BIESSEWORKS
Всем пользователям обрабатывающих центров BIESSE.
BIESSEWORKS 3 BASIC не требует ключа.
BiesseWorks Basic can run parametric programs and import files from external software in DXF and CID3 formats. However, the following functions (present in the Advanced version) are not included:
- Parametric programming of the working area (Advanced version recommended with EPS platforms)
- Simplified programming for custom faces (Advanced version recommended when C-axis is used frequently to bore or mill sides other than the 4 main ones)
- Automatic calculation of tool path necessary for pocketing operations.
- Text engraving using Windows font types
- Baffle for chipboard aspiration management
- 3D machining operation simulation
- Multiple panel positioning (function not yet available)
- Edgebanding
Изменено пользователем demonlibra
