PTC Named the Technology Leader in Global PLM Market for Second Consecutive Year
Technology Excellence and Customer Impact Qualify PTC as the Technology Leader in Global PLM Market Evaluation by Quadrant Knowledge Solutions BOSTON --(BUSINESS WIRE)--Feb. 13, 2020-- PTC (NASDAQ: PTC) today announced it has been named the leader in the global product lifecycle management (PLM)
Просмотр полной статьи
    • статист
