PTC Leaders Recognized for Achievements in Innovation, Culture, and Technology
Recognitions Highlight Employee Excellence Across Business Lines BOSTON --(BUSINESS WIRE)--May 22, 2019-- PTC (NASDAQ: PTC) today announced that five members of its leadership team have received prestigious industry awards, showcasing successes in their individual fields and in advancing the
Просмотр полной статьи
    • sneg0vik
    • Soprin
    • niagara39
    • Sivolap36
    • Irukanjii
