Продам зап.части к ПЛК, привода
boomeeeer
SIEMENS
6ES7647-6CE30-0AA0 - ПРОМЫШЛЕННЫЙ КОМПЬЮТЕР IPC627C
SIMATIC S5
6ES5945-7UA13 – S5 CPU945 Processor Module
6ES5945-7UA23 - S5 CPU945 Processor Module
6ES5430-7LA12 – S5 Digital Input Module - 32DI, 24VDC
6ES5306-7LA11 – S5 IM306 Interface Module
6ES5254-4UB21 – S5 IP254 Moby M Interface Module
6ES5922-1AA21 – S5 CPU922 Processor Module
6AW5463-0AB – S5 Moby-M Module
6ES5544-3UA11 – S5 Communications Processor - CP544
6ES5314-3UA11 – S5 IM314 Interface Module
6ES5304-3UB11 – S5 IM304 Interface Module
6ES5524-3UA15 – S5 Communications Processor - CP524
6ES5700-2LA11 – S5 Central Mounting Rack-CR2
6ES5942-7UB11 – S5 CPU942B Processor Module
6ES5375-1LA71 – S5 EPROM MODULE 128K
6ES5375-1LA61 - S5 EPROM MODULE 64K
6GK1500-0DA00 - Simatic S5 RS 485 BUS TERMINAL
6GT2002-0AB00 – S5 Moby I CM422 Sub Module for ASM 400
6GK1500-0AB00 – S5 Bus Terminal RS485
6GK1543-1AA01 – S5 CP5431 Profibus Module
6AV6641-0CA01-0AX1 - OP77B Operator Panel
SIMATIC S7
6ES7972-0CB20-0XA0 - SIMATIC PC Adapter USB (MPI)
6ES7315-2AG10-0AB0 - Simatic S7-300 CPU 315-2DP
6ES7317-2EK14-0AB0 - Simatic S7-300 CPU 317-2 PN/DP
6ES7315-2AF03-0AB0 - Simatic S7-300 CPU 315-2DP
6ES7414-3XJ04-0AB0 - Simatic S7-300 CPU 414-3
6ES7343-1EX11-0XE0 - Simatic S7-300 CP343-1
6GK7343-1EX30-0XE0 - Simatic S7-300 CP343-1
6GK7343-1CX10-0XE0 - CP343-1 Ethernet Module
6GK1551-2AA00 - CP5512 MPI/Profibus PC Card PCMCIA
6GK7443-5FX02-0XE0 – S7-400 CP443-5 Basic Communications Processor
6GK7443-1EX11-0XE0 – S7-400 CP443-1 Industrial Ethernet Module
6GT2002-0FA10 – S7 MOBY Interface Module Moby I/F ASM470
6GT2002-0GA10 – S7 ASM475 Interface Moby I/F Module (PARAM)
6GK7343-1GX21-0XE0 – S7-300 CP 343-1 Advanced Communications Processor
6GK7443-5FA01-0XE0 - S7-300 CP343-5 Comm. Processor
6ES7321-1BL00-0AA0 – S7-300 Digital Input Module SM321
6ES7322-1BL00-0AA0 - S7-300 Digital Output Module SM322
6ES7322-1BF01-0AA0 - S7-300 Digital Output Module SM322
6ES7331-7KF01-0AB0 – S7-300 SM331 Analog Input
6ES7331-7NF00-0AB0 - S7-300 SM331 Analog Input
6ES7390-1AF30-0AA0 - Simatic S7-300 Rail
6ES7392-1AM00-0AA0 – S7-300 Connector, Front Screw, 40 pin
6ES7392-1AJ00-0AA0 – S7-300 Front Connector 20-pin
6ES7972-0AB01-0XA0 - Diagnose-Repeater for Profibus DP
6ES7972-0AA01-0XA0 - Repeater Module RS485
6ES7972-0AA02-0XA0 - Repeater Module RS485
6ES7153-2BA00-0XB0 - ET200M IM153-2 Interface Module
6ES7153-2BA01-0XB0 - ET200M IM153-2 Interface Module
6ES7153-2AA02-0XB0 - ET200M IM153-2
6ES7153-1AA03-0XB0 - ET200M IM153-1
6ES7153-2BA02-0XB0 - IM153-2 DP Slave High Feature Header Module
6ES7151-1AA05-0AB0 - ET200S Interface IM151-1 Standard
6ES7953-8LP11-0AA0 - MMC Memory Module - 8 MB
6ES7953-8LL20-0AA0 - Micro Memory Card - 2MB
6ES7953-8LJ30-0AA0 - Micro Memory Card - 512 KB
6ES7307-1EA00-0AA0 - PS-307 Power Supply Module
6EP1971-2BA00 - Sitop Power Mounting Bracket
6EP1333-3BA00 - SITOP Modular Power Supply
6EP1437-2BA10 - SITOP Power 40 - Power Supply
PG
6ES7791-0KS00-0XA0 - Модуль расширения памяти SIMATIC PG 128 Мбайт SO-DIMM PC-100
ПРЕОБРАЗОВАТЕЛИ
6SE6440-2AB22-2BA1 - MICROMASTER 440
6SE9221-3DC50 - MICROMASTER MM550
6SE6440-2UD23-0BA1 - Micromaster MM440 Drive
6SE9221-0DC50 - MICROMASTER MM550
6SN1113-1AB01-0BA1 – Simodrive Pulsed Resistor Module
6SN1145-1BA02-0CA2 - Simodrive Drive Module
6ES7322-1BF01-0AA0 – SM322 Digital Output Module
6SN1118-0NH01-0AA1 - Simodrive Drive Module
