Решении проблемы "...highly distorted."
Уважаемые участники форума, подскажите возможные пути решения ошибки
"*** ERROR *** SUPPRESSED MESSAGE CP = 5527.734 TIME= 13:07:34
One or more elements have become highly distorted. Excessive distortion of elements is usually a symptom indicating the need for corrective action elsewhere. Try incrementing the load more slowly
(increase the number of substeps or decrease the time step size). You may need to improve your mesh to obtain elements with better aspect ratios. Also consider the behavior of materials, contact pairs,
and/or constraint equations. If this message appears in the first iteration of first substep, be sure to perform element shape checking."
При этом ansys не выдает номера "плохих" элементов и проверка escheck также ничего не дает.
листинг привожу ниже
/CLEAR,START
/filename,plast_ver_5
/Title,plast_2d_Axi_ans_fric
/units,si
/config,stat
*afun,deg
s1=20e6
s2=2e6
e1=35e9
ro=2500
epscu2=0.0035
nu=.2
mu=0.25
f1=-1500
b=0.05
h=0.05
r1=0.01
el=0.0005
d=0.0
/prep7
ET,1,PLANE182
KEYOPT,1,1,2
KEYOPT,1,3,1
KEYOPT,1,6,0
KEYOPT,1,10,0
R,1
MP,ex,1,e1 ! Pa
MP,nuxy,1,nu ! No units
MP,dens,1,ro ! kg/m3
!Вариант  материала 1
TB,KINH,1,1,3,0
TBTEMP,0
TBPT,,s1/e1,s1
TBPT,,epscu2,0*s1
TBPT,,epscu2+s1/e1*10,0*s1
!TB,CONC,1,1,9,
!TBTEMP,0
!TBDATA,,,,2e6,20e6,,
!TBDATA,,,,,,,
BLC4,0,0,b,-h
/pnum,line,1
esize,el
mat,1
type,1
real,1
amesh,1
et,2,169
KEYOPT,2,2,1
et,3,172
keyopt,3,1,0
keyopt,3,3,1
keyopt,3,5,1
keyopt,3,9,0
keyopt,3,10,1
CYL4,0,r1+d,r1,0,r1,-90
*get,MaxLine,line,,num,max
MP,MU,2,mu
r,2
mat,2
type,2
real,2
esize,el
lmesh,Maxline-2,Maxline
NUMMRG,NODE,0.0001, , ,LOW
nsel,s,loc,x,0
nsel,r,loc,y,r1+d
*get,PilotID,node,,num,max
tshap, pilo
e,PilotID
alls
type,3
mat,2
real,2
lsel,s,loc,Y,0
nsll,,1
esln,,0
esurf
alls
d,PilotID,ux,0.0
d,PilotID,rotz,0.0
!lsel,s,loc,Y,-h
lsel,,,,1
nsll,,1
d,all,uy,0.0
d,all,ux,0.0
alls
!lsel,s,loc,x,0
lsel,,,,4
nsll,,1
d,all,ux,0.0
alls
/solution
f,PilotID,fy,f1
*dim,time_res,,4
time_res(1)=0.02
time_res(2)=0.066667
time_res(3)=0.666667
time_res(4)=1.0
EPLOT
ANTYPE,0
NLGEOM,1
PSTRES,1
AUTOTS,1
CNVTOL,F,1,0.1,2, ,
NEQIT,1000
NSUBST,150
OUTRES,ERASE
OUTRES,ALL,time_res
NCNV,0,0,0,0,0
TIME,1.0
С уважение к сообществу.
Изменено пользователем master_luc
Открой последний сошедшийся шаг. Там видно подозрительные элементы. Скорее всего поможет измельчение сетки в плохих местах (если, конечно, они не очень плохие).
для начала
уменьши шаг nsubst,1000
и записывай невязки nldiag,nrre,on
там же (кажется) можно записать номера проблемных элементов
(ключи напамять не скажу)
потом рисуй= plnso,nrre
по пути замечу=
сходимость улучшит nropt,unsym,,on
и уменьшение контактной жестксоти.
в принципе, я это на форуме уже писал не раз.
СергейД,
Огромное спасибо за ответ, но все рекомендации не приводят к результату.
Формы элементов остаются в норме. Решение не сходиться.
Даже использование nropt,unsym,,on не увеличивает число сошедшихся подшагов.
Может быть особые способы решения используются при ниспадающая ветвь сигма-эпсилон.
И, глупый вопрос:
Где определяется контактная жесткость?
ничего кроме keyopt(10) и Fkop не нашел, да и последнюю в интерфейсе не наблюдаю.
Тем более, что использую жесткую таргет поверхность.
С уважением.
П.С. Посмотрел все ваши сообщения на форуме, может быть я слепой - но четких указаний не нашел.
контактная жесткость задается в R, как третья х-ка.
0.1 для начала (множитель на автовыбираемую)
но главное, нужно смотреть невязки.
