Новости РТСSicame Group Selects PTC’s ThingWorx for Remote Monitoring and Real-Time Insight
Smart, Connected Products Will Allow Product Performance Monitoring and Improved Operation Efficiency NEEDHAM, Mass. --(BUSINESS WIRE)--Sep. 12, 2018-- PTC (NASDAQ: PTC) today announced that Sicame Group , a global provider of products related to the transport and distribution of electrical energy,
Просмотр полной статьи
    • Andrey_kzn
    • niagara39
    • nicomed
    • sneg0vik
    • Soprin
    • niagara39
