PTC Supercharges Vuforia Augmented Reality Platform with New Technology, Acquisition, Customers, and Collaborations
Industrial Sector Moves Quickly to Adopt Vuforia Augmented Reality with Focus on Improving Workforce Productivity and Operational Efficiency BOSTON --(BUSINESS WIRE)--Jun. 11, 2019-- From the sold-out LiveWorx ® 19 digital transformation event, PTC (NASDAQ: PTC) announced new initiatives to fuel
Просмотр полной статьи
    • sneg0vik
    • Soprin
    • niagara39
    • Sivolap36
    • Irukanjii
