Ищу материалы по нерж. сталям:
G.V.Smith, An evaluation of the yield, tensile creep, and rupture strengths of wrought 304, 316, 321, and 347 stainless steels at elevated temperatures. ASTM data series DS5S2.
Помогите!!!!!!!!!!!
    • Sivolap36
    • Irukanjii
    • anykeyto
    • Sivolap36
    • Рома калужский
    • Горыныч
