Токарка в Москве. Срочно.
Необходимо изготовить два комплекта согласно чертежам.
Палка.PDF
Изменено пользователем turumputum
just a friendly suggestion :
you design is not   appropriate ,see attachment , change material to be stainless steel 304, separate into two parts and Welding
but there is a need of mass production quantity . because the outer diameter is Φ5 and Inner Diameter is Φ3 mm ,not Standard pipe .
    • Andrey_kzn
    • niagara39
    • nicomed
    • sneg0vik
    • Soprin
    • niagara39
