Редактирование постпроцессора
AntonH
Здравствуйте!!! Подскажите, что изменить в постпроцессоре, что бы коды G2 и G3 повторялись в последующих кадрах.
Есть:
N3480 G2 X10.509 Y13.219 R35.02
N3490 X3.344 Y25.627 R36.014
N3500 X1.591 Y42.186 R47.296
N3510 G1 X-.108 Y42.191
Нужно:
N3490 G2 X3.344 Y25.627 R36.014
N3500 G2 X1.591 Y42.186 R47.296
Спасибо!!!
3 часа назад, 19_BBB_68 сказал:
Файл pst выложите
18 часов назад, GalielO сказал:
Файл pst выложите
[POST_VERSION] #DO NOT MOVE OR ALTER THIS LINE# V17.00 P0 E1 W17.00 T1391635708 M17.00 I0 O0
# Post Name           : MPFAN.pst
# Product             : Mill
# Machine Name        : Generic
# Control Name        : Fanuc
# Description         : Generic 4 Axis Mill Post
# 4-axis/Axis subs.   : Yes
# 5-axis              : No
# Subprograms         : Yes
# Executable          : MP 17.0
# WARNING: THIS POST IS GENERIC AND IS INTENDED FOR MODIFICATION TO
# THE MACHINE TOOL REQUIREMENTS AND PERSONAL PREFERENCE.
# THIS POST REQUIRES A VALID 3 OR 4 AXIS MACHINE DEFINITION.
# YOU WILL RECEIVE AN ERROR MESSAGE IF MORE THAN ONE ROTARY AXIS IS DETECTED IN
# THE ACTIVE AXIS COMBINATION WITH READ_MD SET TO YES.
# Associated File List$
#region Revision log
# Revision log:
# CNC 06/09/05  -  Initial post setup for Mastercam X
# CNC 10/06/05  -  Changed parameter read for min_speed, modified pspindle, pprep$ and pset_mach
#               -  Modified pset_rot_label to use srot_y for horizontal machines
#               -  Added call to pset_mach in pq$ to set rotaxtyp$
# CNC 11/18/05  -  Added psynclath with call to pset_mach to set rotaxtyp$, removed call from pq$
# CNC 02/03/06  -  Added logic for high-speed toolpath tool inspection (see prapidout & plinout)
# CNC 06/26/06  -  Initial post setup for Mastercam X2
# CNC 12/15/06  -  Modified pset_mach for horizontal rotation when rotating about world Z axis.
# CNC 02/26/07  -  Modified pwcs
# CNC 11/02/07  -  Added prv_shftdrl$ = zero
# CNC 04/08/08  -  X3 release - Removed check for write_ops
# CNC 01/26/09  -  Initial post update for Mastercam X4
# CNC 04/15/09  -  Added read_md switch to enable or disable setting rotary axis from Machine Definition
# CNC 05/06/09  -  Modified pindxcalc to omit ctable check when rotary is not indexer
# CNC 06/09/09  -  Updated MD parameters
# CNC 08/31/09  -  Added check for read_md in pset_mach
# CNC 02/03/10  -  Initial post update for Mastercam X5
# CNC 04/21/10  -  Added Toolpath Transform Enhancements
# CNC 08/17/10  -  Added fix for canned drill cycle incremental mode code output and Z output in incremental mode
#               -  Added fix for X coolant output
#               -  Added fix for MP line break pattern
#               -  Added fix for stock to leave output in tool table
#               -  Removed CD_VAR variables
#               -  Added axis sub direction logic
# CNC 08/23/10  -  Added logic to handle axis sub with signed or shortest direction and rotation >= 360 degrees
# CNC 02/17/11  -  Added three arctype$ initialization variables that are used for
#                  full arc and helix arc output, when CD is set to R or signed R
# CNC 05/20/11  -  Initial post update for Mastercam X6
# CNC 05/23/11  -  Modified pcoutrev to fix potential endless loop when processing axis sub
# CNC 09/01/11  -  Modified pcoutrev to fix potential endless loop when processing axis sub for null tool change operation
# CNC 11/21/11  -  Modified ptap$ and pmisc2$ logic. Post now uses switch (tap_feedtype) to control
#                  Feed per Unit (Inch/MM), or Feed per Revolution
# CNC 12/28/11  -  Minor spacing change
# CNC 02/21/12  -  Added support for CD option 'Subprograms before / after main program'
# CNC 07/24/12  -  X coolant 'With' - separated coolant 'with' logic from cantext 'with' logic to give
#                    more control over output location of X coolant 'With'.  See pcan1 and pcan1_cool
# CNC 10/16/12  -  Initial post update for Mastercam X7
# CNC 04/23/13  -  Revised logic for rotary lock / unlock (See use_rot_lock)
# CNC 02/06/14  -  Initial post update for Mastercam X8
# CNC 05/09/14  -  Added "Convert Rapid To Feed" code
#endregion
#region Features, notes
# Features:
# This post supports Generic Fanuc code for 3 and 4 axis milling.
# It is designed to support the features of Mastercam X Mill.
# NEW FEATURES FOR X:
# - Sub-program support
#     Choose the location of subprogram output using the Control Definition options
#     'Subprograms after main program' or 'Subprograms before main program'
# - Machine definition, control definition and toolpath group parameter read sections added.
# - Post sets rotary "switches" from MD and CD settings.  Also sets min/max spindle speed,
#     max feed rates and type of feed for rotary motion from MD and CD.  Includes option for
#     units/min and units/sec for inverse time feed rate.
# - Variable initialization with SET_BY_MD or SET_BY_CD are overwritten in this post by parameter or
#     variable settings from MD or CD.
# - Support for rotary axis lock/unlock codes when in index mode (see use_rot_lock)
# - Support for signed rotary axis direction and M-code specified axis direction (see use_rotmcode)
# - Switch to force rotary output to index mode when tool plane positioning with a full rotary (see force_index)
# - Enhanced tool information - Added switch for tool comments only, tooltable in header with no tool
#     comments at tool change or tooltable in header with tool comments at tool change (see tool_info)
#     Tooltable output includes cutter compensation type and stock to leave information
# - Enhanced tool staging options - enable or disable in CD.  Set stagetltype in post for output type:
#     Do not stage 1st tool, stage 1st tool at last tool change or stage 1st tool at end of file (peof)
# - Supports X comments including machine name, group name and group comment output (see pcomment2)
# - Additional date, time and data path output options (see pheader)
# - Additional rigid tapping cycle (separate from original tapping cycle) and initial custom drill
#     cycle support (see pmisc2$ and pdrlcst$)
# - Support for 10 additional canned text options for X
# - Decimal support for sequence number output (set "Increment sequence number" in CD to a decimal value
#     for output.  I.E. "Increment sequence number" = .5, "Start sequence number" = 10 : N10, N10.5, N11, N11.5, etc...)
# - Switch for output of M00 or M01 at tool change (3 position switch, off, M00, M01 - see prog_stop)
# - Support for seperate XY, XZ and YZ plane/arc variables (see Arc page in CD)
# - Support for X style coolant.  Allows up to 10 different coolants to be turned on/off before, with, or after like
#     canned text.  Coolant output is handled by "coolant" variable and string selector for V9 style coolant,
#     "coolantx" variable and string selector for X style coolant.
# Misc. Values:
# Integers:
# mi1 - Work coordinate system
#        0 = Reference return is generated and G92 with the
#            X, Y and Z home positions at file head.
#        1 = Reference return is generated and G92 with the
#            X, Y and Z home positions at each tool.
#        2 = WCS of G54, G55.... based on Mastercam settings.
# mi2 - Absolute or Incremental positioning at top level
#        0 = absolute
#        1 = incremental
# mi3 - Select G28 or G30 reference point return.
#        0 = G28, 1 = G30
# mi4 - mi10 (NOT USED)
# Reals:
# mr1 - mr10 (NOT USED)
#Canned text:
#    Entering cantext on a contour point from within Mastercam allows the
#    following functions to enable/disable.
#    Cantext value:
#    1 = Program Stop = output the "M00" stop code
#    2 = Optional Stop =  output the "M01" optional stop code
#    3 = Block Delete on = turn on block delete codes in NC lines
#    4 = Block Delete off = turn off block delete codes in NC lines
#Milling toolpaths (4 axis)
#Layout:
# The term "Reference View" refers to the coordinate system associated
# with the Top view (Alt-F9, the upper gnomon of the three displayed).
# Create the part drawing with the axis of rotation about the axis
# of the "Reference View" according to the setting you entered for
# 'vmc' (vertical or horizontal) and 'rot_on_x' (machine relative
# axis of rotation).
# vmc = 1 (vertical machine) uses the top toolplane as the base machine
# view.
# vmc = 0 (horizontal machine) uses the front toolplane as the base machine
# view.
# Relative to the machine matrix -
# Rotation zero position is on the Z axis for rotation on X axis.
# Rotation zero position is on the Z axis for rotation on Y axis.
# Rotation zero position is on the X axis for rotation on Z axis.
# The machine view rotated about the selected axis as a "single axis
# rotation" are the only legal views for 4 axis milling.  Rotation
# direction around the part is positive in the CCW direction when
# viewed from the plus direction of the rotating axis.  Set the variable
# 'rot_ccw_pos' to indicate the signed direction.  Always set the work
# origin at the center of rotation.
#Toolplane Positioning:
# Create the Cplane and Tplane as the rotation of the machine view about
# the selected axis of rotation.  The toolplane is used to calculate
# the position of the rotary axis.  This is the default setting.
#3 Axis Rotary (Polar)
# Polar positioning is offered in Mastercam 3 axis toolpaths through the
# rotary axis options dialog.  The selected toolpath is converted to angle
# and radius position.  The axis of rotation is forced to zero.
#Axis substitution:
# Use the Rotary axis substitution by drawing the geometry flattened
# from the cylinder.  The rotary axis button must be active for axis
# substitution information to be output to the NCI file. The radius of
# the rotary diameter is added to all the Z positions at output.
#Simultaneous 4 Axis (11 gcode):
# Full 4 axis toolpaths can be generated from various toolpaths under the
# 'multi-axis' selection (i.e. Rotary 4 axis). All 5 axis paths are
# converted to 4 axis paths where only the angle about the rotation axis
# is resolved.
#Drill:
# All drill methods are supported in the post.  See Simultaneous 4 Axis.
#Additional Notes:
# 1) G54 calls are generated where the work offset entry of 0 = G54,
#    1 = G55, etc.
# 2) Metric is applied from the NCI met_tool variable.
# 3) Incremental mode calculates motion from home position at toolchanges.
#    The home position is used to define the last position of the tool
#    for all toolchanges.
# 4) The variable 'absinc' is now pre-defined, set mi2 (Misc. Integer) for
#    the 'top level' absolute/incremental program output.  Subprograms are
#    updated through the Mastercam dialog settings for sub-programs.
# 5) Always avoid machining to the center of rotation with rotary axis!
# 6) Transform subprograms are intended for use with G54.. workshifts.
# END_HEADER$
#endregion
#region Debugging and factory set program switches
# Debugging and Factory Set Program Switches
#Define Constants
m_one        := -1
zero         := 0
one          := 1
two          := 2
three        := 3
four         := 4
five         := 5
c9k          := 9999
bug4$        : 1     #Debug output with the tilde '~'.
                     #A value greater the zero applies the variable formatting with
                     #debug output (default is typically FS 1 but not a guarantee).
                     #A value of zero gets the value directly with NO formatting.
linktolvar$  : 0     #Associate X tolerance variables to V9- variable?
linkplnvar$  : 0     #Associate X plane specific variables to V9- variable?
skp_lead_flgs$ : 0   #Do NOT use v9 style contour flags
get_1004$    : 1     #Find gcode 1004 with getnextop?
rpd_typ_v7$  : 0     #Use Version 7 style contour flags/processing?
strtool_v7$  : 2     #Use Version 7+ toolname?
tlchng_aft$  : 2     #Delay call to toolchange until move line
cant_tlchng$ : 1     #Ignore cantext entry on move with tlchng_aft
newglobal$   : 1     #Error checking for global variables
getnextop$   : 1     #Build the next variable table
tooltable$   : 3     #Pre-read, call the pwrtt postblock
#endregion
#region General output settings
# General Output Settings
maxfeedpm    : 500   #SET_BY_MD Limit for feed in inch/min
ltol_m       : 0.05  #Length tolerance for arccheck, metric
vtol_m       : 0.0025#System tolerance, metric
maxfeedpm_m  : 10000 #SET_BY_MD Limit for feed in mm/min
force_wcs    : yes$  #Force WCS output at every toolchange?
stagetool    : 0     #SET_BY_CD 0 = Do not pre-stage tools, 1 = Stage tools
stagetltype  : 1     #0 = Do not stage 1st tool
                     #1 = Stage 1st tool at last tool change
                     #2 = Stage 1st tool at end of file (peof)
use_gear     : 0     #Output gear selection code, 0=no, 1=yes
min_speed    : 50    #SET_BY_MD Minimum spindle speed
progname$    : 1     #Use uppercase for program name (sprogname)
prog_stop    : 1     #Program stop at toolchange: 0=None, 1=M01, 2 = M00
tool_info    : 2     #Output tooltable information?
