Измерения деталей на станке с пом. Renishaw.
father
O00099 (MEASURE)
(01-A 7-D 18-R 24-X 25-Y 26-Z)
G103 P1
#101= #0
#102= #0
#11= #5321 (G59-X)
#12= #5322 (G59-Y)
IF [ [ #24 NE #0 ] AND [ ABS[ #24 ] LT 0.1 ] ] THEN #24= 10000 * #24
IF [ [ #25 NE #0 ] AND [ ABS[ #25 ] LT 0.1 ] ] THEN #25= 10000 * #25
IF [ [ #26 NE #0 ] AND [ ABS[ #26 ] LT 0.1 ] ] THEN #26= -10000 * ABS[ #26 ]
IF [ [ #1 NE #0 ] AND [ ABS[ #1 ] LT 0.1 ] ] THEN #1= 10000 * #1
IF [ [ #18 NE #0 ] AND [ ABS[ #18 ] LT 0.1 ] ] THEN #18= 10000 * #18
IF [ [ ABS[ #24 ] EQ 1 ] OR [ ABS[ #25 ] EQ 1 ] OR [ #26 EQ [ -1 ] ] ] GOTO2 (SURF X/Y/Z)
IF [ #24 OR #25 ] GOTO1 (POCKET/WEB X/Y)
IF [ #1 NE #0 ] GOTO3 (ANG)
IF [ #7 EQ #0 ] GOTO6
(BORE/BOSS)
#1= 1
IF [ #26 ] THEN #1= 2
G00 G90
G65 P9023 A#1 D#7 Z#26 S59.
G103 P1
#5321= #11 (G59-X)
#5322= #12 (G59-Y)
G00 G90 G80 G40
T25 M06
G43 H25
G65 P9832 (OMP ON)
G103 P1
IF [ #26 ] THEN #26= #26 + #5043 - #5083
G65 P9812 X#7 Z#26
#101= #188 (DIAMETER X)
G65 P9812 Y#7 Z#26
#102= #188 (DIAMETER Y)
GOTO5
(POCKET/WEB)
N1 IF [ [ #24 NE #0 ] AND [ #25 NE #0 ] ] GOTO6
IF [ [ #24 LT 0 ] OR [ #25 LT 0 ] ] GOTO6
#1= 3
IF [ #26 ] THEN #1= 4
G65 P9023 A#1 X#24 Y#25 Z#26 S59.
G103 P1
#5321= #11 (G59-X)
#5322= #12 (G59-Y)
IF [ #24 ] THEN #101= #188 (Size X)
IF [ #25 ] THEN #102= #188 (Size Y)
GOTO5
(SURFACE)
G103 P1
N2 IF [ [ [ #24 NE #0 ] OR [ #25 NE #0 ] ] AND [ #26 NE #0 ] ] GOTO6
G00 G90 G80 G40
T25 M06
G43 H25
IF [ #24 ] THEN #24= 10 * #24 + #5041
IF [ #25 ] THEN #25= 10 * #25 + #5042
IF [ #26 ] THEN #26= 10 * #26 + #5043 - #5083
G65 P9832 (OMP ON)
G65 P9811 X#24 Y#25 Z#26
G103 P1
IF [ #24 ] THEN #101= #185 (SURF X)
IF [ #25 ] THEN #102= #186 (SURF Y)
IF [ #26 ] THEN #101= #187 (SURF Z)
GOTO5
(ANG XY SURFACE)
N3 IF [ #7 ] GOTO4
IF [ #18 EQ #0 ] THEN #18= 10.
G00 G90 G80 G40
T25 M06
G43 H25
G65 P9832 (OMP ON)
G65 P9821 A#1 D#18
G103 P1
#101= #188 (DISTANCE)
GOTO5
(ANG POCKET/WEB)
N4 #7= ABS[ #7 ]
#1= #1 + 90
G00 G90 G80 G40
T25 M06
G43 H25
IF [ #26 ] THEN #26= #5043 - #5083 + #26
G65 P9832 (OMP ON)
G65 P9822 A#1 D#7 Z#26
G103 P1
#101= #188 (Size)
N5 G65 P9833 (OMP OFF)
G00 G90
N6 G103
M99
O00088
(ANGLE & OTVIR MEASURE)
(1-A 24-X 25-Y 26-Z 7-D)
G103 P1
N1 IF [ [ #26 EQ #0 ] OR [ [ #7 EQ #0 ] AND [ #1 EQ #0 ] ] ] GOTO1
IF [ ABS[ #26 ] LT 0.1 ] THEN #26= 10000 * #26
T25 M06
G54 G90 G00 X#24 Y#25
G90 G00 G43 Z100. H25
G65 P9832 (OMP ON)
G65 P9810 Z#26 F2222.
