http://www.hyprox.fi/datasheets/4WRE.pdf
Можете сообщить полную маркировку.
4WREE 6 E16-22/G24K31/A1V-655
КАК то так
dear all
i still wait help
for our machine durma type 25100 ad r, now when the machine is realizing indexing it dose complete the process reference
but the piston y2 move up fast than piston y1 also piston y2 stop at indexation position put piston y1 is not stop at indexation piston (in actually when i measure it ) but in the screen i see that are the same so the machine give me ok to work when i choose to work with manual mode the piston y2 go down and y1 no
Dear abdushibi,
I need the machine parameters of this Press Brake. You can make photos of all pages with the machine parameters.
Also I need the photo after the indexing process (Page N)
We need the photo of this page after taking the reference (the beam is in the TOP DEAD CENTER and the red led of the START BUTTON is off)
Dear abdushibi,
What is the actual position of the X axe? The value 0.00 of X axe is impossible.
Did the  X axe move after pressing the START button?
The Y2 axe did not take reference, because the actual position of Y2 axe is 378.80, but the index position of  Y2 axe is 379.82.
Can you measure the distanse between the table and the beam on the left and the right sides?
Dear/Vad000
yes it did (the x move after pressing the start button
also with this difference the machine give me ok (mean it is complete indexation) and we can work
but when work semi automatic the x axes move after that when we need  the beam go down
just y2 go down put y1 no
(actually y2 it is the same which we see in page (n)
but y1 no they are 10 mm diffrerence )
Dear abdushibi,
Increase this parameter to 20.
After changing parameters you have to switch off the DURMA controller.
Did the difference of the velocity between Y1 and Y2 have decreased?
If not, increase this parameter to 25 and 30.
i am waiting your answer about distance between table and piston y1 and y2
The difference between Y1 and Y2 is 5 mm.
But the DURMA controller shows the other difference, about 2 mm.
So, I need you to change 65 parameter as I described in 390 message.
Dear/Vad0000
yes the difference of the velocity between Y1 and Y2 have decreased
but we have the same problem the machine complete indexation put the position of piston y1 and y2, in the screen i see that are the same but in actually when i measure it they are difference 8 to 10 mm also with this difference the machine give me ok (mean it is complete indexation) and we can work
just y2 go down put y1 no some times go together  but when we stop and after that when we need work again  the y1 and y2 do not move
but when work semi automatic the x axes move after that when we need the beam go down just y2 go down put y1 no some times go together  but when we stop and after that when we need work again  the y1 and y2 do not move
Enter the value 40 in the field TOP DEAD PNT for the each bend.
Have you any changes or not?
Make the photo of the controller at the TOP DEAD PNT (value = 40)
Смотри на почте!
я извеняюсь ,я на английском ни бум-бум,у вас есть инструкция для CEBELEC DNC60 на руском.очень надо!шеф купил листогиб,и меня поставили перед фактом.
Куда выслать?
Вышлите пожалуйста инструкцию для ЧПУ CEBELEC DNC 60 для листогиба, на русском на 50t_2007_08@mail.ru буду очень благодарен.
Вышлите пожалуйста инструкцию для ЧПУ CEBELEC DNC 60 для листогиба, на русском на 50t_2007_08@mail.ru буду очень благодарен.ПОМОГИТЕ!
      Нагуглил старый список отличий профкарт от GTX, кому интересно   А тут - полный список важных для производительности карты настроек на потыцкать https://www.goengineer.com/blog/optimizing-solidworks-for-faster-performance
      @eljer0n, в настройках драйвера и графики игровой карты попробуйте вручную выставить на максимум все видеоэффекты и привязать карту к приложению принудительно (а то у Вас симптомы как софтверного рендера на CPU). Пример: https://www.mlc-cad.com/solidworks-help-center/how-to-force-solidworks-to-use-your-graphics-card/ По дефолту там что-то среднее, скорее всего. Не поможет - установить дрова к профкартам и там покрутить настройки, сменить версию Windows с 11 на 10. И только потом можно смотреть на профкарты. Также потестить опции в самом солиде. Вот тут ниже рекомендуют включить Enable petformance pipeline и не юзать SW 2018 https://www.engineering.com/story/20-to-30-times-faster-graphics-response-with-solidworks-2019s-new-graphics-engine
      Лихой Вы, однако....   Да, это уже сильно сложнее.
    • neon0404
      Да, действительно, огромное спасибо! Ошибка новичка) Не тот режим визуализации был
    • Максим604
      @Killerchik ну да, пишу реальную и стойка переправит, а если пишу руками, то считать для центра.  Просто резьбу писал или через переменные или через turn. И подачу считал как на обычную фрезеровку.   Ещё раз спасибо)
    • Alexejswt
      Все работает.  Job-1.inp
      Простой вопрос - Вы материально гарантируете, что компании-обладателю этого TaxID это ничем не грозит?
      По Вашему описанию - как раз наоборот. Считайте реальную подачу, а стойка скорректирует исходя из диаметров. У меня на фрезере точно так же.