                     #0 = Off - Do not output any tool comments or tooltable
                     #1 = Tool comments only
                     #2 = Tooltable in header - no tool comments at T/C
                     #3 = Tooltable in header - with tool comments at T/C
tlchg_home   : no$   #Zero return X and Y axis prior to tool change?
# The following three initializations are used for full arc and helix arc output when the CD
#   is set to output R or signed R for arcs
arctype$     : 2     #Arc center type XY plane 1=abs, 2=St-Ctr, 3=Ctr-St, 4=unsigned inc.
arctypexz$   : 2     #Arc center type XZ plane 1=abs, 2=St-Ctr, 3=Ctr-St, 4=unsigned inc.
arctypeyz$   : 2     #Arc center type YZ plane 1=abs, 2=St-Ctr, 3=Ctr-St, 4=unsigned inc.
#endregion
#region Rotary axis settings
# Rotary Axis Settings
read_md      : no$   #Set rotary axis switches by reading Machine Definition?
vmc          : 1     #SET_BY_MD 0 = Horizontal Machine, 1 = Vertical Mill
rot_on_x     : 1     #SET_BY_MD Default Rotary Axis Orientation
                     #0 = Off, 1 = About X, 2 = About Y, 3 = About Z
rot_ccw_pos  : 0     #SET_BY_MD Axis signed dir, 0 = CW positive, 1 = CCW positive
index        : 0     #SET_BY_MD Use index positioning, 0 = Full Rotary, 1 = Index only
ctable       : 5     #SET_BY_MD Degrees for each index step with indexing spindle
use_frinv    : no$   #SET_BY_CD Use Inverse Time Feedrates in 4 Axis, (0 = no, 1 = yes)
maxfrdeg     : 2000  #SET_BY_MD Limit for feed in deg/min
maxfrinv     : 999.99#SET_BY_MD Limit for feed inverse time
maxfrinv_m   : 99.99 #SET_BY_MD Maximum feedrate - inverse time
frc_cinit    : yes$  #Force C axis reset at toolchange
ctol         : 225   #Tolerance in deg. before rev flag changes
ixtol        : 0.01  #Tolerance in deg. for index error
frdegstp     : 10    #Step limit for rotary feed in deg/min
rot_type     : 1     #SET_BY_MD Rotary type - 0=signed continuous, 1=signed absolute, 2=shortest direction
force_index  : no$   #Force rotary output to index mode when tool plane positioning with a full rotary
use_rotmcode : 0     #Output M-Code for Axis direction (sindx_mc)
                     #0 = Signed direction (only valid when rot_type = 1)
                     #1 = M-Code for direction
toolismetric       : 0     #flag that tool is metric
tap_feedtype       : 1     #0 = Units Per Minute (G94)
                           #1 = Units Per Revolution (G95)
#Rotary Axis Label options
use_md_rot_label : no$  #Use rotary axis label from machine def? - Leave set to 'no' until available
srot_x       : "A"   #Label applied to rotary axis movement - rotating about X axis - used when use_md_rot_label = no
srot_y       : "B"   #Label applied to rotary axis movement - rotating about Y axis - used when use_md_rot_label = no
srot_z       : "C"   #Label applied to rotary axis movement - rotating about Z axis - used when use_md_rot_label = no
sminus       : "-"   #Address for the rotary axis (signed motion)
#Axis locking
use_rot_lock : no$  #Use rotary axis lock/unlock codes
#endregion
#region Common user-defined variable initializations (not switches!)
# Common User-defined Variable Initializations (not switches!)
xia          : 0     #Formatted absolute value for X incremental calculations
yia          : 0     #Formatted absolute value for Y incremental calculations
zia          : 0     #Formatted absolute value for Z incremental calculations
cia          : 0     #Formatted absolute value for C incremental calculations
cuttype      : 0     #Cut type flag
                     #0 = Tool Plane, 1 = Axis Subs,  2 = Polar, 3 = 4/5 axis
bld          : 0     #Block delete active
result       : 0     #Return value for functions
sav_spc      : 0     #Save spaces
sav_gcode    : 0     #Gcode saved
sav_absinc   : 0     #Absolute/Incremental Saved Value
sav_coolant  : 0     #Coolant saved
sav_frc_wcs  : 0     #Force work offset flag saved
toolchng     : 1     #On a toolchange flag
toolchng0    : 0     #On a null toolchange flag
spdir2       : 1     #Copy for safe spindle direction calculation
#Drill variables
drlgsel      : -1    #Drill Select Initialize
drillref     : 0     #Select drill reference
drlgcode     : 0     #Save Gcode in drill
sav_dgcode   : 0     #Drill gcode saved
#Subprogram variables
mr_rt_actv   : 0     #Flag to indicate if G51/G68 is active
                     #0=Off, 1=Rotate initial, 2=G68 Subprogram call/start, 3=Mirror, Neg. enable restore
mr_rt_rst    : 0     #Flag to restore abs/inc when G51/G68 is active
rt_csav      : 0     #C saved value
end_sub_mny  : 0     #Many tool setting captured at transform sub end
#Rotary/Index variables
prvcabs      : 0     #Saved cabs from pe_inc_calc,
                     #Used for rotary feed and direction calculations
cdelta       : 0     #Calculation for angle change
cdelta_calc  : 0     #Rotation calculation
rev          : 0     #Calculation for deg/min
sav_rev      : 0     #Saved revolution counter
indx_out     : c9k   #Rotation direction calculation
fmt     16  indx_mc  #Rotation direction calculation
rev_brkflag  : 0     #Revolution break flag. 0 = No break, 1 = Break every 90 or 360 degrees (see pmotion_su)
rot_locked   : 1     #Flag to track status of rotary lock (0=unlocked, 1=locked), (Not a switch - initialized to 1 to force unlock with first rotary move)
#Vector Constants for Rotatary Calculations
aaxisx       : 1     #A axis rotation vector constant
aaxisy       : 0     #A axis rotation vector constant
aaxisz       : 0     #A axis rotation vector constant
baxisx       : 0     #B axis rotation vector constant
baxisy       : 1     #B axis rotation vector constant
baxisz       : 0     #B axis rotation vector constant
caxisx       : 0     #C axis rotation vector constant
caxisy       : 0     #C axis rotation vector constant
caxisz       : 1     #C axis rotation vector constant
#Feedrate calculation variables
frdelta      : 0     #Calculation for deg/min
frinv        : 0     #Feedrate inverse time
frdeg        : 0     #Feedrate deg/min actual
prvfrdeg     : 0     #Feedrate deg/min actual
ldelta       : 0     #Calculation for deg/min, linear
cldelta      : 0     #Calculation for deg/min, linear and rotary
circum       : 0     #Calculation for deg/min
ipr_type     : 0     #Feedrate for Rotary, 0 = UPM, 1 = DPM, 2 = Inverse
comp_type    : 0     #Cutter compensation type - 0=computer, 1=control, 2=wear, 3=reverse wear, 4=off
subs_before  : 0     #Flag to indicate whether subprograms are to be output before or after main program
first_sub    : 1     #Flag used to suppress blank line before first sub that gets output with subs before main
#rotary_axis2 values are not consistent with rot_on_x values.  Need to add 1 to rotary_axis2 to compare them.
rotary_axis2 : c9k   #Rotary axis selected in Multiaxis Drill and Curve 5 Axis, 0=X, 1=Y, 2=Z
#Coolant variables for X style coolant
cant_pos     : 0     #Read from current canned text (cant_pos1 - cant_pos20)
coolant_bin  : 0     #Binary value for current coolant command
coolant_on   : 0     #Binary value holding the sum of all coolants currently on
coolantx     : 0     #Selector variable for coolant string selector
local_int    : 0     #Local variable for output of coolant off commands
result2      : 0     #Return value for functions
suppress     : 0     #Flag used to suppress redundant coolant on commands
all_cool_off : 0     #First coolant off command shuts off ALL coolant options
#Variables to capture parameter values - use to set post switches in pset_mach
rotaxerror   : 0     #Error flag
rot_axis     : 0     #Axis of rotation - 1=X, 2=Y, 3=Z
rot_dir      : 0     #Rotary direction - CW is positive, 0 = false, 1 = true
rot_index    : 0     #Index or continuous - 0 = continuous, 1 = index
rot_angle    : 0     #Degrees for each index step with indexing spindle
rot_zero     : 0     #Rotary zero degree position (NOT CURRENTLY IMPLEMENTED)
rot_ax_cnt   : 0     #Rotary axis counter
component_type : 0   #Component type: (See documentation for complete list - )
                       #0 = MACHINE
                       #1 = STOCK_COMPONENT
                       #2 = MISC_COMPONENT
                       #3 = MACHINE_BASE_COMPONENT
                       #4 = LINEAR_AXIS_COMPONENT
                       #5 = ROTARY_AXIS_COMPONENT
                       #6 = RECT_TABLE_COMPONENT
                       #12 = CHUCK_COMPONENT
                       #24 = TOOL_SPINDLE_COMPONENT
                       #23 = ATC_COMPONENT
z_dir        : 0     #Z Axis direction flag
axis_label   : 0     #Axis label - 1=X,2=Y,3=Z
srot_label   : ""    #Rotary Axis label (Generally A, B or C)
sav_srot_label : ""  #Store original rotary axis label (required for signed rotation output rot_type = 1)
sav_index    : 0     #Store original index value
#endregion
#region String definitions for NC output
#String and string selector definitions for NC output
#Address string definitions
strm         : "M"
strn         : "N"
stro         : "O"
strp         : "P"
srad         : "R"
srminus      : "R-"
sblank       : ""
#Cantext string definitions (spaces must be padded here)
sm00         : "M00"
sm01         : "M01"
strtextno    : ""
strcantext   : ""
#Transform mirror and rotate codes
strns_mir_on  : "G51.1" #Programmable mirror image code
strns_mir_off : "G50.1" #Programmable mirror image cancel code
strns_rot_on  : "G68"   #Coordinate System Rotation
strns_rot_off : "G69"   #Coordinate System Rotation Cancel
#Misc. string definitions
sopen_prn    : "("   #String for open parenthesis "("
sclose_prn   : ")"   #String for close parenthesis ")"
sdelimiter   : "|"   #String for delimiter
sg95         : "G95" #Feed per rotation
sm29         : "M29" #Rigid tapping preperation support function
sg80         : "G80" #Cancel canned drilling cycle
sg43         : "G43" #Tool length compensation
sg49         : "G49" #Tool length compensation cancel
sg92         : "G92" #Set work piece coordinate system
sm06         : "M6"  #Toolchange
#endregion
#region Error messages
# Error messages
saxiserror   : "WARNING - DEFINED AXIS OF ROTATION DOES NOT MATCH OPERATION'S AXIS OF ROTATION - OUTPUT MAY BE INVALID"
sindxerror   : "WARNING - INDEX ANGLE DOES NOT MATCH POST SETTING ('ctable')"
stlorgerr    : "ERROR - TOOL ORIGIN DOES NOT MATCH CENTER OF ROTATION IN POLAR MILLING"
shomeserror  : "ERROR - WORK OFFSET USAGE DOES NOT SUPPORT TRANSFORM SUBPROGRAM"
sprgnerror   : "ERROR - SUBPROGRAM NUMBER MATCHES THE MAIN PROGRAM NUMBER"
srotaxerror  : "ERROR - MORE THAN 1 ROTARY AXIS DETECTED IN SELECTED AXIS COMBINATION - OUTPUT MAY BE INVALID"
#endregion
#region String select, lookup tables for NC output
# General G and M Code String select tables
# Motion G code selection
sg00    : "G0"       #Rapid
sg01    : "G1"       #Linear feed
sg02    : "G2"       #Circular interpolation CW
sg03    : "G3"       #Circular interpolation CCW
sg04    : "G4"       #Dwell
sgcode  : ""         #Target string
fstrsel sg00 gcode$ sgcode 5 -1
# Select work plane G code
sg17    : "G17"      #XY plane code
sg19    : "G19"      #YZ plane code
sg18    : "G18"      #XZ plane code
sgplane : ""         #Target string
fstrsel sg17 plane$ sgplane 3 -1
#Select english/metric code
sg20    : "G20"      #Inch code
sg21    : "G21"      #Metric code
smetric : ""         #Target string