в принципе применение жестких таргетов всегда ухудшает сходимость.
kinh я бы сгладил. и до нуля не доводил.
и стараюсь применять нагружение перемщениями (кинематическое)
а не силами.
мультик и графики сделайте.
А Ансис по поведению невязок умееет варьировать параметры сходимости - шаг мельчить и т.п.?
саша!
может-может.
вы бы наконец-то пригласили кого нибудь, с кем мне интересно было бы поговорить о невязках и тп,
к участию в форуме...
а с вами мне только про газодинамику общаться имеет резон.
Эх! Сергей Тропкин настолько разрывается на работе, что просто не может (а может и не хочет) участвовать в местных разговорах.
Но вроде нашли выход из ситуации. Раздел по Абакусу то уже создали, поэтому задавайте вопросы, а там уж дядя Вова или еще другие (появились уже на форуме) подскажут куда фонариком светить.
добрался наконец-то до файла. из спортивного интереса.
(дел у меня уж никак не меньше, чем у Тропкина...)
вроде все теперь считает.
советы. прежде чем активировать физнелин= просчитать без него.
без него считает= дело в материале, а не в контакте
опции 172 я поправил.
бетон вообще-то так моделировать не стоит... и там могу дать множество мелких поправок.
видно же, что при физлинейном расечте напряжения гигантские.
и начальный шаг нужно сделать таким, чтобы первые шаги были ниже предела текучести.
остальное по мелочам.
testluk.txt
Уважаемый Сергей!
Спасибо за участие, ну а теперь по порядку.
Эту модель я анализировал с би-линейным материалом (Диаграмма Прандтля),
И вроде как было все ОК (конечно применять для бетона такую модель не совсем
корректно, но для первого приближения более или менее...)
Как только активировал обратную линию - все пошло наперекосяк.
Опции 182:
1) Keyopt(1)=2 - упрощенная расширенная формулировка деформаций
(как обезьяна цитирую умную книгу , хотелось бы к этому еще и физику процесса понимать)
Опции 172:
1) Keyopt(2)=0 - метод MPC - чем он лучше расширенного метода (может быть существуют какие-то рекомендации или область применения???)
2) Keyopt(3)=1 активировать не следует - т.е. указывать что ОС расчет не следует???
И, я так полагаю, вы хотели указать множитель к контактной жесткости для
второго набора численных констант (для контактного элемента), а не для первого:
R,1,,,0.1 => R,2,,,0.1
Принятая сетка (на мой взгляд) грубовата, так как оценка, например, по SMX показывает:
Напряжения: 0,5S 0,1S
размер 5,00 мм: 0,025671 0,020822
размер 2,50 мм: 0,014024 0,012555
(погрешность) 45,4% 39,7%
размер 1,25 мм: остановка остановка
на 0,282 на 0,236
0,091541 0,004111
Таким образом, опять же на мой взгляд, полученное решение ни чем не лучше ответа - нет решения, так как, при такой огромной относительной погрешности доверять результатам
нельзя. Или я что-то упустил?
Я решил, что лучше перейти на конкретный материал ( в данном случае штамп - стальной шар) и нагрузку приложить через rigid элемент на все верхние узлы полушара. Посмотрим...
В любом случае, огромное спасибо за помощь.
П.С. Пару вопросиков :
1) Какие поправки можете дать по модели бетона?
2) Возможно ли управлять толщиной отрисовки изолиний?
3) Каким образом отобразить ЗНАЧЕНИЕ приложенной нагрузки (не листинг, а в модели)?
4) Где можно ознакомиться с планом проведения учебных занятий по ANSYS в МГСУ (если я правильно понял) в которых участвует Сергей.
вряд ли смогу заочно ответить на все вопросы.
в обучении я не участвую, я его провожу...
программа примерная есть на сайте stadyo.ru. Корректируется под заказчика.
сейчас системно обучать некогда. Расчеты интереснее...
Видимо, проведем в феврале-марте.
проконсультировать можно= пишите в личку.
1. такое сложное поведение нужно моделировать максимально искривленным графиком
(задайте по еврокоду хотя бы). обратная кривая требует большой аккуратности
2. для бетона есть solid65 и его нужно осваивать. сделайте сектор и решайте.
3. опция 3 только для СЭ. программа сама поймет, что осевая симметрия (в182)
4. R разумеется.
5. ваша прежняя сетка избыточна. ее нужно сгустить у контакта.
6. /pbc,f,,2
7. общие рекомендации по контакту я уже давал. Остальное зависит от задачи конкретной
8. В результах вы сомневаетесь, думаю, излишне.
Ну наконец я добрался до форума...
Спасибо за ответ Сергей!
Безусловно вы ведете занятия, я просто не так выразился.
На сайте stadyo.ru я нашел раздел обучение - но присутствует только название
"Программа семинаров-консультаций по 5-дневному курсу "Применение высокоэффективных конечно элементных технологий в компьютерном моделировании теплового и напряженно-деформированного состояния произвольных пространственных конструкций и сооружений в программном комплексе ANSYS."
