PTC ThingWorx Platform Recognized as a Leader in Industrial IoT Software Platforms Report by Independent Research Firm
Augmented Reality and Device Connectivity Make ThingWorx a “Strong Choice for Companies” BOSTON --(BUSINESS WIRE)--Jan. 28, 2020-- PTC (NASDAQ: PTC) today announced it has been named a leader in a new evaluation of Industrial Internet of Things (IIoT) software platforms issued by Forrester Research
Просмотр полной статьи
    • sneg0vik
    • Soprin
    • niagara39
    • Sivolap36
    • Irukanjii