fstrsel sg20 met_tool$ smetric 2 -1
#Select reference return code
sg28    : "G28"      #First reference point return
sg30    : "G30"      #Second reference point return
sg28ref : ""         #Target string
fstrsel sg28 mi3$ sg28ref 2 -1
# Cutter compensation G code selection
scc0    : "G40"      #Cancel cutter compensation
scc1    : "G41"      #Cutter compensation left
scc2    : "G42"      #Cutter compensation right
sccomp  : ""         #Target string
fstrsel scc0 cc_pos$ sccomp 3 -1
# Canned drill cycle string select
sg81    : "G81"      #drill - no dwell
sg81d   : "G82"      #drill - with dwell
sg83    : "G83"      #peck drill - no dwell
sg83d   : "G83"      #peck drill - with dwell
sg73    : "G73"      #chip break - no dwell
sg73d   : "G73"      #chip break - with dwell
sg84    : "G84"      #tap - right hand
sg84d   : "G74"      #tap - left hand
sg85    : "G85"      #bore #1 - no dwell
sg85d   : "G89"      #bore #1 - with dwell
sg86    : "G86"      #bore #2 - no dwell
sg86d   : "G86"      #bore #2 - with dwell
sgm1    : "G76"      #fine bore - no dwell
sgm1d   : "G76"      #fine bore - with dwell
sgm2    : "G84"      #rigid tap  - right hand
sgm2d   : "G74"      #rigid tap  - left hand
sgdrill : ""         #Target string
fstrsel sg81 drlgsel sgdrill 16 -1
# Select incremental or absolute G code
sg90    : "G90"      #Absolute code
sg91    : "G91"      #Incremental code
sgabsinc : ""        #Target string
fstrsel sg90 absinc$ sgabsinc 2 -1
# Feed mode G code selection
sg94    : "G94"      #UPM
sg94d   : "G94"      #DPM, See pfcalc_deg if you use another gcode
sg93    : "G93"      #Inverse
sgfeed  : ""         #Target string
fstrsel sg94 ipr_type sgfeed 3 -1
#Canned drill cycle reference height
sg98    : "G98"      #Reference at initht
sg99    : "G99"      #Reference at refht
sgdrlref : ""        #Target string
fstrsel sg98 drillref sgdrlref 2 -1
# Generate string for spindle
sm04    : "M4"       #Spindle reverse
sm05    : "M5"       #Spindle off
sm03    : "M3"       #Spindle forward
spindle : ""         #Target string
fstrsel sm04 spdir2 spindle 3 -1
# Coolant M code selection for V9 style coolant
# Note: To enable V9 style coolant, click on the General Machine Parameters icon
#   in the Machine Definition Manager, Coolant tab, enable first check box
#   Output of V9 style coolant commands in this post is controlled by scoolant
sm09    : "M9"       #Coolant Off
sm08    : "M8"       #Coolant Flood
sm08_1  : "M8"       #Coolant Mist
sm08_2  : "M8"       #Coolant Tool
scoolant : ""        #Target string
fstrsel sm09 coolant$ scoolant 4 -1
# Coolant output code selection for X style coolant
# Note: To enable X style coolant, click on the General Machine Parameters icon
#   in the Machine Definition Manager, Coolant tab, disable first check box
#   Output of X style coolant commands in this post is controlled by pcan, pcan1, & pcan2
scool50 : "M8"                 #Coolant 1 on value
scool51 : "M9"                 #Coolant 1 off value
scool52 : "M7"                 #Coolant 2 on value
scool53 : "M9"                 #Coolant 2 off value
scool54 : "M88"                #Coolant 3 on value
scool55 : "M89"                #Coolant 3 off value
scool56 : "M8(Coolant4=ON)"    #Coolant 4 on value
scool57 : "M9(Coolant4=OFF)"   #Coolant 4 off value
scool58 : "M8(Coolant5=ON)"    #Coolant 5 on value
scool59 : "M9(Coolant5=OFF)"   #Coolant 5 off value
scool60 : "M8(Coolant6=ON)"    #Coolant 6 on value
scool61 : "M9(Coolant6=OFF)"   #Coolant 6 off value
scool62 : "M8(Coolant7=ON)"    #Coolant 7 on value
scool63 : "M9(Coolant7=OFF)"   #Coolant 7 off value
scool64 : "M8(Coolant8=ON)"    #Coolant 8 on value
scool65 : "M9(Coolant8=OFF)"   #Coolant 8 off value
scool66 : "M8(Coolant9=ON)"    #Coolant 9 on value
scool67 : "M9(Coolant9=OFF)"   #Coolant 9 off value
scool68 : "M8(Coolant10=ON)"   #Coolant 10 on value
scool69 : "M9(Coolant10=OFF)"  #Coolant 10 off value
scoolantx  : ""                #Target string
fstrsel scool50 coolantx scoolantx 20 -1
#X coolant has the option - First coolant off command shuts off ALL coolant options
sall_cool_off : "M09" #Coolant off command output with all_cool_off
# Table rotation direction, index
sindx_cw  : "M22"    #Rotate CW code
sindx_ccw : "M21"    #Rotate CCW code
sindx_mc  : ""       #Target string
fstrsel sindx_cw indx_mc sindx_mc 2 -1
# Define the gear selection code
flktbl  1       3       #Lookup table definition - table no. - no. entries
        40      0       #Low gear range
        41      400     #Med gear range
        42      2250    #Hi gear range
# Define coolant binary value for X style coolant
flktbl  2       20      #Lookup table definition - table no. - no. entries
        1       50      #Coolant 1 on value
        2       51      #Coolant 1 off value
        4       52      #Coolant 2 on value
        8       53      #Coolant 2 off value
        16      54      #Coolant 3 on value
        32      55      #Coolant 3 off value
        64      56      #Coolant 4 on value
        128     57      #Coolant 4 off value
        256     58      #Coolant 5 on value
        512     59      #Coolant 5 off value
        1024    60      #Coolant 6 on value
        2048    61      #Coolant 6 off value
        4096    62      #Coolant 7 on value
        8192    63      #Coolant 7 off value
        16384   64      #Coolant 8 on value
        32768   65      #Coolant 8 off value
        65536   66      #Coolant 9 on value
        131072  67      #Coolant 9 off value
        262144  68      #Coolant 10 on value
        524288  69      #Coolant 10 off value
# Month selector
smon0   : ""
smon1   : "JAN."
smon2   : "FEB."
smon3   : "MAR."
smon4   : "APR."
smon5   : "MAY."
smon6   : "JUN."
smon7   : "JUL."
smon8   : "AUG."
smon9   : "SEP."
smon10  : "OCT."
smon11  : "NOV."
smon12  : "DEC."
smonth  : ""         #Target string
fstrsel smon0 month$ smonth 13 -1
# Cutter Compensation Type
scomp   : "COMPUTER"
scomp1  : "CONTROL COMP"
scomp2  : "WEAR COMP"
scomp3  : "REVERSE WEAR COMP"
scomp4  : "OFF"
scomp_type : ""      #Target string
fstrsel scomp comp_type scomp_type 5 -1
# Rotary axis lock/unlock
sunlock   : "M11"    #Unlock Rotary Axis
slock     : "M10"    #Lock Rotary Axis
srot_lock : ""       #Target string
fstrsel sunlock rot_locked srot_lock 2 -1
#endregion
#region Format statements
# Format statements - n=nonmodal, l=leading, t=trailing, i=inc, d=delta
#Default english/metric position format statements
fs2 1   0.7 0.6      #Decimal, absolute, 7 place, default for initialize (:)
fs2 2   0.4 0.3      #Decimal, absolute, 4/3 place
fs2 3   0.4 0.3d     #Decimal, delta, 4/3 place
#Common format statements
fs2 4   1 0 1 0      #Integer, not leading
fs2 5   2 0 2 0l     #Integer, force two leading
fs2 6   3 0 3 0l     #Integer, force three leading
fs2 7   4 0 4 0l     #Integer, force four leading
fs2 9   0.1 0.1      #Decimal, absolute, 1 place
fs2 10  0.2 0.2      #Decimal, absolute, 2 place
fs2 11  0.3 0.3      #Decimal, absolute, 3 place
fs2 12  0.4 0.4      #Decimal, absolute, 4 place
fs2 13  0.5 0.5      #Decimal, absolute, 5 place
fs2 14  0.3 0.3d     #Decimal, delta, 3 place
fs2 15  0.2 0.1      #Decimal, absolute, 2/1 place (feedrate)
fs2 16  1 0 1 0n     #Integer, forced output
fs2 17  0.2 0.3      #Decimal, absolute, 2/3 place (tapping feedrate)
# These formats used for 'Date' & 'Time'
fs2 18  2.2 2.2lt    #Decimal, force two leading & two trailing (time2)
fs2 19  2 0 2 0t     #Integer, force trailing                   (hour)
fs2 20  0 2 0 2lt    #Integer, force leading & trailing         (min)
# This format statement is used for sequence number output
# Number of places output is determined by value for "Increment Sequence Number" in CD
# Max depth to the right of the decimal point is set in the fs statement below
fs2 21  0^7 0^7      #Decimal, 7 place, omit decimal if integer value
fs2 22  0^3 0^3      #Decimal, 3 place, omit decimal if integer value
#endregion
#region Format assignments
# Toolchange / NC output Variable Formats
fmt  "T" 4  t$          #Tool number
fmt  "T" 4  first_tool$ #First tool used
fmt  "T" 4  next_tool$  #Next tool used
fmt  "D" 4  tloffno$    #Diameter offset number
fmt  "H" 4  tlngno$     #Length offset number
fmt  "G" 4  g_wcs       #WCS G address
fmt  "P" 4  p_wcs       #WCS P address
fmt  "S" 4  speed       #Spindle Speed
fmt  "M" 4  gear        #Gear range
fmt  "N" 21 n$          #Sequence number
fmt  "X" 2  xabs        #X position output
fmt  "Y" 2  yabs        #Y position output
fmt  "Z" 2  zabs        #Z position output
fmt  "X" 3  xinc        #X position output
fmt  "Y" 3  yinc        #Y position output
fmt  "Z" 3  zinc        #Z position output
fmt  "A" 11 cabs        #C axis position
fmt  "A" 14 cinc        #C axis position
fmt  "A" 22 indx_out    #Index position
fmt  "R" 14 rt_cinc     #C axis position, G68
fmt  "I" 3  iout        #Arc center description in X
fmt  "J" 3  jout        #Arc center description in Y
fmt  "K" 3  kout        #Arc center description in Z
fmt  "R" 2  arcrad$     #Arc Radius
fmt  "F" 15 feed        #Feedrate
fmt  "P" 11 dwell$      #Dwell
fmt  "M" 5  cantext$    #Canned text
fmt  "F" 2  pitch       #Tap pitch (units per thread)
#Move comment (pound) to output colon with program numbers
fmt  "O" 7  progno$     #Program number
#fmt ":" 7   progno$     #Program number
fmt  "O" 7  main_prg_no$ #Program number
#fmt ":" 7   main_prg_no$ #Program number
fmt  "O" 7  sub_prg_no$ #Program number
#fmt ":" 7   sub_prg_no$ #Program number
fmt  "X" 2  sub_trnsx$  #Rotation point
fmt  "Y" 2  sub_trnsy$  #Rotation point
fmt  "Z" 2  sub_trnsz$  #Rotation point
fmt  "Q" 2  peck1$      #First peck increment (positive)
fmt  "Q" 2  shftdrl$    #Fine bore tool shift
fmt  "R" 2  refht_a     #Reference height
fmt  "R" 2  refht_i     #Reference height
fmt "TOOL - "      4   tnote    #Note format
fmt "DIA. OFF. - " 4   toffnote #Note format
fmt "LEN. - "      4   tlngnote #Note format
fmt "TOOL DIA. - " 1   tldia$   #Note format
fmt "XY STOCK TO LEAVE - " 2  xy_stock #Note format
fmt "Z STOCK TO LEAVE - "  2  z_stock  #Note format
fmt     4   year2       #Calculated year value
fmt     18  time2       #Capture 24-hour time value into 'time2' variable
fmt     19  hour        #Hour
fmt     20  min         #Minutes
year2 = year$ + 2000
#endregion
#region Tool comment, tool table, manual entry output
# Tool Comment / Manual Entry Section
ptoolcomment    #Comment for tool
      tnote = t$, toffnote = tloffno$, tlngnote = tlngno$
      if tool_info = 1 | tool_info = 3,
        sopen_prn, pstrtool, sdelimiter, *tnote, sdelimiter, *toffnote, sdelimiter, *tlngnote, sdelimiter, *tldia$, sclose_prn, e$
ptooltable      #Tooltable output
      sopen_prn, *t$, sdelimiter, pstrtool, sdelimiter, *tlngno$,
        [if comp_type > 0 & comp_type < 4, sdelimiter, *tloffno$, sdelimiter, *scomp_type, sdelimiter, *tldia$],
        [if xy_stock <> 0 | z_stock <> 0, sdelimiter, *xy_stock, sdelimiter, *z_stock],
        sclose_prn, e$
      xy_stock = 0  #Reset stock to leave values
      z_stock = 0   #Reset stock to leave values
pstrtool        #Comment for tool
      if strtool$ <> sblank,
        strtool$ = ucase(strtool$)
        *strtool$
pcomment$       #Comment from manual entry (must call pcomment2)
      pcomment2 #Required if doing boolean 'if' logic testing!
