PTC Recognized as Winner and Finalist for Three 2019 Microsoft Partner of the Year Awards
BOSTON --(BUSINESS WIRE)--Jun. 10, 2019-- From the LiveWorx ® digital transformation event , PTC (NASDAQ: PTC) today announced it won and has been named a finalist in three of the 2019 Microsoft Partner of the Year Awards, including: Manufacturing and Resources Partner of the Year (winner), Mixed
Просмотр полной статьи
    • sneg0vik
    • Soprin
    • niagara39
    • Sivolap36
    • Irukanjii
