PTC Names Kristian Talvitie Chief Financial Officer
BOSTON --(BUSINESS WIRE)--Apr. 24, 2019-- PTC (NASDAQ: PTC) today announced the appointment of Kristian Talvitie as Executive Vice President and Chief Financial Officer (CFO), effective May 15, 2019 . Talvitie has a broad business background with more than 25 years of finance and sales and
Просмотр полной статьи
    • soldo
    • ak762
    • Ander
    • ak762
    • soldo
      @alek77  У меня норм, просто надо соблюсти условия: 1) масштаб вида 1:1 2) масштаб листа 2:1 почему такие условия хз.