pcomment2       #Output Comment from manual entry
      scomm$ = ucase (scomm$)
      if gcode$ = 1005, sopen_prn, scomm$, sclose_prn, e$  #Manual entry - as comment
      if gcode$ = 1006, scomm$, e$                         #Manual entry - as code
      if gcode$ = 1007, sopen_prn, scomm$, sclose_prn      #Manual entry - as comment with move NO e$
      if gcode$ = 1026, scomm$                             #Manual entry - as code with move NO e$
      if gcode$ = 1008, sopen_prn, scomm$, sclose_prn, e$  #Operation comment
      if gcode$ = 1051, sopen_prn, scomm$, sclose_prn, e$  #Machine name
      if gcode$ = 1052, sopen_prn, scomm$, sclose_prn, e$  #Group comment
      if gcode$ = 1053, sopen_prn, scomm$, sclose_prn, e$  #Group name
      if gcode$ = 1054, sopen_prn, scomm$, sclose_prn, e$  #File Descriptor
#endregion
#region Header, date/time
# Start of File and Toolchange Setup
ptime           #Convert 24-hour time format into 12-hour AM/PM format
      if time$ >= 13, time2 = (time$ - 12)
      else, time2 = time$
      hour = int(time2), min = frac(time2)
      *hour, ":", *min,
      if time$ > 12, " PM"
      else, " AM"
pheader$         #Call before start of file
      if subs_before, " ", e$ #header character is output from peof when subs are output before main
      else, "%", e$
      sav_spc = spaces$
      spaces$ = 0
      *progno$, sopen_prn, sprogname$, sclose_prn, e$
      #sopen_prn, "PROGRAM NAME - ", sprogname$, sclose_prn, e$
      sopen_prn, "DATE=DD-MM-YY - ", date$, " TIME=HH:MM - ", time$, sclose_prn, e$ #Date and time output Ex. 12-02-05 15:52
      #sopen_prn, "DATE - ", month$, "-", day$, "-", year$, sclose_prn, e$  #Date output as month,day,year - Ex. 02-12-05
      #sopen_prn, "DATE - ", *smonth, " ", day$, " ", *year2, sclose_prn, e$ #Date output as month,day,year - Ex. Feb. 12 2005
      #sopen_prn, "TIME - ", time$, sclose_prn, e$  #24 hour time output - Ex. 15:52
      #sopen_prn, "TIME - ", ptime sclose_prn, e$  #12 hour time output 3:52 PM
      spathnc$ = ucase(spathnc$)
      smcname$ = ucase(smcname$)
      stck_matl$ = ucase(stck_matl$)
      snamenc$ = ucase(snamenc$)
      sopen_prn, "MCX FILE - ", *smcpath$, *smcname$, *smcext$, sclose_prn, e$
      sopen_prn, "NC FILE - ", *spathnc$, *snamenc$, *sextnc$, sclose_prn, e$
      sopen_prn, "MATERIAL - ", *stck_matl$, sclose_prn, e$
      spaces$ = sav_spc
#endregion
#region Start of file
psof0$           #Start of file for tool zero
      psof$
psof$            #Start of file for non-zero tool number
      pcuttype
      toolchng = one
      if ntools$ = one,
        #skip single tool outputs, stagetool must be on
        stagetool = m_one
        !next_tool$
      pbld, n$, *smetric, e$
      if convert_rpd$, pconvert_rpd
      pbld, n$, [if gcode$, *sgfeed], *sgcode, *sgplane, scc0, sg49, sg80, *sgabsinc, [if gcode$, *feed], e$
      sav_absinc = absinc$
      if mi1$ <= one, #Work coordinate system
        absinc$ = one
        pfbld, n$, sgabsinc, *sg28ref, "Z0.", e$
        pfbld, n$, *sg28ref, "X0.", "Y0.", e$
        pfbld, n$, sg92, *xh$, *yh$, *zh$, e$
        absinc$ = sav_absinc
      pcom_moveb
      pcheckaxis
      c_mmlt$ #Multiple tool subprogram call
      ptoolcomment
      comment$
      pcan
      pbld, n$, *t$, sm06, e$
      pindex
      if mi1$ > one, absinc$ = zero
      if use_rot_lock & (cuttype <> zero | (index = zero & prv_cabs <> fmtrnd(cabs))), prot_unlock
      pcan1, pbld, n$, [if gcode$, *sgfeed], *sgcode, *sgabsinc, pwcs, pfxout, pfyout, pfcout,
        [if nextdc$ <> 7, *speed, *spindle], pgear, [if gcode$, *feed], strcantext, e$
      if use_rot_lock & cuttype = zero, prot_lock
      pbld, n$, sg43, *tlngno$, pfzout, pscool, pstagetool, e$
      pbld, n$, sgabsinc, e$
      pcom_movea
      toolchng = zero
      c_msng$ #Single tool subprogram call
#endregion
#region Tool change
#region Null tool change
ptlchg0$         #Call from NCI null tool change (tool number repeats)
      pcuttype
      toolchng0 = one
      pcom_moveb
      pcheckaxis
      comment$
      pcan
      result = newfs(15, feed)  #Reset the output format for 'feed'
      pbld, n$, sgplane, e$
      pspindchng
      pbld, n$, pscool, e$
      if mi1$ > one & workofs$ <> prv_workofs$,
        absinc$ = zero
        pbld, n$, sgabsinc, pwcs, pfxout, pfyout, pfzout, pfcout, e$
        pe_inc_calc
        ps_inc_calc
      if cuttype = zero, ppos_cax_lin
      if gcode$ = one, plinout
      else, prapidout
      pcom_movea
      toolchng0 = zero
      !xnci$, !ynci$, !znci$
#endregion
#region Tool change / stage tool
ptlchg$          #Tool change
      pcuttype
      toolchng = one
      if mi1$ = one, #Work coordinate system
      if prog_stop = 1, pbld, n$, *sm01, e$
      if prog_stop = 2, pbld, n$, *sm00, e$
      pcom_moveb
      pcheckaxis
      ptoolcomment
      comment$
      pcan
      pindex
      pcom_movea
      toolchng = zero
pstagetool      #Pre-stage tools
      if stagetool = 1,
        if ttblend$,  #Check for last toolchange
          if stagetltype = 1, *next_tool$  #stage first tool at last toolchange
        else, *next_tool$ #stage tool at every toolchange
#endregion
#End of Tool change region
#endregion
#region Retract at end of tool path, reference return
pretract        #End of tool path, toolchange
      absinc$ = one
      sav_coolant = coolant$
      coolant$ = zero
#      if nextop$ = 1003, #Uncomment this line to leave coolant on until eof unless
        [                 #  explicitely turned off through a canned text edit
        if all_cool_off,
          #all coolant off with a single off code here
          if coolant_on, pbld, n$, sall_cool_off, e$
          coolant_on = zero
        else,
          local_int = zero
          coolantx = zero
          while local_int < 20 & coolant_on > 0,
            coolantx = and(2^local_int, coolant_on)
            local_int = local_int + one
            if coolantx > zero,
              coolantx = local_int
              pbld, n$, scoolantx, e$
            coolantx = zero
          coolant_on = zero
      #cc_pos is reset in the toolchange here
      cc_pos$ = zero
      gcode$ = zero
      if use_rot_lock & rot_on_x,
        if (index = one & (prv_indx_out <> fmtrnd(indx_out)) | (prv_cabs <> fmtrnd(cabs)))
          | nextop$ = 1003 | frc_cinit, prot_unlock
      pbld, n$, sccomp, *sm05, psub_end_mny, e$
      pbld, n$, [if gcode$, sgfeed], sgabsinc, sgcode, *sg28ref, "Z0.", [if gcode$, feed], scoolant, e$
      if nextop$ = 1003 | tlchg_home, pbld, n$, *sg28ref, "X0.", "Y0.", protretinc, e$
      else, pbld, n$, protretinc, e$
      coolant$ = sav_coolant
protretinc      #Reset the C axis revolution counter
      if frc_cinit & rot_on_x,
        rev = zero
        sav_rev = zero
        cabs = zero
        csav = zero
        indx_out = zero
        if index, e$, pindxcalc, pindex
        else, *cabs
        prvcabs = zero
        !csav, !cabs
#endregion
#region End-of-file
peof0$           #End of file for tool zero
      peof$
peof$            #End of file for non-zero tool
      pretract
      comment$
      if stagetool = 1 & stagetltype = 2, pbld, n$, *first_tool$, e$
      n$, "M30", e$
      if subs_before, #Merge subs before main program
        [             #At this point, the NC / Main program level is blank (Main prg was written to ext with subs before)
        subout$ = zero
        "%", e$
        mergesub$     #Merge transform subs
        clearsub$
        mergeaux$     #Merge non-transform subs
        clearaux$
        mergeext$     #Merge NC / Main program
        clearext$
      else,           #Merge subs after main program
        [             #At this point, the NC / Main program is written (Main prg was written to NC level with subs after)
        mergesub$
        clearsub$
        mergeaux$
        clearaux$
      subout$ = zero
      "%", e$
#endregion
#region Work offsets, gear selection
pwcs            #G54+ coordinate setting at toolchange
      if mi1$ > one,
        sav_frc_wcs = force_wcs
        if sub_level$ > 0, force_wcs = zero
        if workofs$ <> prv_workofs$ | (force_wcs & toolchng),
          if workofs$ < 6,
            g_wcs = workofs$ + 54
            *g_wcs
          else,
            p_wcs = workofs$ - five
            "G54.1", *p_wcs
        force_wcs = sav_frc_wcs
        !workofs$
pgear           #Find spindle gear from lookup table
      if use_gear = one,
        gear = frange (one, speed)
        *gear
#endregion
#region Tool change setup, spindle speed, tool end
#Toolchange setup
pspindchng      #Spindle speed change
      if prv_spdir2 <> spdir2 & prv_speed <> zero, pbld, n$, *sm05, e$
      if prv_speed <> speed | prv_spdir2 <> spdir2,
        if speed, pbld, n$, *speed, *spindle, pgear, e$
      !speed, !spdir2
pspindle        #Spindle speed calculations for RPM
      speed = abs(ss$)
      if speed,
        if speed > maxss$, speed = maxss$
        if speed < min_speed, speed = min_speed
      spdir2 = fsg3(spdir$)
pq$              #Setup post based on switch settings
      stagetool = bldnxtool$  #Set stagetool from CD setting
      result = newfs(11, cdelta_calc)  #Format for 3 place precision
ptoolend$        #End of tool path, before reading new tool data
      !speed, !spdir2
ptlchg1002$      #Call at actual toolchange, end last path here
      if op_id$ <> prv_op_id$, pset_mach   #Set rotary switches by reading machine def parameters
      if cuttype <> one, sav_rev = rev #Axis Sub does not update to rev
      pspindle
      whatline$ = four #Required for vector toolpaths
      if gcode$ = 1000,
        #Null toolchange
      else,
        #Toolchange and Start of file
        if gcode$ = 1002,
          #Actual toolchange
          pretract
        if stagetool = one, prv_next_tool$ = m_one
        prv_xia = vequ(xh$)
        prv_feed = c9k
      !op_id$
#endregion
#region Motion output
# Motion NC output
#region NC output postblocks
#The variables for absolute output are xabs, yabs, zabs.
#The variables for incremental output are xinc, yinc, zinc.