SEW – EURODRIVE (ПРЕОБРАЗОВАТЕЛИ)
SEW MDV60A0075-5A3-4-00
SEW MDX61B0005-5A3-4-00
SEW MDF60A0055-5A3-4-00
SEW MC31CO11-503-4-00
SEW USS21A
SEW MOVITRAC 07A005-5A3-4-00
ALLEN-BRADLEY
160-BA06NPS1 - ALLEN BRADLEY 3 HP AC DRIVE
20AC0300AYNANCO - A-B POWERFLEX 700
2711P-K4M20D - PANELVIEW PLUS 400
2711P-K7C15D1 - PANELVIEW PLUS 400
1776ENBT - module to RSLinx
1746 OB16 - DC OUTPUT MODULE FOR SLC500
1746 IB32 - DC INPUT MODULE FOR SLC500
1746 Р1 – Power Supply for SLC500
1794ADN - MEDIA ADAPTER MODULE 24VDC DEVICENET FLEX I/O
LENZE (ПРЕОБРАЗОВАТЕЛЬ)
E82MV552_4B001- LENZE 8200 MOTEC + (KEYPAD E82B E82ZBB)+(LECOM E82ZBL-C)+(CABLE 2.5 M)
ДАТЧИКИ, КОНЦЕВИКИ
WL9-N122 SICK PHOTOELECTRIC POLARIZED RETROREFLECTIVE REFLEX
ВБ2.55.73.30.1.1.С4 – inductive sensor PNP, NO
XCK-J – limit switch
    • Ninja
      А вежливо попросить СпрутКам выйти за пределы заданной заготовки нельзя? Эх! Как же так, законодатель в отрасли и не может выйти из зоны!? Ха... Тоже мне прроблема ))) Ты вспомни про похеренные проекты, и тебе полегчает! хотя.....
    • Ninja
      @Горыныч  какое тебе ещё резюме надо? У меня за 9 лет, 2500 вот таких вот проектов ! На работе с 1 декабря 2000 года. Помню, что тогда ещё мамонты паслись, а Зерг ещё и не родился даже...       ты посмотри на чистоту линий! Зацени как грациозно парит фреза!!!  ТП, оснастка (придумай/начерти/сделай), инструмент и главное ПРОГРАММЫ - всё ж на мне, одном, держится...
    • Dmi3y
      Был уверен , что необработанная поверхность детали и есть заготовка для операции, там везде припуск
      знаю много малых предприятий где есть директор и кучка пенсионеров работающих на этих самых 6-10 станках тоже пенсионного возраста. предприятия имеют стабильные заказы находясь в кооперативной цепочке и работают длительное время их баланс в плюсе. если надо докупают оборудование главное это заказы и реализация а не число станков   так что количество станков не является определяющем если за ними некому работать и нечего делать то ваше предприятие утонет как титаник
    • Slavdos
      от этого модуль не станет ровнее)) как то ведь делают массово те же морские контейнеры...
      Ещё такое правило : фанук выпуская новую модель подразумевает что вы досконально изучили старые, типа C и D.По книгам давно заметил. Поэтому у них Лэнд крузер а у нас Уазик У них даже в одной проге сервогайд разные символы для выдержки времени G4/
    • Nod801
      Кому то будет полезным. В видео показан один из способов моделирования геометрии чешуи на криволинейной поверхности. https://plvideo.ru/watch?v=GgwD5s2rGHd7
    • a_schelyaev
      Это Компас по импортированным моделям не строит СТЛ сетку нормальную. Если геометрия сделана в общем машиностроительном стиле, т.е. без сложных параметрических поверхностей двойной кривизны, то попробуйте библиотеку распознавания дерева построения. Если всю геометрию распознать т.о., с неважно каким кривым деревом, то такая геометрия уже компасом будет считаться своей и стл сетка построится нормально.
      я думаю подход такой - чем больше пользователь перелопатит руководств тем больше запомнит и будет грамотней так фанук вколачивает знания или стимулирует желание идти на курсы
      я думаю Фанук делится на разные кошельки которые между собой не дружат. И главный Фанук пишет свои параметры и дает другим отделам лишь диапазон параметров который те могут использовать. И те уже сами свои доки выпускают