G65 P99 A#1 D#7 R#18
G00 G90 G53 Z0
G103
M99
Пример: измерить расстояние от точки х23.y46.z-8. до поверхности под углом 53°
G65P88X23Y46Z-8A53
Померять диаметр отверстия:
G65P88X102.2Y25Z-10D25
    • Artas28
      Добрый день. Кто нибудь в синтеках, калибровал RTCP? В мануале C_CNC Parameter Manual для этого есть параметры, начиная от pr3001, но в станке такие параметры не отображаются. (или они скрыты) Сдвинули стол в более удобное положение(4-5ось), а RTCP правильно отрабатывает только в первоначальном состоянии, нужно забить новые координаты в параметры для нового расположения стола. Как к ним добраться.
    • Baradozzz
      Уже разобрался. Стойка сама расставляет знак ";"
      Нужно построить диаграмму Кэмпбелла для вала центробежного многоступенчатого насоса, а так как я новичок в этой тематике, то нужно оживить данный топик :-) Критические частоты собираюсь считать в МКЭ. При этом моё ПО не позволяет посчитать изменённые частоты с учётом гироскопических моментов, прецессии и прочих няшностей автоматизировано как в Femap/Ansys. Времени на изучение этих программ нет, так что думаю выкрутиться следующим образом: 1) Моё ПО позволяет извлечь деформированную форму из статического анализа, так что на первом этапе считаю линейную статику, где к валу приложена сила тяжести, извлекаю деформированную модель; 2) на искривлённой модели вала считаю преднапряжённый модальник, т.е. делаю несколько расчётов СЧ с разными частотами вращения вала. 3) соединяю точки, строю диаграмму Кэмпбелла.   Вроде бы всё понятно, решил отработать на "игрушечной" модельке.. Вот такой простенький вал с одной ступенью в центре. Жёсткое защемление по всем ст. своб. на торцах.   Прогиб в статике. Извлекаю деформированную форму Преднапряженный вращением модальник искривлённой модели вала. 1-я частота ~12 Гц   Модальник без нагрузки искривлённой модели вала, Модальник без нагрузки исходной (прямой) модели вала, а также преднапряженный модальник исходной модели вала дали примерно одинаковую первую собственную частоту ~10.5 Гц. Т.е. вроде как метода работает, частота сдвинулась: если говорить языком МКЭ, то искривлённая модель внесла необходимые корректировки в матрицу масс, а преднапряжение - в матрицу жёсткости (что-то похожее давно обсуждали в топике с Графской пружиной). Но вот с этими вилками уже непонятка получается.. не удаётся получить эти самые вилки. Пробовал нагружать вращением по часовой и против часовой стрелки: по моей логике в одном случае частоты должны быть расти относительно расчёта с прямым валом, в другом - падать. Но частоты получаются ровно те же самые...    Про моменты сил вообще не понятно.. В моём скудном понимании при вращении тела с неуравновешенной массой возникают дополнительные силы инерции, которые в случае вала приводят к его колебаниям (нутация). А гироскопический момент по идее должен всегда препятствовать потере устойчивости (сильной раскачке) вала, т.е. должен стремиться возвращать в исходное положение. Буду рад если погрузите меня в физику процесса :-)   Народ, что думаете насчёт методики в целом? Имеет ли право на жизнь? Или она априори неверна?
      посмотрите режим управления какой включен в параметрах . опишите какие сигналы идут на привод? код инструмента в него и из него на входы выходы поступает или только сигналы управления вращением? если коды инструмента не поступают тогда скорее всего plc у вашего привода  нет  как похоже нет и 8 уровневой защиты у вас просто установлен mtb пароль и он не mpara
      https://darxton.ru/catalog_item/servodvigatel-leadshine-cs-m23445b-s-tormozom/ наверняка есть и 8,5Н и 12 Н чем больше дури тем меньше оборотов, для на 12 Н всего 300 оборотов, + чем больше типоразмер тем больше вероятность поймать резонанс на низких оборотах. Я бы смотрел в сторону сервы 750Вт с редуктором 5к1 а что им тягать? Наверняка ведь ещё и винт будет и там сумарно получится грузоподъёмность около 1500кг
    • Димон 87
    • Krusnik
      Даже чертежи не нужны .   Нажимаете Пуск>Инструменты SolidWorks 2023>SolidWorks Rx 2023 Лезете на вкладку "Производительность" и нажимаете на кнопку "Запуск проверки производительности".   В конце будет окошко с результатами и ссылка на сайт, где все выкладывают свои результаты. Можете там сравнить с топами.
    • Мрачный
      А что с графиком частота вращения-момент? Знаю, что там почти линейное падение. Но видел всего пару графиков в тырнетах.
    • felena
      Правомерно ли требование НК в ТТ на сборочном чертеже упаковки (по варианту А) расписывать какие именно эксплуатационные документы нужно вкладывать?
    • Limon2986
      Прошу прощения, как это сделать?