prapidout       #Output to NC of linear movement - rapid
      pcan1, pbld, n$, [if gcode$, `sgfeed], sgplane, `sgcode, sgabsinc, pccdia,
        pxout, pyout, pzout, pcout, [if gcode$, `feed], strcantext, pscool, e$
      #Modify following line to customize output for high-speed toolpath
      #tool inspection/change points
      if rpd_typ$ = 7, pbld, n$, "M00", "(TOOL INSPECTION POINT - POST CUSTOMIZATION REQUIRED)", e$
plinout         #Output to NC of linear movement - feed
      pcan1, pbld, n$, sgfeed, sgplane, `sgcode, sgabsinc, pccdia,
        pxout, pyout, pzout, pcout, feed, strcantext, pscool, e$
pcirout         #Output to NC of circular interpolation
      pcan1, pbld, n$, `sgfeed, sgplane, sgcode, sgabsinc, pccdia,
        pxout, pyout, pzout, pcout, parc, feed, strcantext, pscool, e$
#endregion
#region Motion preparation routines
pcom_moveb      #Common motion preparation routines, before
      pxyzcout
      ps_inc_calc
pncoutput       #Movement output
      pcom_moveb
      comment$
      pcan
      if mr_rt_actv,
        !cabs, !cinc #No rotary in sub
      else,
        if cuttype = zero, ppos_cax_lin #Toolplane rotary positioning
      if gcode$ = zero, prapidout
      if gcode$ > one & gcode$ < four, pcirout
      if mr_rt_rst, #Restore absolute/incremental for G51/G68
        mr_rt_rst = zero
      pcom_movea
pcom_movea      #Common motion preparation routines, after
      pcan2
      pe_inc_calc
pdwl_spd$        #Call from NCI gcode 4
      pspindle
      comment$
      pspindchng
      pcan
      if fmtrnd(dwell$), pcan1, pbld, n$, *sgcode, *dwell$, strcantext, e$
      else, pcan1, pbld, n$, strcantext, e$
      pcan2
prapid$          #Output to NC of linear movement - rapid
      pncoutput
pzrapid$         #Output to NC of linear movement - rapid Z only
      pncoutput
plin$            #Output to NC of linear movement - feed
      pncoutput
pz$              #Output to NC of linear movement - feed Z only
      pncoutput
pmx$             #Output to NC of vector NCI
      pncoutput
pcir$            #Output to NC of circular interpolation
      pncoutput
#Pre-process rotary motion control flags
pmx0$            #5 axis gcode setup
      if drillcur$ = zero,
        if fr$ = -2, gcode$ = zero
        else, gcode$ = one
plin0$           #Linear movement, mill motion test
      pmotion_su
pcir0$           #Circular interpolation, mill arc motion test
      pmotion_su
#endregion
#region Motion output components
# Motion output components
pbld            #Canned text - block delete
      if bld, '/'
pfbld           #Force - block delete
pccdia          #Cutter Compensation
      #Force Dxx#
      if prv_cc_pos$ <> cc_pos$ & cc_pos$, prv_tloffno$ = c9k
      sccomp
      if cc_pos$, tloffno$
pscool          #Coolant output
      scoolant   #Old style coolant - based on NCI variable "coolant$"
      pcan1_cool #X style coolant - based on Canned Text coolant
pfxout          #Force X axis output
      if absinc$ = zero, *xabs, !xinc
      else, *xinc, !xabs
pxout           #X output
      if absinc$ = zero, xabs, !xinc
      else, xinc, !xabs
pfyout          #Force Y axis output
      if absinc$ = zero, *yabs, !yinc
      else, *yinc, !yabs
pyout           #Y output
      if absinc$ = zero, yabs, !yinc
      else, yinc, !yabs
pfzout          #Force Z axis output
      if absinc$ = zero, *zabs, !zinc
      else, *zinc, !zabs
pzout           #Z output
      if absinc$ = zero, zabs, !zinc
      else, zinc, !zabs
pfcout          #Force C axis output
      if index = zero & rot_on_x,
        if use_rotmcode & cabs <> prv_cabs, *sindx_mc
        if absinc$ = zero, *cabs, !cinc
        else, *cinc, !cabs
pcout           #C axis output
        if absinc$ = zero, cabs, !cinc
        else, cinc, !cabs
pindex          #Index output
      if index & rot_on_x,
        if (prv_indx_out <> fmtrnd(indx_out)) | (prv_cabs <> fmtrnd(cabs)),
          if use_rot_lock, prot_unlock
          pbld, n$, [if use_rotmcode, `sindx_mc], *indx_out, e$
          !cabs, !cinc
        if use_rot_lock, prot_lock
prot_unlock     #Unlock Rotary axis
      rot_locked = zero
      pbld, n$, srot_lock, e$
prot_lock       #Lock Rotary axis
      if nextop$ <> 1003,
        rot_locked = one
parc            #Select the arc output
      if (plane$ = zero & (arctype$ = one | arctype$ = four)) |   #XY Plane
        (plane$ = one & (arctypeyz$ = one | arctypeyz$ = four)) | #YZ Plane
        (plane$ = two & (arctypexz$ = one | arctypexz$ = four)),  #XZ Plane
        result = newfs(two, iout)
        result = newfs(two, jout)
        result = newfs(two, kout)
      else,
        result = newfs(three, iout)
        result = newfs(three, jout)
        result = newfs(three, kout)
      if (plane$ = 0 & arctype$ < five) | (plane$ = 1 & arctypeyz$ < five) |
        (plane$ = 2 & arctypexz$ < five) | full_arc_flg$ | arc_pitch$,
        #Arc output for IJK
        # If you do NOT want to force out the I,J,K values,
        # remove the "*" asterisks on the *i, *j, *k 's below...
        if plane$ = zero, *iout, *jout, kout #XY plane code - G17
        if plane$ = one, iout, *jout, *kout  #YZ plane code - G19
        if plane$ = two, *iout, jout, *kout  #XZ plane code - G18
        !i$, !j$, !k$
      else,
        #Arc output for R
        if abs(sweep$)<=180 | (plane$ = 0 & arctype$ = five) | (plane$ = 1 & arctypeyz$ = five) |
          (plane$ = 2 & arctypexz$ = five), result = nwadrs(srad, arcrad$)
        else, result = nwadrs(srminus, arcrad$)
        *arcrad$
ppos_cax_lin    #Position the rotary axis before move - rapid
      if index, pindex
      else,
        if fmtrnd(prv_cabs) <> fmtrnd(cabs) & rot_on_x,
          sav_gcode = gcode$
          gcode$ = zero
          pbld, n$, [if gcode$, sgfeed], sgcode, pcout, [if gcode$, feed], e$
          !cia
          ps_cinc_calc
          gcode$ = sav_gcode
#endregion
#End of Motion output region
#endregion
#region Drilling
#region Canned drill cycles, pre-process, first hole
# Drilling
pdrill0$         #Pre-process before drill call
      sav_dgcode = gcode$ #Capture gcode for 5 axis drill
pdrlcommonb     #Canned Drill Cycle common call, before
      if initht$ <> refht$, drillref = zero
      else, drillref = one
      if sav_dgcode = 81,
        result = newfs(two, zinc)
        if drillcyc$ = three | drillcyc$ = 7, drlgsel = fsg1(-ss$) + drillcyc$ * two
        else, drlgsel = fsg2(dwell$) + drillcyc$ * two
        prv_refht_a = c9k
        prv_refht_i = c9k
        prv_dwell$ = zero
        prv_shftdrl$ = zero
      if cuttype = three, sav_dgcode = gcode$
      else, z$ = depth$
      if cuttype = one, prv_zia = refht$ + (rotdia$/two)
      else, prv_zia = refht$
      pcom_moveb
      feed = fr_pos$
      comment$
      pcan
      #5 axis must map the true Z, correct Z calculation here
      if cuttype = three,
        prv_zia = zabs + (-depth$) + refht$
        zia = fmtrnd(zabs)
        zinc = zia - prv_zia
prdrlout        #R drill position
      if cuttype = one, refht_a = refht$ + (rotdia$ / two)
      else, refht_a = refht$
      refht_i = refht$ - initht$
      if cuttype = three, refht_a = w$
      if absinc$ = zero, refht_a, !refht_i
      else, refht_i, !refht_a
pdrill$          #Canned Drill Cycle
      pdrlcommonb
      pcan1, pbld, n$, *sgdrlref, *sgdrill, pxout, pyout, pfzout, pcout,
        prdrlout, dwell$, *feed, strcantext, e$
      pcom_movea
ppeck$           #Canned Peck Drill Cycle
      pdrlcommonb
        prdrlout, *peck1$, *feed, strcantext, e$
      pcom_movea
pchpbrk$         #Canned Chip Break Cycle
      pdrlcommonb
      pcom_movea
ptap$            #Canned Tap Cycle
      pdrlcommonb
      result = newfs(17, feed)  # Set for tapping Feedrate format
      if met_tool$,
        if toolismetric, pitch = n_tap_thds$  #Metric NC Code - Metric Tap
        else, pitch = (1/n_tap_thds$) * 25.4  #Metric NC Code - English Tap
      else,
        if toolismetric, pitch = n_tap_thds$ * (1/25.4)  #English NC Code - Metric Tap
        else, pitch = 1/n_tap_thds$           #English NC Code - English Tap
      pitch = pitch * speed #Force Units Per Minute for regular Tap cycle
      pbld, n$, sg94, e$
        prdrlout, *pitch, !feed, strcantext, e$
      pcom_movea
pbore1$          #Canned Bore #1 Cycle
      pdrlcommonb
      pcom_movea
pbore2$          #Canned Bore #2 Cycle
      pdrlcommonb
        prdrlout, *feed, strcantext, e$
      pcom_movea
pmisc1$          #Canned Fine Bore (shift) Cycle
      pdrlcommonb
        prdrlout, shftdrl$, dwell$, *feed, strcantext, e$
      pcom_movea
pmisc2$          #Canned Rigid Tapping Cycle
      pdrlcommonb
      #RH/LH based on spindle direction
      if met_tool$,
      else,
      if tap_feedtype = 0,
        pbld, n$, sg94, e$
      else, pbld, n$, sg95, e$
      pbld, n$, sm29, *speed, e$
      pcom_movea
#endregion
#region Custom drill cycles (cycles 8-19), first hole
pdrlcst$         #Custom drill cycles 8 - 19 (user option)
      #Use this postblock to customize drilling cycles 8 - 19
      if drillcyc$ = 8, pdrlcst8
      else,
        pdrlcommonb
        sopen_prn, "CUSTOMIZABLE DRILL CYCLE - NOT CONFIGURED - FIRST HOLE", sclose_prn, e$
        pcom_movea
pdrlcst8         #Custom drill cycle 8 - example custom cycle
      pdrlcommonb
      sopen_prn, "CUSTOMIZABLE DRILL CYCLE EXAMPLE - FIRST HOLE", sclose_prn, e$
      pcom_movea
#endregion
#region Canned drill cycles (additional holes)
# Additional Holes
pdrill_2$        #Canned Drill Cycle, additional points
      pdrlcommonb
      pcan1, pbld, n$, pxout, pyout, pzout, pcout, prdrlout, feed, strcantext, e$
      pcom_movea
ppeck_2$         #Canned Peck Drill Cycle
      pdrill_2$
pchpbrk_2$       #Canned Chip Break Cycle
      pdrill_2$
ptap_2$          #Canned Tap Cycle
      pdrill_2$
pbore1_2$        #Canned Bore #1 Cycle
      pdrill_2$
pbore2_2$        #Canned Bore #2 Cycle
      pdrill_2$
pmisc1_2$        #Canned Fine Bore (shift) Cycle
      pdrill_2$
pmisc2_2$        #Canned Rigid Tapping Cycle
      pdrlcommonb
      pcan1, pbld, n$, pxout, pyout, pzout, pcout, prdrlout, strcantext, e$
      pcom_movea
#endregion
#region Custom drill cycles (cycles 8-19), additional holes
pdrlcst_2$       #Custom drill cycles 8 - 19, additional points (user option)
      if drillcyc$ = 8, pdrlcst8_2
      else,
        sopen_prn, "CUSTOMIZABLE DRILL CYCLE - NOT CONFIGURED - NEXT HOLE", sclose_prn, e$
        pdrill_2$
pdrlcst8_2       #Custom drill cycle 8 - example custom cycle
      sopen_prn, "CUSTOMIZABLE DRILL CYCLE EXAMPLE - NEXT HOLE", sclose_prn, e$
      pdrill_2$
#endregion
#region Cancel canned drill cycle
pcanceldc$       #Cancel canned drill cycle
      result = newfs(three, zinc)
      z$ = initht$
      if cuttype = one, prv_zia = initht$ + (rotdia$/two)
      else, prv_zia = initht$
      pxyzcout
      !zabs, !zinc
      prv_gcode$ = zero
      pcan
      pcan1, pbld, n$, sg80, strcantext, e$
      if (drillcyc$ = 3 | drillcyc$ = 7) & tap_feedtype, pbld, n$, sg94, e$
      pcan2
#endregion
#end of Drilling region
#endregion
#region Subprograms
#Subprogram postblocks
#sub_trnstyp - 0=mirror, 1=rotate, 2=scale, 3=translate
#sub_trnmthd (mirror) - 0=X axis, 1=Y axis, 2=line
#sub_trnmthd (rotate) - 0=tplane, 1=tplane origin only, 2=coordinates
psub_call_m$     #Call to main level, single tool
      psub_call_trans
psub_call_mm$    #Call to main level, multiple tools
      psub_call_trans
psub_call_trans #Translate level calls from toolchange, user
      if mi1$ <= one, result = mprint(shomeserror)
      pindex
      #Mirror or Rotate Coord's
      if sub_trnstyp$ = zero, mr_rt_actv = three  #Mirror
      if mr_rt_actv,
          #The original pattern is not mirrored
          if sub_chn_no$ <> one,
            absinc$ = zero
            psub_mirror
        else,
          #The original pattern is not rotated, calculate the rotation incremental angle for G68
          rt_csav = atan2(sub_m2$, sub_m1$)
          if sub_sec_no$,
            rt_cinc = prv_rt_csav - rt_csav
            while rt_cinc > 180, rt_cinc = rt_cinc - 360
            while rt_cinc < -180, rt_cinc = rt_cinc + 360
            if rot_ccw_pos = one, rt_cinc = -rt_cinc
            !rt_csav
            absinc$ = zero
            psub_rotate
          else,
            !rt_csav
        #Set restore flag and sign mr_rt_actv to indicate active
        mr_rt_rst = one
        mr_rt_actv = -abs(mr_rt_actv)
      else, #Translate all, Rotate toolplane
        if sub_mny_t$,
          pbld, n$, [if gcode$, *sgfeed], *sgcode, *sgabsinc, pwcs, pfxout, pfyout, pfzout, pfcout, [if gcode$, *feed], e$
          pe_inc_calc
          ps_inc_calc
      result = nwadrs(strp, main_prg_no$)
      if progno$ = main_prg_no$, result = mprint(sprgnerror)
      pbld, n$, "M98", *main_prg_no$, e$
      prv_feed = c9k #Force feed in sub
psub_mirror     #Mirror start code, user
      #Mirror Y axis
      if sub_trnmthd$, pbld, n$, *sgabsinc, strns_mir_on, *sub_trnsx$, e$
      #Mirror X axis
      else, pbld, n$, *sgabsinc, strns_mir_on, *sub_trnsy$, e$
psub_rotate     #Rotate start code, user
      pbld, n$, [if gcode$, *sgfeed], *sgcode, *sgabsinc, strns_rot_on, *sub_trnsx$, *sub_trnsy$,
        [absinc$ = one], *sgabsinc, *rt_cinc, [if gcode$, *feed], e$
psub_st_m$       #Header in main level
      result = nwadrs(stro, main_prg_no$)
      if first_sub & subs_before, first_sub = zero #suppress blank line before first sub with subs before main
      else, " ", e$
      *main_prg_no$, e$
      #G51/G68 requires absolute position on first move
      if mr_rt_rst,
        if absinc$ = one,
          absinc$ = zero
          prv_absinc$ = m_one
          prv_xabs = m_one
          prv_yabs = m_one
      else, pbld, n$, sgabsinc, e$
psub_end_m$      #End in main level
      n$, "M99", e$
      prv_absinc$ = m_one
      #Reset update variables for subs at main level
      #Mirror or Rotate cancel, flagged cleared on return
      if mr_rt_actv,
        subout$ = zero
        no_nc_out$ = m_one
          #The original pattern is not cancelled
            absinc$ = zero
            pbld, n$, *sgabsinc, strns_mir_off, *sub_trnsx$, *sub_trnsy$, e$
        else, #Rotate
          if sub_trnstyp$ = one & sub_trnmthd$ = two & esub_sec_no$,
            absinc$ = zero
            pbld, n$, strns_rot_off, e$
        no_nc_out$ = zero
        mr_rt_rst = zero
        mr_rt_actv = zero
      end_sub_mny = sub_mny_t$
psub_end_mny    #End in main level for many tools sub, user
      #Check for coming out of xform with stage tool.
