PTC Appoints Craig Melrose to Lead New Digital Transformation Solutions Organization
BOSTON --(BUSINESS WIRE)--Jul. 16, 2019-- PTC (NASDAQ: PTC) today announced that Craig Melrose has been appointed as the executive vice president of the company’s digital transformation solutions organization. Melrose will lead this newly-formed organization to build customer-facing solutions that
Просмотр полной статьи
    • статист
