Vba: Копирование Sketch`а
Russkij Drakon
Нужно с помощью макроса в part'е скопировать sketch из одной плоскости в другую...
VBA выдал макрос:
Sub CATMain()
Dim partDocument1 As PartDocument
Set partDocument1 = CATIA.ActiveDocument
Dim selection1 As Selection
Set selection1 = partDocument1.Selection
selection1.Clear
Dim part1 As Part
Set part1 = partDocument1.Part
Dim bodies1 As Bodies
Set bodies1 = part1.Bodies
Dim body1 As Body
Set body1 = bodies1.Item("PartBody")
Dim sketches1 As Sketches
Set sketches1 = body1.Sketches
Dim sketch1 As Sketch
Set sketch1 = sketches1.Item("Sketch.3")
selection1.Add sketch1
selection1.Copy
Dim selection2 As Selection
Set selection2 = partDocument1.Selection
selection2.Clear
Dim hybridShapes1 As HybridShapes
Set hybridShapes1 = body1.HybridShapes
Dim planarFace1 As PlanarFace
Set planarFace1 = hybridShapes1.GetBoundary("Selection_RSur:(Face:(Brp:(GSMPlane.1);None:();Cf9:());GSMPlane.1;Z0")
selection2.Add planarFace1
selection2.Paste
End Sub
При запуске, на строчке "selection2.Add planarFace1" выдаёт "Method "Add" of object "selection" failed."
А переменная "planarFace1 = Nothing"
Как это исправить?
    • lux59
    • Alexey0336
    • Shvg
    • TVM