      if end_sub_mny & stagetool = one,
        *t$
        end_sub_mny = zero
psub_call_s$     #Call to sub level
      result = nwadrs(strp, sub_prg_no$)
      sub_prg_no$ = sub_prg_no$ + 1000 #Add sub number offset
      if progno$ = sub_prg_no$, result = mprint(sprgnerror)
      pbld, n$, "M98", *sub_prg_no$, e$
psub_st_s$       #Header in sub leveln
      result = nwadrs(stro, sub_prg_no$)
      else, " ", e$
      *sub_prg_no$, e$
psub_end_s$      #End in sub level
      n$, "M99", e$
      prv_absinc$ = -1
#endregion
#region Canned text
# Canned Text
pcan            #Canned text - before output call
      strcantext = sblank
      if cant_no$ > zero,
        if cant_pos1$ = zero | cant_pos1$ = three, pcant_1
        if cant_pos2$ = zero | cant_pos2$ = three, pcant_2
        if cant_pos3$ = zero | cant_pos3$ = three, pcant_3
        if cant_pos4$ = zero | cant_pos4$ = three, pcant_4
        if cant_pos5$ = zero | cant_pos5$ = three, pcant_5
        if cant_pos6$ = zero | cant_pos6$ = three, pcant_6
        if cant_pos7$ = zero | cant_pos7$ = three, pcant_7
        if cant_pos8$ = zero | cant_pos8$ = three, pcant_8
        if cant_pos9$ = zero | cant_pos9$ = three, pcant_9
        if cant_pos10$ = zero | cant_pos10$ = three, pcant_10
        if cant_pos11$ = zero | cant_pos11$ = three, pcant_11
        if cant_pos12$ = zero | cant_pos12$ = three, pcant_12
        if cant_pos13$ = zero | cant_pos13$ = three, pcant_13
        if cant_pos14$ = zero | cant_pos14$ = three, pcant_14
        if cant_pos15$ = zero | cant_pos15$ = three, pcant_15
        if cant_pos16$ = zero | cant_pos16$ = three, pcant_16
        if cant_pos17$ = zero | cant_pos17$ = three, pcant_17
        if cant_pos18$ = zero | cant_pos18$ = three, pcant_18
        if cant_pos19$ = zero | cant_pos19$ = three, pcant_19
        if cant_pos20$ = zero | cant_pos20$ = three, pcant_20
        strcantext = sblank
pcan1           #Canned text - with move
      strcantext = sblank
      if cant_no$ > zero,
        if cant_pos1$  = one, pcant_1
        if cant_pos2$  = one, pcant_2
        if cant_pos3$  = one, pcant_3
        if cant_pos4$  = one, pcant_4
        if cant_pos5$  = one, pcant_5
        if cant_pos6$  = one, pcant_6
        if cant_pos7$  = one, pcant_7
        if cant_pos8$  = one, pcant_8
        if cant_pos9$  = one, pcant_9
        if cant_pos10$ = one, pcant_10
        if cant_pos11$ = one, pcant_11
        if cant_pos12$ = one, pcant_12
        if cant_pos13$ = one, pcant_13
        if cant_pos14$ = one, pcant_14
        if cant_pos15$ = one, pcant_15
        if cant_pos16$ = one, pcant_16
        if cant_pos17$ = one, pcant_17
        if cant_pos18$ = one, pcant_18
        if cant_pos19$ = one, pcant_19
        if cant_pos20$ = one, pcant_20
      if cstop$, strcantext = strcantext + sm00
      if cgstop$, strcantext = strcantext + sm01
      #Output of strcantext occurs at the end of the output line
pcan1_cool      #Canned text Coolant - with move
      if cant_no$ > zero,
        if cant_pos1$  = four, pcant_1
        if cant_pos2$  = four, pcant_2
        if cant_pos3$  = four, pcant_3
        if cant_pos4$  = four, pcant_4
        if cant_pos5$  = four, pcant_5
        if cant_pos6$  = four, pcant_6
        if cant_pos7$  = four, pcant_7
        if cant_pos8$  = four, pcant_8
        if cant_pos9$  = four, pcant_9
        if cant_pos10$ = four, pcant_10
        if cant_pos11$ = four, pcant_11
        if cant_pos12$ = four, pcant_12
        if cant_pos13$ = four, pcant_13
        if cant_pos14$ = four, pcant_14
        if cant_pos15$ = four, pcant_15
        if cant_pos16$ = four, pcant_16
        if cant_pos17$ = four, pcant_17
        if cant_pos18$ = four, pcant_18
        if cant_pos19$ = four, pcant_19
        if cant_pos20$ = four, pcant_20
pcan2           #Canned text - after output call
      strcantext = sblank
      if cant_no$ > zero,
        if cant_pos1$ = two | cant_pos1$ = five, pcant_1
        if cant_pos2$ = two | cant_pos2$ = five, pcant_2
        if cant_pos3$ = two | cant_pos3$ = five, pcant_3
        if cant_pos4$ = two | cant_pos4$ = five, pcant_4
        if cant_pos5$ = two | cant_pos5$ = five, pcant_5
        if cant_pos6$ = two | cant_pos6$ = five, pcant_6
        if cant_pos7$ = two | cant_pos7$ = five, pcant_7
        if cant_pos8$ = two | cant_pos8$ = five, pcant_8
        if cant_pos9$ = two | cant_pos9$ = five, pcant_9
        if cant_pos10$ = two | cant_pos10$ = five, pcant_10
        if cant_pos11$ = two | cant_pos11$ = five, pcant_11
        if cant_pos12$ = two | cant_pos12$ = five, pcant_12
        if cant_pos13$ = two | cant_pos13$ = five, pcant_13
        if cant_pos14$ = two | cant_pos14$ = five, pcant_14
        if cant_pos15$ = two | cant_pos15$ = five, pcant_15
        if cant_pos16$ = two | cant_pos16$ = five, pcant_16
        if cant_pos17$ = two | cant_pos17$ = five, pcant_17
        if cant_pos18$ = two | cant_pos18$ = five, pcant_18
        if cant_pos19$ = two | cant_pos19$ = five, pcant_19
        if cant_pos20$ = two | cant_pos20$ = five, pcant_20
        strcantext = sblank
pcant_1         #Canned text - output call
      cant_pos = cant_pos1$
      cantext$ = cant_val1$
      pcant_out
pcant_2         #Canned text - output call
      cant_pos = cant_pos2$
      cantext$ = cant_val2$
      pcant_out
pcant_3         #Canned text - output call
      cant_pos = cant_pos3$
      cantext$ = cant_val3$
      pcant_out
pcant_4         #Canned text - output call
      cant_pos = cant_pos4$
      cantext$ = cant_val4$
      pcant_out
pcant_5         #Canned text - output call
      cant_pos = cant_pos5$
      cantext$ = cant_val5$
      pcant_out
pcant_6         #Canned text - output call
      cant_pos = cant_pos6$
      cantext$ = cant_val6$
      pcant_out
pcant_7         #Canned text - output call
      cant_pos = cant_pos7$
      cantext$ = cant_val7$
      pcant_out
pcant_8         #Canned text - output call
      cant_pos = cant_pos8$
      cantext$ = cant_val8$
      pcant_out
pcant_9         #Canned text - output call
      cant_pos = cant_pos9$
      cantext$ = cant_val9$
      pcant_out
pcant_10        #Canned text - output call
      cant_pos = cant_pos10$
      cantext$ = cant_val10$
      pcant_out
pcant_11        #Canned text - output call
      cant_pos = cant_pos11$
      cantext$ = cant_val11$
      pcant_out
pcant_12        #Canned text - output call
      cant_pos = cant_pos12$
      cantext$ = cant_val12$
      pcant_out
pcant_13        #Canned text - output call
      cant_pos = cant_pos13$
      cantext$ = cant_val13$
      pcant_out
pcant_14        #Canned text - output call
      cant_pos = cant_pos14$
      cantext$ = cant_val14$
      pcant_out
pcant_15        #Canned text - output call
      cant_pos = cant_pos15$
      cantext$ = cant_val15$
      pcant_out
pcant_16        #Canned text - output call
      cant_pos = cant_pos16$
      cantext$ = cant_val16$
      pcant_out
pcant_17        #Canned text - output call
      cant_pos = cant_pos17$
      cantext$ = cant_val17$
      pcant_out
pcant_18        #Canned text - output call
      cant_pos = cant_pos18$
      cantext$ = cant_val18$
      pcant_out
pcant_19        #Canned text - output call
      cant_pos = cant_pos19$
      cantext$ = cant_val19$
      pcant_out
pcant_20        #Canned text - output call
      cant_pos = cant_pos20$
      cantext$ = cant_val20$
      pcant_out
pcant_out       #Canned text - build the string for output
      #Assign string select type outputs
      if cant_pos < three, #cant_pos indicates canned text output
        if cantext$ = three, bld = one
        if cantext$ = four, bld = zero
        #Build the cantext string
        if cantext$ = one, strcantext = strcantext + sm00
        if cantext$ = two, strcantext = strcantext + sm01
        if cantext$ > four,
          strtextno = no2str(cantext$)
          strcantext = strcantext + strm + strtextno
      else, #cant_pos indicates coolant output
        coolant_bin = flook (two, cantext$) #Create binary value for each coolant using lookup table
        if frac(cantext$/two),  # coolant off
          if all_cool_off,
            coolant_on = zero
          else,
            if coolant_on > 0,
              coolant_on = coolant_on - coolant_bin/2 #Odd = off command, subtract appropriate binary value.
