Наставьте на путь истинный Индуса!
Вот его послание:
Hello,
I am Aloke Das, from India. I am pursuing my MS in CFD from
Internatinational Institute of Information Technology, Pune.
www.isquareit.ac.in
This course is run in collaboration with Moscow State University,
Russia and RICCR, Moscow.
My final trimester is approaching, in which i have to do a project.
We have been given a chance to express our areas of interest in which
we would like to do our project.
I am not so much inclined towards doing Ph. D after MS program, so i
would like to do a project in field which is more likely to be helpful
in the industrial sector.
I would like suggestions, and informations about the areas in which
the companies are working.
It would very helpful to me.
Thanking you all,
With regards,
Aloke Das.
Вот его адрес: "Aloke Das" <alokedas2002@gmail.com>
    • IGor2D
    • Gmv
    • Gmv
    • ID_Hacker
