Давление в CFX
Universe
Задаю давление на входе - срывает расчет. Как корректно задать условия?
И каким способом можно задать условие: остановка расчета при достижении определенного давления в камере.
Заранее спасибо за квалифицированные советы.
Из мануала:
Recommended Configurations of Boundary Conditions
The following combinations of boundary conditions are all valid configurations commonly used in ANSYS CFX. They are listed from the most robust option to the least robust:
Most Robust: Velocity/Mass Flow at an inlet; Static Pressure at an outlet. The inlet total pressure is an implicit result of the prediction.
Robust: Total Pressure at an inlet; Velocity/Mass Flow at an outlet. The static pressure at the outlet and the velocity at the inlet are part of the solution.
Sensitive to Initial Guess: Total Pressure at an inlet; Static Pressure at an outlet. The system mass flow is part of the solution.
Very Unreliable: Static Pressure at an inlet; Static Pressure at an outlet. This combination is not recommended, as the inlet total pressure level and the mass flow are both an implicit result of the prediction (the boundary condition combination is a very weak constraint on the system).
Not Possible: Total Pressure cannot be specified at an outlet. The total pressure boundary condition is unconditionally unstable when the fluid flows out of the domain where the total pressure is specified.
With more than two inflows or outflows, the other openings should be of the boundary condition type Opening. This is because the flow at these other boundaries could in general be in or out, and the direction will be part of the solution.
Стандартными средствами расчет останавливается по заданному уровню невязки. Но там так же можно прописать не конкретное число, а безразмерный expression. Можно попробовать прописать экспрешн типа "если давление меньше такого-то, то невязка для останова 1е-99; а если давелние больше такого-то, то невязка для останова 1е-1". То есть пока давление не достигло заданного занчения расчет будет молотить бесконечно долго. А когда достигнет заданного давления - сразу остановится, так как обычно невязки меньше уровня 1е-1. Надеюсь мысль ясна, должно сработать.
Есть камера сгорания, перед ней миксер. Одновременно подаю воздух и метан. Получить надо в камере смесь с концентрацией 1:9 и давлением 12 атм. При задании на входе давление газов - срывается расчет, задавала массовый расход и тоже не корректно получается.
ОК, имеем один inlet с метаном и один inlet c воздухом. Либо один inlet и с метаном и с воздухом в заданной пропорции - неважно. Задаем на inlet скорость, либо расход - тоже принципиально неважно в такой постановке. На выходе ставим outlet и задаем относительное стат давление - 11 атм (если 12 атм - абсолютное значение). В инициализации поставить относительное стат давление в домене тоже 11атм.
В таком случае камера сразу будет под давлением 12 атм и не нужны будут извращения с остановом расчета по давлению. Если стоит задача просто посчитать смешение + поле скоростей (т.е. без горения) и др. параметры, то расчет должен быть достаточно стабильным. Для большей уверенности стоит задать шаг по времени вручную. Если скорости не сотни метров в секунду, то шага 0.01с - 0.001с с постепенным увеличением хватит за глаза.
вот тут как раз и проблема :unsure:
задаю расход, а в камере получается давление 50 атм и больше...
Такого не должны быть. Если только:
-) слишком маленький выход и поток "запирается"
-) неправильно поставлена задача в CFX
Напишите мне в личку, я посмотрю что там.
    • Sabadash
      Поправьте режим легкой сборки в настройках, включается с определенного количества деталей, просто увеличьте количество деталей или отключите этот режим. Быстрое переключение в дереве построения (Set resolved to lightweight)
    • mixey53rus
      Вот пример программы, которой сам пользуюсь O0001 ( T17 | M10 METCHIK | H17 ) N100 G21 N102 G0 G17 G40 G49 G80 G90 N104 T17 M6 ( T17 | M10 METCHIK | H17 ) N106 G0 G90 G54 X-.75 Y0. S100 M3 N108 G43 H17 Z5. N110 G94 N112 M29 N114 G98 G84 Z-10. R.5 F150. N116 G80 N118 G94 N120 M9 N122 G53 Z0 N124 G53 Y0 N126 M30
      Видел я как швейцарцы проектировали кран один, рама нижняя пополам переломилась на заводе где цветняк собирали и в вагоны грузили.  Квадратный лючок устроили в самом напряженном месте ну и переломился естественно из-за концентрации напряжений и усталости. Чайники проектировали, одно слово .  Объяснил заводчанам как чинить, все посчитал.  Кинули на три штуки бакинских , не заплатили. Думал сначала бандюкам долг продать, потом пожалел убогих. Все-таки сам когда-то работал на этом заводе, поэтому и доверял. А зря. Предают обычно свои :)  Швейцарцы с них за новую раму запросили двести штук бакинских.  Этот кран для фермеров делался, а они редко грузят вот гарантийный режим и выдерживался. Да и нагрузка не металл, а сельскохозяйственная.  А на заводе   в две смены цветняк грузили в вагоны на экспорт прибалты.  Грабили Россию   :)
      Не понял? Если гиб 1, то зачем повторения?   Повторения имеют смыслы, когда гибов больше 2-х   Например, есть программа 1 Гиб Х=20 2 Гиб Х=20 3 Гиб Х=50   Эту программу можно по другому записать 1 Гиб Х=20 (2 повтора) 2 Гиб Х=50
    • Artas28
      А почему направление стружки вверх??? Я влево - вправо выбирал . Спасибо)
    • MagicNight
      Да. Напротив, оператор станка не расслабляется!
    • andrei4ik
      Всем доброго дня. Заметил что солид каждый раз при запуске при рткрытии сборки сам ее открывает по умолчанию в сокращеном виде... в настройках галочка снята. И приходится каждый раз руками при открытии сборки уирать переключатель с сокращеного режима... Солид 2022
    • Ninja
      я сделал так как ты и сказал - ось вдоль UV. Ткнул направление стружки вверх и всё!
    • Artas28
      Молодец, а как сделал рассказать не хочешь?) или пример обратно скинуть?
    • Ninja
