PTC’s Industrial IoT Platform ThingWorx Celebrates More Recognition as Industry Leader
Compass Intelligence and Quadrant Knowledge Solutions Name PTC Leader in IIoT for ThingWorx Industrial Innovation Platform BOSTON --(BUSINESS WIRE)--May 1, 2019-- PTC (NASDAQ: PTC) today announced that it has been recognized by both Compass Intelligence and Quadrant Knowledge Solutions as a 2019
Просмотр полной статьи
    • eljer0n
    • mrVladimir
    • davidovka
    • ak762
    • SAPRonOff
