Shenzhen Sunsoar Tech Co.,Ltd
Shenzhen Sunsoar Circuit Technology is specialized in Printed Circuit Board & PCB Assembly including components sourcing, functional test and complete assembly for clients all over the world.
All of our base materials and process can meet ROHS and UL international certifications. We stand behind our reputation and have a 100% quality and customer's service promise.If there is any defects for our products, our team will go back to produce a new batch of products that is in conformity with every specification you have requested for.
Our PCB capabilities range from 1-18 layers prototypes and full production pcb manufacturing , with special features such as blind & buried vias, controlled impedance,heavy copper, via fill and more,Also we can deliver Single-Side PCB and Double-side PCB Prototype within 24 hours, 4-8 layer PCB Prototypes in 3-5 working days.The quick and fast lead time stably ensures our customer of quick research speed to occupying the market.
For the convenience of better cooperating with our customers, we purchased and reestablished a SMT factory in 2012. By introducing into advanced management system and adding advanced high speed SMT machines, multifunctional SMT machines, 12 wet HALS lead free hot air reflow machine and ICT testing machine facilities, we ensure our customers with high quality, speedy SMT prototype and medium batch quantity services.
Nowadays, with our 9-year OEM PCB & PCBA experience,we have built up our own Research & Development Department to develop Yunlife Series new smart household finished product such as humidifier diffuser,night light, so that we are able to provide more different customers with more our new mart and healthy products.
We rely heavily on customer and manufacturing feedback to produce a world-class production,our staff enjoys supporting customers to find a solution to reduce cost of products without sacrifice quality.Sunsoar will be your right choice.
http://www.oem-pcb.com
      как это если а куда он денется ведь чпу пока работает только глючит
      если на плате уже есть файл OPRMINF, он и будет работать. Переписывать его не надо. Все опции которые в него записаны будут работать. Если же вы попытаетесь переписать его, тогда он при включении потребует сертификацию. Потому что бутлоадер при переписывании сам внесет в него флажок о том что произошло вмешательство в опции
      да.     ранее приезжал японец вводил файл и все еще и ваш старый cpu dram модуль надо поставить тогда все заработает как надо а вы слили все системные файлы?
      То есть, если залить на новый from модуль все наши слитые архивы, никаких опций не будет, пока мы не зальем файл OPRMINF ? Но и после заливки этого файла потребуется эти опции еще и сертифицировать. Так? А как выглядит процесс сертификации? Это самим можно сделать? Может где-то подробно про это расписано - может подскажет кто.  И еще, а если, как говорил Виктор, ничего не делая со старым модулем FROM, поставить его на новую материнскую плату, то все опции и их сертификация должны по идее остаться? Так ведь? @gudstartup , спасибо за контакты  продавцов - будем думать.
    • paull3
      Добрый вечер!, принято, скачал -СПАСИБО ОГРОМНОЕ!!! завтра буду пробовать, если не затруднит напишите пожалуйста в каком положении должен быть переключатель на передней дверце .  последовательность вижу так - разархивирую на дискету- в моём случае флешку так ка стоит эмулятор,  вставляю флешку и включаю стойку чпу далее как повезёт естественно перед этим батарейку проверю и заменю всё верно?
      Так, нашел кусок дискуссии в этой теме, плюс проверил в спецификации, видимо, с трехзначным кодом исполнения засада, а очень жаль. Предыдущий вопрос снимается.
    • Akabanks87
      Спасибо за ответ. Попробую разобраться... мб встречали какой-то наводящий материал? тема или видео на ютубе? Жесткость вращения нужно по всем осям задавать, должен же быть способ проще...
      Делал неоднократно для нескольких фирм, которые разали нам металл на лазерной резке. 1. Делаем развертку отдельно без всего в масштабе 1:1. 2. Делаем обязательно линиями НУЛЕВОЙ ТОЛЩИНЫ! 3. Никаких осевых, размеров и другого мусора. Только контуры... 4. Выставляли еще требования отрисовки развертки на каком-то слое, но я обычно клал на это требование...
    • Chertezhnik
      Добрый день! Подскажите, как отобразить компоновочную геометрию из 3D модели на 2D чертеж. Могу ли я сделать на ней разрезы?