              coolantx = cantext$ - 50                #Create a coolantx value for string select
              pbld, n$, *scoolantx, e$
        else,                                         #Even = on command
          [   #Determine if this coolant is already on
          local_int = zero
          coolantx = zero
          suppress = zero
            result2 = and(2^local_int, coolant_on)
            if result2 = coolant_bin, suppress = one
          if suppress <> 1, #Don't output an on code for a coolant that is already on
            coolant_on = coolant_on + coolant_bin #Maintain binary sum of all coolants currently on
            if cant_pos = four, *scoolantx        #Coolant "With"
            else, pbld, n$, *scoolantx, e$        #Coolant "Before" or "After"
#endregion
#region Calculations
#region Position calculations
# Position calculations, generally these do not need to be modified
pmiscint$        #Capture the top level absinc for subprograms
      if sub_level$ <= zero, absinc$ = mi2$
      #Disable cutpos2 if not 4 axis, saves time
      if rot_on_x = zero, cutpos2$ = m_one
pmotion_su      #Motion Setup (Set brklinestype & linarc)
      brklinestype$ = zero
      linarc$ = zero
      if rot_on_x,
        if cuttype = one,  #Axis Substitution
          linarc$ = one  #Linearize all arcs
          if rev_brkflag,  #Break rotation flag (set in pcoutrev)
            brklinestype$ = 11  #Break all lines, use brklineslen$ for segment length
            #brklineslen$ = pi$ * rotdia$        #Break every 360 degrees
            brklineslen$ = pi$ * rotdia$ / four  #Break every 90 degrees
            rev_brkflag = zero  #Reset flag
        if cuttype = two, #Polar
          brklinestype$ = rotary_axis$ + three
          linarc$ = one
pcuttype   #Determine the cut type
      #cuttype (0 = Tool Plane, 1 = Axis Subs,  2 = Polar, 3 = 4/5 axis)
      cuttype = rotary_type$
      if cuttype = three, cuttype = zero
      if mill5$, cuttype = three
      if cuttype = zero & force_index, index = 1  #If tool plane positioning & force index mode
      else, index = rot_index                     #otherwise use machine def. rotary axis setting
      #Check for Tool Origin in Polar Milling
      if cuttype = two & (tox$ | toy$ | toz$), result = mprint(stlorgerr)
      #Avoid calling G51/G68 with additional toolchanges
      if mr_rt_actv = zero,
        #Transform Rotate, set mr_rt_actv if user selected 'coordinates'
        #Mirror is set on sub call
        if sub_trnstyp$ = one & sub_trnmthd$ = two,
          if sub_sec_no$, mr_rt_actv = two
          else, mr_rt_actv = one
      pfcalc_u_min
      pmotion_su
pcheckaxis      #Check for valid rotary axis
      #If selected axis combination has more than 1 rotary axis and toolpath has rotation
      if (cabs | cdelta | cuttype) & rotaxerror = 1, [if mprint(srotaxerror, 2) = 2, exitpost$]
      #If machine's defined axis of rotation does not match operations axis of rotation
#      if (rotary_axis$ & (rotary_axis$ <> rot_on_x)) | (rotary_axis2 <> c9k &
#        ((rotary_axis2 + 1) <> rot_on_x)), [if mprint(saxiserror, 2) = 2, exitpost$]
#      rotary_axis2 = c9k
pxyzcout        #Map coordinates
      if rot_on_x,
        if cuttype = zero, pxyzcout0    #Toolplane Positioning
        if cuttype = one, pxyzcout1     #Axis Substitution
        if cuttype = two, pxyzcout2     #Polar Conversion
        if cuttype = three, pxyzcout3   #Simulatneous 4 axis (Multi-axis)
        if rot_ccw_pos = one, csav = -csav
        if mr_rt_actv <> two,
          pcoutrev
          if index, pindxcalc
          pfcalc
        else, feed = fr_pos$
      else,
        xabs = vequ(x$)
        iout = vequ(i$)
        feed = fr_pos$
      xabs = vequ(x$)
      iout = vequ(i$)
      if rot_on_x = two, csav = -c$
      else, csav = c$
pxyzcout1       #Axis substitution
      if rot_on_x = one, #X axis substitution
        xabs = x$
        yabs = zero
        zabs = z$ + (rotdia$ / two)
        csav =  y$ * (360 / (pi$ * rotdia$))
      else, #Y axis substitution
        xabs = zero
        yabs = y$
        csav =  x$ * (360 / (pi$ * rotdia$))
      #Reverse direction if needed
      if (rot_ccw_pos = 0 & rotaxis_dir$ = 1) | (rot_ccw_pos = 1 & rotaxis_dir$ = 0), csav = -csav
pxyzcout2       #polar interpolation
      #Drill polar is toolplane drilling toward center
      #if not a coincident axis
      #Also, Capture initial index position for Polar Milling
      if (opcode$ = three & rot_on_x <> three), pxyzcout0
      else,
        if rot_on_x = one, #X axis rotation
          csav = atan2(y$, z$)   #Z+ zero
          axisx$ = vequ(aaxisx)
          xabs = rotp(csav, x$)
        if rot_on_x = two, #Y axis rotation
          csav = atan2(-x$, z$)   #Z+ zero
          axisx$ = vequ(baxisx)
        if rot_on_x = three, #Z axis rotation
          csav = atan2(-y$, x$)   #X+ zero
          axisx$ = vequ(caxisx)
        csav = csav + c$
pxyzcout3       #Multisurf rotary axis motion
      if rot_on_x = one, #Multisurf Rotary about X
        csav = atan2 (vtooly$, vtoolz$)
        axisx$ = vequ (aaxisx)
      if rot_on_x = two, #Multisurf Rotary about Y
        csav = atan2 (-vtoolx$, vtoolz$)
        axisx$ = vequ (baxisx)
      xabs = rotp (csav, x$)
      u$ = rotp (csav, u$)
      csav = csav + c$
#endregion
#region Rotary axis revolution / index calculations
pcoutrev        #Rotary axis revolution calculation (Modify for wind-up)
      cdelta = csav - prv_csav
      if cuttype = one & rot_type > zero & not(index) & toolchng = zero & toolchng0 = zero,  #Axis sub and signed direction or shortesat direction
        cdelta_calc = abs(cdelta)
        cdelta_calc = fmtrnd(cdelta_calc)
        if cdelta_calc > 360,  #Break rotary motion
          rev_brkflag = one  #Break every 90 or 360 degrees (see plin0$)
          redo_proc$  #Reprocess NCI line
      while abs(cdelta) > ctol, #If motion exceeds ctol, add wind-up
        if cdelta > zero,
          rev = rev - one
          cdelta = cdelta - 360
        else,
          rev = rev + one
          cdelta = cdelta + 360
      if cuttype <> one, cabs = rev * 360 + csav
      else, cabs = sav_rev * 360 + csav
      !csav
      if index <> 1 & rot_type > 0,  #Signed absolute output or shortest direction
        #Keep tablebetween 0 - 360
        while cabs < 0 & absinc$ <> 1, cabs = cabs + 360
        while cabs > 360 & absinc$ <> 1, cabs = cabs - 360
        # Calc signed direction.  Not sure why I need to flop indx_mc
        #Phase shift delta 10 revolutions, check odd/even
        if frac(int((cdelta + 3600)/180)/two), indx_mc = zero   #indx_mc = one
        else, indx_mc = one                         #indx_mc = zero
        if cdelta < 0, indx_mc = zero
        else, indx_mc = one
      if rot_type = 1, pset_rot_label_sign  #Set rotary axis label with sign
      else, pset_rot_label  #Set rotary axis label
pindxcalc       #Index move calculations, direction is shortest
      #Check if in tolerance when not full rotary
      #ie. rotary has been defined as an indexer or force_index is yes$
      if rot_index = one,
        cdelta = frac(abs(csav)/ctable)
        if cdelta > ixtol & cdelta < 1-ixtol, result = mprint(sindxerror)
      cdelta = prvcabs - cabs
      if frac(int((cdelta + 3600)/180)/two), indx_mc = one
      else, indx_mc = zero
      #Set range 0-360
      indx_out = csav
      while indx_out < 0, indx_out = indx_out + 360
      while indx_out > 360, indx_out = indx_out - 360
#endregion
#region Set rotary axis label and sign
      if not(use_md_rot_label),
        if rot_on_x = 1, srot_label = srot_x  #Rotating about X axis
        if rot_on_x = 2, srot_label = srot_y  #Rotating about Y axis
        if rot_on_x = 3,
          if vmc, srot_label = srot_z  #Rotating about Z axis - vertical machine
          else, srot_label = srot_y  #Rotating about Y axis - horizontal machine
      result = nwadrs(srot_label, cabs)
      result = nwadrs(srot_label, cinc)
      result = nwadrs(srot_label, indx_out)
pset_rot_label_sign  #Set rotary axis label for signed output direction
      if use_md_rot_label,
        if not(use_rotmcode),
          if indx_mc = zero, srot_label = srot_label + sminus
          else, srot_label = sav_srot_label
      else,
          if rot_on_x = 3, srot_label = srot_z  #Rotating about Z axis
#endregion
#region Feedrate calculations
#Feedrate calculations
pconvert_rpd    #Convert rapid motion to linear motion at maximum feedrate when selected in CD
      gcode$ = one
      feed = pst_rpd_fr$
      ipr_type = zero
pfcalc          #Feedrate calculations, gcode 0 does not evaluate
      if gcode$ <> zero,
        if fmtrnd(cabs) = prvcabs | index, pfcalc_u_min
        else,
          if (cuttype = one & (cutpos2$ <= one | cutpos2$ = four)) | rotfeed4$ = 0,
          pfcalc_u_min
          else, pfclc_deg_inv
        if ipr_type <> prv_ipr_type, prv_feed = c9k
pfcalc_u_min    #Feedrate unit/min
      ipr_type = zero
      feed = fr_pos$
      if feed > maxfeedpm, feed = maxfeedpm
      prvfrdeg = feed
pfclc_deg_inv   #Feedrate deg/min
      circum = zabs * two * pi$
      if circum = zero, circum = c9k          #Don't allow Zero
      ldelta = sqrt((xabs-prv_xabs)^2+(yabs-prv_yabs)^2+(zabs-prv_zabs)^2)
      cdelta = ((abs(cabs - prvcabs))/360)*circum
      if ldelta = zero, cldelta = cdelta
      else, cldelta = sqrt(cdelta^two + ldelta^two)
      if cldelta = zero, cldelta = c9k
      #Set rotary feedrate type from CD variable
      if rotfeed4$ = 2, use_frinv = yes$ #Use inverse time feedrate is set in CD
      else, use_frinv = no$             #Or not...
      if use_frinv,
        #Feedrate inverse calculation
        ipr_type = two
        prv_feed = c9k #Always force feed
        if cuttype = three, cldelta = sqrt((x$-prv_x$)^2+(y$-prv_y$)^2+(z$-prv_z$)^2)
        if inversefeed$,  #Feedrate in seconds
          frinv = (fr_pos$*(1/60))/cldelta
          if frinv > (maxfrinv/60), frinv = (maxfrinv/60)
        else,  #Feedrate in minutes
          frinv = fr_pos$/cldelta
          if frinv > maxfrinv, frinv = maxfrinv
        feed = frinv
      else,
        #Feedrate deg/min control and calculation
        ipr_type = zero  #Change to ipr_type = one to force new DPM
        frdeg = abs(cdelta/cldelta) * abs(fr_pos$ * (360/circum))
        if abs(frdeg - prvfrdeg) > frdegstp | ipr_type <> prv_ipr_type,
          #Control output of frdeg
          prvfrdeg = frdeg
          feed = frdeg
        if frdeg > maxfrdeg, feed = maxfrdeg
#endregion
#region Incremental calculations
#Incremental calculations
ps_inc_calc     #Incremental calculations, start
      xia = fmtrnd(xabs)
      yia = fmtrnd(yabs)
      zia = fmtrnd(zabs)
      xinc = vsub (xia, prv_xia)
      ps_cinc_calc
ps_cinc_calc    #Incremental calculations, start rotary
      cia = fmtrnd(cabs)
      cinc = cia - prv_cia
pe_inc_calc     #Incremental calculations, end
      prvcabs = fmtrnd(cabs) #Avoid updating until called explicitly
      !xia, !yia, !zia, !cia
      !x$, !y$, !z$, !cc_pos$, !cutpos2$
#endregion
#end of Calculations region
#endregion
#region Parameter read postblocks, parameter tables
# Parameter read postblocks:
pprep$          #Pre-process postblock - Allows post instructions after the post is parsed but before the NC and NCI file are opened.
#DO NOT ATTEMPT TO OUTPUT TO THE NC FILE IN THIS POSTBLOCK (OR ANY POSTBLOCKS YOU MAY CALL FROM HERE) BECAUSE THE NC OUTPUT FILE IS NOT YET OPENED!
      sav_index = index  #Save original index value
      rd_cd$             #Read CD Parameters
      rd_mch_ent_no$ = 0 #Read only the machine base parameters (use to collect common parameters from CNC_MACHINE_TYPE)
      rd_md$             #Read machine definition parameters
psynclath$      #Read NCI Axis-Combination (950) line
      #Rotaxtyp = 1 sets initial matrix to top
      #Rotaxtyp = -2 sets initial matrix to front
      if vmc, rotaxtyp$ = one
      else, rotaxtyp$ = -2
pwrtt$          #Pre-read NCI file
      if tool_info > 1 & t$ > 0 & gcode$ <> 1003, ptooltable
pwrttparam$     #Pre-read parameter data
      #"pwrttparam", ~prmcode$, ~sparameter$, e$
      if prmcode$ = 15346, comp_type = rpar(sparameter$, 1) #Cutter compensation type - 0=computer, 1=control, 2=wear, 3=reverse wear, 4=off
      if prmcode$ = 10010, xy_stock = rpar(sparameter$, 1)  #Capture stock to leave (XY)
      if prmcode$ = 10068, z_stock = rpar(sparameter$, 1)   #Capture stock to leave (Z)
pparameter$     #Read operation parameters
      #rd_params is used to call pparameter postblock and read the parameters of the operation specified in rd_param_op_no
      #"pparameter", ~prmcode$, ~sparameter$, e$
      if prmcode$ = 12025, rotary_axis2 = rpar(sparameter$, 1) #Capture the axis of rotation in Multiaxis Drill and Curve 5 Axis
      # Check To See if tool is metric
      if prmcode$ = 20007, toolismetric = rparsngl(sparameter$, 11)
# Parameter lookup tables - You must adjust the size value if you add any parameters to these tables!
# Machine Definition Parameters
fprmtbl 17000   14   #Table Number, Size
#       Param   Variable to load value into
        17391   axis_label   #Axis label - 1=X,2=Y,3=Z
        17397   srot_label   #Rotary Axis label (Generally A, B or C) - Not yet available.
