Mach 3 Post Processor
Mrich0908
Does any one have a 4 axis post processor for mach3?
do you want postprocessor for Solidcam ?
Yes please , A four axis postprocessor  for solidcam and mach3 please. I have a few fanuc 4x postprocessor  a hass postprocessor . Ive been trying to learn how to edit  mine but its not easy.
send me please a sample program for your machine and the image of your machine kinematics  to mail: ncc_@rambler.ru
    • sneg0vik
    • Soprin
    • niagara39
    • Sivolap36
    • Irukanjii
