0
N21 G00 Z#18
N22 X#24 Y#25
N23 IF [#30GT#26] GOTO 9
N24 M99
У нас на одном работает переменная #100 а на другом ошибка #151 а на другом ошибка. Может ещё надо понять какие переменные работают!!
Правда мне Вашу прогу с планшета не глянвть.
    • Buka_juve
      Здравствуйте!!!   Может кто-то сможет поделиться постпроцессором для стойки Fanuc 31i TD или Fanuc 0i-TD (XZC). Вообще интересует обработка фрезерованием шнеков с поворотом детали по оси C.   Станки Hyundai Wia L280LM или L150SY.   Спасибо
    • Sabadash
      Поправьте режим легкой сборки в настройках, включается с определенного количества деталей, просто увеличьте количество деталей или отключите этот режим. Быстрое переключение в дереве построения (Set resolved to lightweight)
    • mixey53rus
      Вот пример программы, которой сам пользуюсь O0001 ( T17 | M10 METCHIK | H17 ) N100 G21 N102 G0 G17 G40 G49 G80 G90 N104 T17 M6 ( T17 | M10 METCHIK | H17 ) N106 G0 G90 G54 X-.75 Y0. S100 M3 N108 G43 H17 Z5. N110 G94 N112 M29 N114 G98 G84 Z-10. R.5 F150. N116 G80 N118 G94 N120 M9 N122 G53 Z0 N124 G53 Y0 N126 M30
      Видел я как швейцарцы проектировали кран один, рама нижняя пополам переломилась на заводе где цветняк собирали и в вагоны грузили.  Квадратный лючок устроили в самом напряженном месте ну и переломился естественно из-за концентрации напряжений и усталости. Чайники проектировали, одно слово .  Объяснил заводчанам как чинить, все посчитал.  Кинули на три штуки бакинских , не заплатили. Думал сначала бандюкам долг продать, потом пожалел убогих. Все-таки сам когда-то работал на этом заводе, поэтому и доверял. А зря. Предают обычно свои :)  Швейцарцы с них за новую раму запросили двести штук бакинских.  Этот кран для фермеров делался, а они редко грузят вот гарантийный режим и выдерживался. Да и нагрузка не металл, а сельскохозяйственная.  А на заводе   в две смены цветняк грузили в вагоны на экспорт прибалты.  Грабили Россию   :)
      Не понял? Если гиб 1, то зачем повторения?   Повторения имеют смыслы, когда гибов больше 2-х   Например, есть программа 1 Гиб Х=20 2 Гиб Х=20 3 Гиб Х=50   Эту программу можно по другому записать 1 Гиб Х=20 (2 повтора) 2 Гиб Х=50
    • Artas28
      А почему направление стружки вверх??? Я влево - вправо выбирал . Спасибо)
    • MagicNight
      Да. Напротив, оператор станка не расслабляется!
    • andrei4ik
      Всем доброго дня. Заметил что солид каждый раз при запуске при рткрытии сборки сам ее открывает по умолчанию в сокращеном виде... в настройках галочка снята. И приходится каждый раз руками при открытии сборки уирать переключатель с сокращеного режима... Солид 2022
    • Ninja
      я сделал так как ты и сказал - ось вдоль UV. Ткнул направление стружки вверх и всё!
    • Artas28
      Молодец, а как сделал рассказать не хочешь?) или пример обратно скинуть?
