Hi all
Does someone have a existing machine wirring diagram for this controller and rest of CNC press brake?
I have a Beyeler small 50 ton press brake with Y1-Y2 and rear back guage
Machine i purchased but wirring is done so i need to see a machine how it is wired safty and everything
I have a Cybelec MSV-402 controller in it for the controlling of pressure of Y1-Y2
thank you for the help
11 час назад, simplextibi сказал:
I have INPUT/OUTPUT manual.
LS60-PS-0.pdf
Hello
Thank you i have this, i would like to see a example of a existing machines wirring
I have a problem of the RAM not moving at all, i dont know where to start :(
Maybe even paramter is not correct and maybe other stuff
I someone have a Cybelec technical instaructions, supposedly it has example working
thanks
Изменено пользователем simplextibi
I need the photos of the buttons and the posiotion keys.
38 минут назад, simplextibi сказал:
Yes i have axis X1 X2 there is a proportional valve on top which keeps it in synchron
You have mistaken, Y1 and Y2 are hydraulic axes.
X1 and X2 are mechanical axes. What induction motors do you have?
And I need the photo with positions switch.
ahhh
The axis are hydraulic with a proportional valve HVM-090-100 for ech one, each side has a Heidenhein sliding measuring.
I have a X axis in the rear with a rotary encoder and a 3PH motor
The hydraulic pump has a valve i gues to swith on the pressure with a manually adjustable pressure
The first problem i see is that on J9 i do not get the -/+10v outputs to controll the Cybelec MCV-402A
proportional valve controller, if i inducxe manually 10V it will give output, so i think the controller is nmot giving signal on J9
At the moment i dont care about rear just the Y1 and Y2
1.jfif
2.jfif
13 минуты назад, simplextibi сказал:
If You have only one X axis, why we have two X axes in machine parameters?
Ok, so parameter is bad
So how do i enter Y1 and Y2 axes?
On J12, J13 i have the linear mesuring encoder for Y1 and Y2
Ok so i change axis 0 to X nad erase all other
Can i use other 3 axis for R and other backgage axis?
What parameter controlls the J9 output for the MCV 402A controller?
I see you have experience with this
Can you help me configure the parameters step by step, page by page
I could pay for your help if you dont ask too much:)
I bought this machine and would like to get it in operation
5 часов назад, simplextibi сказал:
OK.
At first we enter machine parameters for mechanical axes.
Read this manual.
See the example on pages 51-52.
N2X7E.pdf
2 минуты назад, simplextibi сказал:
I configured the axis to 0 type
You have servo axis or AC axis?
If you have AC axis, 120 patameter = 3
I have axis controller MSV402
I dont know if this is AC or DC controller
on manual you sent
axis parameter for P00
it says 0 for DC
1 for AC
3 for not controlled
15 минут назад, simplextibi сказал:
MSV402 is the hydraulic amplifier.
I need the photo of the motor.
MSV402.pdf
