PTC Named a Visionary in Gartner Magic Quadrant for Industrial IoT Platforms for the Second Consecutive Year
PTC Positioned Highest for Ability to Execute BOSTON --(BUSINESS WIRE)--Jul. 9, 2019-- PTC (NASDAQ: PTC) today announced that it has been positioned in the Visionaries quadrant by independent industry analyst firm Gartner in its Magic Quadrant for Industrial IoT Platforms 1 .
Просмотр полной статьи
    • sneg0vik
    • Soprin
    • niagara39
    • Sivolap36
    • Irukanjii
