PTC Provides “Leading AR Platform in the Market,” According to Independent Analyst Report
Автор:
Bot,
в Новости РТС
Сообщения
Автор: Maks Horhe · Опубликовано:
Можно и так сказать) Пока я не выслал бэкап посмотрите пожалуйста, будет работать уп? Станок 3х фрезер, fanuc 0i mf plus. Именно в таком виде, в одном файле, может где ошибся, подскажите. Пока не пробовал. % O0001(FREZA D40R5) G21 G0 G17 G40 G49 G80 G90 T1 M6 (D40) G0 G90 G54 X0. Y0. S800 M3 G43 H1 Z20. M8 G1 F500. X0. Y0. G66 P8888 X0. Y0. G67 G66 P8889 X0. Y0. G67 G66 P8890 X0. Y0. G67 M5 M9 M30 % O8888 #20=20(RFrezi) #21=63.7(DNach) #22=-121.0(Z) #23=4.5(Angle) #24=1(step Z) #25=0.25(step CIRC) #33=-1(G2-1 G3+1) (****************) G90 G1 Z1.0 #11=0 #12=0 #13=1.0 #26=ROUND[3.142*#21/#25](N) #27=#21/2-#20 #31=#27 #28=0 #29=#24*TAN[#23] #30=#29/#26 #32=360/#26 N1 #1=#11+#27*COS[#28] #2=#12+#27*SIN[#28] #3=#13+[#27-#31]/TAN[#23] IF [#3 LT #22] GOTO2 G1 X#1 Y#2 Z#3 #27=#27-#30 #28=#28+#32*#33(G2 or G3) IF [ABS[#28] GE 360] THEN #28=0 IF [#27 LE 0.1] GOTO3 GOTO1 N2 X#1 Y#2 G2 I[#11-#1] J[#12-#2] N3 G1 X#11 Y#12 (Z[#13+5]) X#11 Y#12 M99 % O8889 #20=20(RFrezi) #21=45(DNach) #22=-121(Z) #23=0.001(Angle) #24=0.5(step Z) #25=0.25(step CIRC) #33=-1(G2-1 G3+1) (****************) G90 G1 Z-113.0 #11=0 #12=0 #13=-113. #26=ROUND[3.142*#21/#25](N) #27=#21/2-#20 #31=#27 #28=0 #29=#24*TAN[#23] #30=#29/#26 #32=360/#26 N4 #1=#11+#27*COS[#28] #2=#12+#27*SIN[#28] #3=#13+[#27-#31]/TAN[#23] IF [#3 LT #22] GOTO5 G1 X#1 Y#2 Z#3 #27=#27-#30 #28=#28+#32*#33(G2 or G3) IF [ABS[#28] GE 360] THEN #28=0 IF [#27 LE 0.1] GOTO6 GOTO4 N5 X#1 Y#2 G2 I[#11-#1] J[#12-#2] N6 G1 X#11 Y#12 (Z[#13+5]) X#11 Y#12 M99 % O8890 #20=20(RFrezi) #21=44.969(DNach) #22=-195(Z) #23=-4.5(Angle) #24=0.5(step Z) #25=0.25(step CIRC) #33=-1(G2-1 G3+1) (****************) G90 G1 Z-121.0 #11=0 #12=0 #13=-121.0 #26=ROUND[3.142*#21/#25](N) #27=#21/2-#20 #31=#27 #28=0 #29=#24*TAN[#23] #30=#29/#26 #32=360/#26 N7 #1=#11+#27*COS[#28] #2=#12+#27*SIN[#28] #3=#13+[#27-#31]/TAN[#23] IF [#3 LT #22] GOTO8 G1 X#1 Y#2 Z#3 #27=#27-#30 #28=#28+#32*#33(G2 or G3) IF [ABS[#28] GE 360] THEN #28=0 IF [#27 LE 0.1] GOTO9 GOTO7 N8 X#1 Y#2 G2 I[#11-#1] J[#12-#2] N9 G1 X#11 Y#12 G1 Z[0+10] F2000. X#11 Y#12 M99 % -
Автор: Eduard99 · Опубликовано:
Заказ очень актуальный, прошу не стесняться задавать вопросы на почту и переходить к обсуждению. Количество может быть разделено на 2 партии: по 4шт каждого + остаток. Первая партия на 4шт. потребуется за 2 месяца, остальное можно попозже. Являюсь прямым заказчиком. -
Автор: AlexArt · Опубликовано:
Ну заниматься математикой на досуге полезно для прочистки мозга. -
Автор: mannul · Опубликовано:
Вы уверены что у вас программа и подпрограмма выводятся? Оставьте галочку только на УП при записи: -
проверяйте все что написано в руководстве. то что вы там нарезаете хоть десятками к рг не имеет отношения она зафиксирована. или это привод активного инструмента? -
на каких блоках7 если надпись smartkey не исчезает то ключ не читается у вас он не читается по причине неправильной работы базы. можите вынуть ключ с базы и посмотреть ошибка должна остаться -
Автор: FitchKrause · Опубликовано:
Ранее на этом станке успешно запускали нарезку 5-и уплотнителей, нарезали две штуки, и в момент смены инструмента нажали reset. Посыпались ошибки, их вроде устранили, попутно сбросив нули станка(не специально) и восстановив их, после он проработал примерно час и проблем не было. Ещё ранее, его пару раз запускали и нарезали уплотнители, работал без проблем. А про разборку двигателя не известно, скорее всего как он приехал, включили, дабы проверить на работоспособность и все. -
Автор: karlf · Опубликовано:
Ну, интересный момент в том, что на этом бэкапе, который загружается полностью, ключ не видится и на блоках в шкафу горит красная лампочка. А на бэкапе, который не грузится полностью, на блоках загорается зелёная. То есть сам ключ физически работает
