youtube- Autodesk Inventor vs. Dassault 3D CAD
TechniCom, a respected CAD analyst firm, has published the results of a study they conducted comparing 15 core user capabilities. The study revealed that Inventor 2011 beat Dassault® SolidWorks in every category, proving of course what I already knew... Have a look.
icn_star_full_11x11.gificn_star_full_11x11.gificn_star_full_11x11.gificn_star_full_11x11.gificn_star_half_11x11.gif
52ratings
Time:02:19 More inScience & Technology
]]>Читать дальше]]>
      а как вы taxid фирмы нашли?