        17401   rot_zero     #Rotary zero degree position
        17402   rot_dir      #Rotary direction
        17408   rot_index    #Index or continuous
        17409   rot_angle    #Index step
        17410   rot_type     #Rotary type
        17605   min_speed    #Minimum spindle speed
        17058   maxfrinv     #Maximum feedrate - inverse time - inch - Minimum value from MD as this is inverse time
        17066   maxfrinv_m   #Maximum feedrate - inverse time - metric - Minimum value from MD as this is inverse time
        17992   maxfrdeg     #Maximum feedrate deg/min
        17055   maxfeedpm    #Limit for feed in inch/min
        17063   maxfeedpm_m  #Limit for feed in mm/min
        17101   all_cool_off #First coolant off command shuts off ALL coolant options
# Control Definition Parameters
fprmtbl 18000   1    #Table Number, Size
        18713   subs_before  #Subprograms output before or after main program
# Toolpath Group Parameters
fprmtbl 19000   0    #Table Number, Size
pset_mach       #Set post switches by reading machine def parameters
      rot_ax_cnt = 0
      rotaxerror = 0
      rot_axis = 0  #Turn off rotary axis unless it is detected in machine read - supresses rotary output in 3 axis machines
      #maxfeedpm = 999999       #Uncomment these variables to force use of machine def values as initial lowest max feedrate value
      #maxfeedpm_m = 9999999    #Otherwise the default (post) initialization setting is used as initial value
      !maxfeedpm, !maxfeedpm_m
      rd_mch_ent_no$ = syncaxis$  #Retrieve machine parameters based on current axis combination - read from .nci G950 line
      if read_md = yes$, rd_md$   #Read machine definition parameters - calls pmachineinfo$
      #We only need these set at toolchange (and start of file).  No need to set them each time a user may call rd_md
      if read_md = yes$, #Override initial post values if reading Machine Definition
        rot_on_x = rot_axis
        rot_ccw_pos = rot_dir
        index = rot_index
        if rot_angle = zero, ctable = one #ctable zero will produce a divide by zero error, so force to one if zero in MD
        else, ctable = rot_angle
        if not(vmc) & rot_on_x = 3, rot_on_x = 2 #If HMC and rotating about world Z axis (machine Y axis)
      else, rot_index = sav_index
      if met_tool$ = 1,
        maxfrinv = maxfrinv_m   #Set limit for feed inverse time
        maxfeedpm = maxfeedpm_m #Set limit for feed in mm/min
      sav_srot_label = srot_label #Backup the original rotary axis label
# Machine definition and control definition parameter capture:
pmachineinfo$   #Machine information parameters postblock
      #rd_md is used to call pmachineinfo postblock and read the parameters of the selected axis
      #combination machine entity set in rd_mch_ent_no
      #rd_cd is used to call pmachineinfo postblock and read the active control definition parameters
      #rd_tlpathgrp is used to call pmachineinfo postblock and read the active toolpath group parameters
      #"-->pmachineinfo", ~prmcode$, "  ", ~sparameter$, e$  #Do not uncomment if being called from pprep$ - see pprep comment
      #Read parameter lookup tables -
      if prmcode$ >= 17000 & prmcode$ < 18000, result = fprm(17000) #Run the parameter table for Machine Definition Parameters
      if prmcode$ >= 18000 & prmcode$ < 19000, result = fprm(18000) #Run the parameter table for Control Definition Parameters
      #Leave line below commented until you enter values in related lookup tables
      #if prmcode$ >= 19000 & prmcode$ < 19900, result = fprm(19000) #Run the parameter table for Toolpath Group Parameters
      #Count rotary axis and output error message if more than one is found in the active axis combination and read_md = yes$
      if prmcode$ = 19958,
        component_type = rpar(sparameter$, 1)  #Component type
        if component_type = 5 & read_md = yes$,
          rot_ax_cnt = rot_ax_cnt + 1  #Rotary component
          if rot_ax_cnt = 2, rotaxerror = rotaxerror + 1   #Post only supports 1 rotary per axis combination
      #Determine Z direction - set vmc
      if prmcode$ = 17392 & axis_label = 3,
        z_dir = rpar(sparameter$, 1)  #Z axis direction - +X=1,+Y=2,+Z=3,-X=7,-Y=8,-Z=9
        if z_dir <> 3 & z_dir <> 9, vmc = 0   #0 = Horizontal Machine, 1 = Vertical Mill
        else, vmc = 1
      #Set axis of rotation for rotary component
      if prmcode$ = 17399,
        rot_axis = rpar(sparameter$, 1)  #Axis of rotation - +X=1,+Y=2,+Z=3,-X=7,-Y=8,-Z=9
        if rot_axis > 3, rot_axis = rot_axis - 6 #Keep value positive (+X,+Y,+Z) for use in rot_on_x
      #Read Linear Axis parameters - capture lowest feedrate value of all linear axis
      if maxfeedpm > prv_maxfeedpm, maxfeedpm = prv_maxfeedpm
      if maxfeedpm_m > prv_maxfeedpm_m, maxfeedpm_m = prv_maxfeedpm_m
#endregion
#region Post text
# Do not add an #endregion tag -- or any other #region tags -- below this line.
# POST TEXT
[CTRL_MILL|MPFAN]
[misc integers]
1. "Work Coordinates [0-1=G92, 2=G54's]"//2
2. "Absolute/Incremental, top level [0=ABS, 1=INC]"
3. "Reference Return [0=G28, 1=G30]"
[simple drill]
1. "Drill/Counterbore"
7. ""
8. ""
9. ""
10. ""
11. ""
[peck drill]
3. ""
7. "Peck"
8. ""
9. ""
10. ""
11. ""
[chip break]
3. ""
7. "Peck"
8. ""
9. ""
10. ""
11. ""
[tap]
3. ""
7. ""
8. ""
9. ""
10. ""
11. ""
[bore1]
1. "Bore #1 (feed-out)"
7. ""
8. ""
9. ""
10. ""
11. ""
[bore2]
1. "Bore #2 (stop spindle, rapid out)"
3. ""
7. ""
8. ""
9. ""
10. ""
11. ""
[misc1]
1. "Fine Bore (shift)"
7. ""
8. ""
9. ""
10. ""
[misc2]
1. "Rigid Tapping Cycle"
3. ""
7. ""
8. ""
9. ""
10. ""
11. ""
[drill cycle descriptions]
7. "Fine bore (shift)"
8. "Rigid Tapping Cycle"
[canned text]
1. "Stop"
2. "Ostop"
3. "Bld on"
4. "bLd off"
5. "M5"
6. "M6"
7. "M7"
8. "M8"
9. "M9"
10. "M10"
[CTRL_MILL|DEFAULT]
[misc integers]
[simple drill]
7. ""
8. ""
9. ""
10. ""
11. ""
[peck drill]
3. ""
7. "Peck"
8. ""
9. ""
10. ""
11. ""
[chip break]
3. ""
7. "Peck"
8. ""
9. ""
10. ""
11. ""
[tap]
3. ""
7. ""
8. ""
9. ""
10. ""
11. ""
[bore1]
7. ""
8. ""
9. ""
10. ""
11. ""
[bore2]
3. ""
7. ""
8. ""
9. ""
10. ""
11. ""
[misc1]
7. ""
8. ""
9. ""
10. ""
[misc2]
3. ""
7. ""
8. ""
9. ""
10. ""
11. ""
[canned text]
1. "Stop"
2. "Ostop"
3. "Bld on"
4. "bLd off"
5. "M5"
6. "M6"
7. "M7"
8. "M8"
9. "M9"
10. "M10"
[CTRL_TEXT_END]
@19_BBB_68
Найдите в посте:
      pxyzcout
Должно быть так:
      pxyzcout
      prv_gcode$ = -1
22.04.2021 в 14:50, 19_BBB_68 сказал:
что изменить в постпроцессоре, что бы коды G2 и G3 повторялись в последующих кадрах.
@hlibhlib Тогда уж и в линейные добавить. Я так понял, что там станок не понимает, когда без G-кода строка.
2 минуты назад, GalielO сказал:
Вопрос касался только Дуг, причем тут линейные?
Подождем ответа.
Если ему нужны дубляжи на все перемещения, то твой вариант подойдет лучше.
6 часов назад, hlibhlib сказал:
У меня была стойка Sinumerik на DOS она не понимала, что G1, G2, G3 заданные в предыдущем кадре действуют на текущий. Приходилось в каждом кадре прописывать.
25.04.2021 в 11:55, hlibhlib сказал:
Подождем ответа.
Спасибо огромное!!!! Всё получилось!!!
Да, мне дублирование нужно было только для дуг.
Еще раз спасибо!!!
доброго времени . и так начну с таких вещей
 голова повторная HSD300D
есть файлы с мастеркама Х6 . перевели на 2020 - пост вроде норм работает а вот станок подправить не могу требует пароль . может кто то поможет с этой проблемой или кто работает с такой же головой можете поделиться постом и станком .
может не в той теме ищю пните ,только не сильно, в нужную тему
что мне надо предоставить для того что б гуру помогли ?
Растолкуйте, кто может , значения этих команд (или переменных, как правильно?)
use_tlength : 1 #Use tool length, read from tool overall length
toollength : 100 #Tool length if not read from overall length
shift_z_pvt : 1 #Shift Z by tool length, head/head program to pivot (Z axis only)
Это настройки длины инструмента (расстояние) от точки вращения до кончика инструмента, как я правильно понимаю. А как правильно настроить так, чтобы длина от оси до кончика гайки бралась с поста , а длину самого инструмента пост брал с параметров фрез в программе MC?
Изменено пользователем marapantera
use_tlength  : 2     #Use tool length, read from tool overall length
                     #0=Use 'toollength' var, 1=Mastercam OAL, 2=Prompt
toollength   : 10    #Tool length if not read from overall length
                     #0=Pivot, 1=Pivot-Z, 2=Tool Tip Programming (without zero length)
                     #Option 2, So we can still take advantage of brk_mv_head feature
17 часов назад, marapantera сказал:
От оси чего? Почему Гайки, а не Чипа или Дейла? У Гайки и кончика то нет. Длину инструмента оператор/наладчик забивает в таблицу коррекции на станке, то что в у Вас забито в МС больше для наглядности.
13 часов назад, GalielO сказал:
Это настройки длины инструмента, точнее расстояние от точки (оси) вращения до кончика инструмента, как я правильно понимаю. Имеется ввиду станок 4 -х осевой, с поворотным шпинделем. https://forumupload.ru/uploads/0009/00/75/5302/t788748.jpg А как правильно настроить так, чтобы расстояние от оси вращения до торца шпинделя бралась с поста,(чтобы это значение забить раз и навсегда), а длину самого инструмента пост брал с параметров фрез в программе MC? Так , надеюсь более понятно?
14 часов назад, GalielO сказал:
Я насчёт этого
  • 2 месяца спустя...
Здравствуйте коллеги.
Станок токарный ТС1720Ф4 2 оси ZX. Стойка Siemens SINUMERIK 828d.
CAM систем Mastercam 2017.
Как переделать компоненты постпроцессора
Было  G3 X60 Z-5. 8 I=(0.) K=(-5.8)
Чтобы стало G3 X60 Z-5. 8 I0 K-5.8
Прошу написать сюда. 10liteuawei@gmail.com
Спасибо большое.
Можно и здесь на форуме оставит ответ!
Доброго времени.
На производстве появился новый станок DMG M1.
Sinumerik 828
Делаю программу в Mastercam 2020 постпроцессор
стандартный Siemens 3x_4x Mill
при винтовой интерполяции G код выдает вот такimage-9.jpg.html
что нужно поменять в постпроцессоре  чтоб выдавало
хотя бы такimage-10.jpg.html , или есть какое то другое решение?
не знаю как добавит картинку
выдает так
MSG(" Op-35 ")
X10.15128 Y-93.85765
Z2.
G1 Z0. F1000.
G41 X.15128 F1145.8
G3 X.15128 Y-93.85765 I11.5 J0.
X15.70153 Y-104.62081 I11.5 J0.
X.15128 Y-93.85765 I-4.05025 J10.76316
G1 G40 X12.17957 Y-95.26154 Z-13.
G0 Z50.
нужно хотя бы так
MSG(" Op-35 ")
Z2.
G1 Z0. F1000.
G41 X.15128 F1145.8
G3 X.15128 Y-93.85765 I11.5 J0.Z-1.
X.15128 Y-93.85765 I11.5 J0.Z-2.
X.15128 Y-93.85765 I11.5 J0.Z-3.
X.15128 Y-93.85765 I11.5 J0.Z-4.
X.15128 Y-93.85765 I11.5 J0.Z-5.
X.15128 Y-93.85765 I11.5 J0.Z-6.
X.15128 Y-93.85765 I11.5 J0.Z-7.
X.15128 Y-93.85765 I11.5 J0.Z-8
X.15128 Y-93.85765 I11.5 J0.Z-9.
X.15128 Y-93.85765 I11.5 J0.Z-10.
X.15128 Y-93.85765 I11.5 J0.Z-11.
X.15128 Y-93.85765 I11.5 J0.Z-12.
X.15128 Y-93.85765 I11.5 J0.Z-13.
G1 G40 X10.15128 Z-13.
G0 Z50.
10.11.2021 в 10:31, zagib сказал:
Скорее всего сейчас у вас так в pcirout
      pcan1, pbld, n$, [if rot_on_x, `sgfeed], sgplane, sgcode, sgabsinc,
        [if plane$ = zero, pfxout, pfyout],
        [if plane$ = one, pfyout, pfzout],
        [if plane$ = two, pfxout, pfzout],
Надо так в pcirout
        if plane$ = zero,
          pfxout, pfyout
          if arc_pitch$, pfzout