Больше ничего нет ...
А насчет результатов... то каким образом можно верифицировать полученные результаты на грубой сетке?
Я знаю только один способ: сгустить сетку в двое и сравнить полученную разницу в расчетных показателях.
Безусловно мой пример не показательный, так как при сгущении сетки в случаи приложения сосредоточенных
нагрузок, будет также расти расчетные показатели в местах приложения нагрузки...
Кручу дальше ...
А кликнуть на название курсов не попробовали?
вроде бы все видно...
попробуйте еще раз
<noindex>http://stadyo.ru/kurs_ob.html</noindex>
сосредоточенных сил (с нулевой площадью приложения)
в реальности ведь не бывает. всегда есть некая площадка нагружения.
соответственно и бесконечных напряжений не будет.
даже в линейных задачах будет асимптота.
а в нелине ограничивает пластика.
      А  метал хрупкий или пластичный ?  Нагрузка постоянная или переменная ?   "Вот у меня в зоне отверстия средние напряжения ~250 МПа" даже если умножите на оптимистичную двойку, то получите 50 кГ/кв.мм что в общем то не мало...  Сжатие то ладно, а в растянутой зоне надо бы скругление сделать
    • Mr.White
      Такие вещи считаются и делаются парами исходя из межосевого расстояния, модуля и количества зубьев. Прокаткой по бумаге в нужный угол не попадешь, это даже описано в книге по ремонту зубчатых колес.
      Давление изнутри? Если изнутри, 2d схема не эквивалентна схеме с затяжкой шпилек. Т.к. фиксировать здесь надо отверстия, а не всю боковую поверхность.
    • serrj
      Всём Добрый день! Кто-нибудь может выручить нужны посты на Hass vm-2, стойка Hass и simens sinumerik 820d. Всём заранее спасибо!
      Иногда с конструктором можно согласовать большие радиуса иногда нет. Вообще работал я фрезой ф0,4 на прессформах бывает и такое, тут важна длина ф0,4 5-6 диаметров - работает норм. Вообще борьба за вылеты частая проблема. ТО есть? В сыром шероховатость сложно получить. Без слесарей не обойдешься, полируют они, с станка не получишь норм шероховатость формы. А по стратегии да черновая, подборки в углах получисто чисто. Часто нужна ЭЭВ на прессформах и прожиг электродами.
    • Ninja
      Помните был человек из Рио? А тут человек из Челябы! Да, там сейчас очень круто!!! https://74.ru/text/incidents/2024/05/26/73624415/
    • tompsongun
      Коперник 4.5.5 ещё одно срочное обновление - поправил логику переключений и синхронизаций между 1 и 2 поля, разбиения на 2 поля, имя файла= наименование - были исчезновения введенных значений, иногда задвоения в отображаемых свойствах еще чего-то (если имя файла из одного слова - оно поместится в поле обозначение, чтоб оно попало в наименование - вкл. имя файла=наименование или впереди дописать обознач.+разделитель); - в 2польном режиме обозначение не разделялось (повторно не дробилось на обозн. и наим.), если в поле ввести символ Разделителя (в конце обозначения Разделитель ввести не получится, можно переключиться на режим 1 поля или ввести нужное, а потом сдвинуть курсор назад и вставить разделитель) .          описание сложновато-костыльным ощущается, но вроде проще на практике. тут, конечно, пипец, с постоянной проверкой вводимых символов и проверкой надо ли разделить на наимен. и обозн. +синхронизация с полями вывода + если вкл. или выкл. одно или др., по кругу прыгаешь между подпрогами т.к. всё друг друга проверяет, наверняка, где-то уже дублирует по функционалу какому-то, и вызываются отдельно. жесть, короче, какая-то . но стабильность растёт )))   Коперник 4.5.5.zip   пока около месяца или чуть больше, увы, дорабатывать не получится, но замечания пишите если что, можно и в личку.
    • Dordenis
      Я выбираю материал отливки в разделе "Начальные условия" Потом я в разделе "полная задача" выбираю: Литье под давлением с камерой прессования.    Может не то делаю. Подскажите, как надо.   Где вводить температуру формы я не знаю, и в меню программы не встречал.
      наружное давление 33 МПа. Сверху отверстие под рым-болт. На торце 3 монтажных отверстия, в которых будут шпильки для стягивания к корпусам других ступеней насоса Вот у меня в зоне отверстия средние напряжения ~250 МПа. Думаю, умножить их на коэфф. концентрации для ответрстия, да и дело с концом. Что думаете?
      Резьба мешается? Резьбу и конусность в отверстиях удалить, удалить фаски, отверстия оставить. Какому? Справочник Петерсона 1977 Коэффициенты концентрации напряжений ? На отверстия не обращают внимания, если они не сильно повлияют на НДС основной детали. А на картинке вообще не ясно, где они, как расположены, как нагружен металл в зоне рядом с отверстиями.
