Heidenhain Tnc 246f
ERIKCO
Heidenhain Tnc 246f
нужен пост процессор!!!помогите!
КИНТЕ НА МЫЛО: ERIKCO@HOT.EE
ЗАРАНЕЕ СПОСИБО!!!
ПРИМЕР ПРОГИ0 BEGIN PGM 10944 MM
1 BLK FORM 0.1 Z X-75 Y-46.6 Z-5
2 BLK FORM 0.2 X+0 Y+0 Z+0
3 TOOL DEF 1 L+0 R+3.99
4 TOOL DEF 2 L-16.8 R+1.23
5 TOOL CALL 1 Z S 2000
6 CYCL DEF 7.0 DATUM SHIFT
7 CYCL DEF 7.1 X-1.5
8 CYCL DEF 7.0 DATUM SHIFT
9 CYCL DEF 7.1 Y-7.8
10 CYCL DEF 7.0 DATUM SHIFT
11 CYCL DEF 7.1 Z-0.05
12 CYCL DEF 1.0 PECKING
13 CYCL DEF 1.1 SET UP-2
14 CYCL DEF 1.2 DEPTH -15
15 CYCL DEF 1.3 PECKG -3
16 CYCL DEF 1.4 DWELL 0
17 CYCL DEF 1.5 F200
18 LBL 1
19 L X-3.5 Y+12 Z+2 R0 F MAX M13
20 L Z+0 R0 F MAX M
21 L Y-31 R0 F332 M
22 L X-11 R0 F M
23 L Y+0 R0 F M
24 L Y-3.25 R0 F M
25 L X-34.5 R0 F M
26 L Z+2 R0 F MAX M
27 L Y+12 X-36 R0 F MAX M
28 L Z-3.3 R0 F500 M
29 L Y-39 R0 F222 M
30 L X-28.5 R0 F M
31 L Y-11 R0 F M
32 L X-20.6 R0 F M
33 L Y-39 R0 F M
34 L Z+2 R0 F MAX M
35 L X+5 Y+5 R0 F MAX M
36 L Z-3.3 R0 F500 M
37 L X+0.1 RL F332 M
38 L Y-31.1 RL F M
39 L X-13.7 RL F M
40 L Y-6.6 RL F M
41 L X-31.6 RL F M
42 L Y+0.1 RL F M
43 L X+0 RL F M
44 L Y-31 RL F M
45 L X-13.6 RL F M
46 L Y-6.5 RL F M
47 L X-31.5 RL F M
48 L Y+0 RL F M
49 L X-6.5 RL F M
50 L X+0.1 Y-6.6 RL F M
51 L Z+2 R0 F MAX M
52 LBL 0
53 CYCL DEF 7.0 DATUM SHIFT
54 CYCL DEF 7.1 IX-40.5
55 CALL LBL 1 REP
56 L Z+20 R0 F MAX M09
57 L Z+100 R0 F MAX M05
58 STOP M00
59 TOOL CALL 2 Z S 2000
60 CYCL DEF 7.0 DATUM SHIFT
61 CYCL DEF 7.1 X-1.5
62 CYCL DEF 5.0 CIRCULAR POCKET
63 CYCL DEF 5.1 SET UP-2
64 CYCL DEF 5.2 DEPTH -3.3
65 CYCL DEF 5.3 PECKG -1.1 F30
66 CYCL DEF 5.4 RADIUS1.3
67 CYCL DEF 5.5 F30 DR+
68 LBL 2
69 L X-18.6 Y-8 Z+2 R0 F MAX M13
70 L Z-3 R0 F MAX M
71 L Z-3.3 R0 F100 M
72 L X-15.1 R0 F80 M
73 L Y-11.5 R0 F M
74 L X-13.6 RL F M
75 L Y-6.5 RL F M
76 L X-18.6 RL F M
77 L Z+2 R0 F MAX M
78 L X-29.2 Y-4.2 Z+2 R0 F MAX M
79 L Z+2 R0 F MAX M99
80 L Y-4.2 X-19.2 R0 F MAX M99
81 LBL 0
82 CYCL DEF 7.0 DATUM SHIFT
83 CYCL DEF 7.1 IX-40.5
84 CALL LBL 2 REP
85 L Z+20 R0 F MAX M09
86 L Z+100 Y+70 R0 F MAX M05
87 END PGM 10944 MM :
Изменено пользователем ERIKCO
Вопрос ни очем!
Какая САМ система ?
Пост на Heidenhain (любой классический - например на 155) есть во ВСЕХ САМ системах. Должен подойти.
Переход по меткам и циклы для карманов и т.п. внутренняя математика вряд ли будут поддерживаться постпроцессором. Ну разве что на уровне макросов.
2-х координатка однако!
КАК НЕ ОЧЁМ?!!!!
В МАСТЕРКАМЕ ЕСТЬ ПОХОЖИЙ ПОСТ НО ОН (ИНЧ)!!!!!!!!
IBV
Мне кажется ему как то не очень надо
В одном городе живем, я ему отписал что могу помочь на это все и кончилось
      Это надо сидеть и разбираться с логикой, которая в ладдере прописана разработчиками. Возможно, что править надо. Комментарии там на английском, вам повезло. В Яндексе задавать вопросы бесполезно на этот счет
    • Mixon513
      Подскажите где нужно менять параметры. Или как задать вопрос яндексу?
    • Vengeance
      У нас на дусане револьверка крутится, когда рука опущена, один раз оператор крутанул, повезло что вращение оказалось против часовой, q-setter просто "подпрыгнул"
      У вас там есть Р0225 (T_NO_PE_DSP) Полагаю, что в ней обрабатывается отображение на дисплее
    • SAPRonOff
      либо СКМыши нажмите и там  под курсором появится вариант выбора в виде списка; либо ПКМ - другой : и там тоже будет список рядом лежащих линий.
      У меня LadderIII старый, не открывает. Надеюсь коллеги подтянуться и кто-то посмотрит формирование номера на дисплее.
    • gemini74
    • alex0800
