Листогиб с ЧПУ Cybelec DNC880s
Ostapushenko
Прошу помощи! Листогиб с ЧПУ DNC880s нужна инструкция пользователю или подскажите пожалуйста обучающие статьи. Буду благодарен любой информации. Спасибо!
19 минут назад, Ostapushenko сказал:
http://cncmanual.com/download/4291/
  • 7 месяцев спустя...
 Sir ... Vad0000 ..
My customer owns the ACL / china bending machine PSH-160/4100 ... the old machine frequently fails. Some people try to repair but fail. the machine hardware & software been rape for 100 time ..
      The CNC system cant see any logo CYBELEC and WindowsXP open, but the Cybelec program DNC1200 cannot be opened. It is completely on-hook and paralyzed.totally no function at all
     Guess it need to double check all wiring, troubleshooting is that any circuit board failed, i need a service manual for DNC 800, Could anyone in charge be able to provide any solution?5e55b34b55b18_WhatsAppImage2020-02-22at1_00_22PM.thumb.jpeg.6b39646efc31e1cf7691dab593b335ff.jpeg5e55b34d54bb9_WhatsAppImage2020-02-22at1_02_03PM.thumb.jpeg.fa65481ec516f4f040595c9fb9c9c15c.jpeg5e55b34c71a34_WhatsAppImage2020-02-22at12_47_24PM.thumb.jpeg.03ff6cf63578fb08ed6ab9ddf08a748d.jpeg5e55b34979ff1_WhatsAppImage2020-02-22at12_44_09PM.thumb.jpeg.a43ea305eaa2735118b0702f2f019b93.jpegA.5e55b347f2ec4_WhatsAppImage2020-02-22at12_47_42PM.thumb.jpeg.5023a2c18e1cab7d26f981bca9c5c307.jpeg
  the machine wiring been mess up by previous tenichian...i need to verify all the wiring connection before try anything...i got the Heorbiger Amplifi cateur digital  PVR6
Installation  manuel & panasonic servo motor driver manual.
     Now i need cybelec 800s service manaul as well..cant get it anyway....other then operation manaul...Anyone here can help?
On 2/26/2020 at 7:55 AM, ok2266 said:
 Sir ... Vad0000 ..
4 часа назад, ok2266 сказал:
You don't need any service manual to determine the faulty unit or PCB. It'll be enough only wiring diagram of the machine.
В 26.02.2020 в 02:55, ok2266 сказал:
What is mean  "program DNC1200 cannot be opened"?
1)cant turn it into manual or semi auto..totally no function at all,
2)cant call out this 2 page...(photo attached )
3)that an error 21.0 from the servo motor controller...
some craazy guy try to repair the machine half way,had mess up all the wiring,and dismentle the servo motor n leave it on the floor...
(*Encoder communication error protection / Error code no 21 /Communication between the encoder and the driverhas been interrupted in certain times, and disconnection detecting function has been triggered.)
4) something wrong with Hoerbiger PVR6 wiring,
a) that no connection wire 244 for enable, x14/1 & x14/2
b) i dnt have the hyraulic circuit drawing,but as i understand,it should have a proportional relief         valve to control pressure...Y6 - x5/1 & x5/2 or Y5 - x5/3 &  x5/4
5) since someone add a external LCD,i also suspect inside all the cybelec component may be mess up too, ,i need to double check all pcb connection as well.
5e5e9f059dcc6_WhatsAppImage2020-03-02at8_14.10PM(1).thumb.jpeg.ba903284809a4164cdbbd31854d8f299.jpeg5e5e9f077deee_WhatsAppImage2020-03-02at8_14_10PM.thumb.jpeg.8974b23ff44078fb352b4d8ce92a624b.jpeg
    • Topcher
      Здравствуйте, подскажите пожалуйста модель изначально была stp формата, открыл в NX  и пересохранил в Step. Начинаю писать обработку но не могу выбрать ни одну плоскость обработки- не выбирает, не подсвечивает ее. В чем может быть проблема?
      Спецификация технически отчётный документ, при заполнении всех необходимых свойств в модели конечно, но построение отчёта в Solidworks во встроенной спецификации работает со скрипом и скрежетом, возможно первый подход SWR (бывшее представительство Solidworks в РФ) по выведению отчёта в отдельной программе было технически верным, но продукт оказался сырым и не законченным, а формат самого файла спецификации закрытым без возможностей гибкой настройки и не стандартным вроде MS Word, Excel или любой иной относительно доступный и распространённый формат.   С точки зрения другой программы мог бы выступить громоздкий PDM, но зато из него так понимаю может быть выплюнута спецификация относительно быстро и действительно как отчёт по документу сборки исходя из структуры изделия загруженной в систему PDM. Но в этом случае встают вопросы поднятия этого самого PDM, его администрирования, резервирования и другие сопутствующие проблемы его внедрения.   Возможно в качестве отчётного документа вероятно всё таки стоит вытаскивать из Solidworks таблицу всех свойств по всем деталям, а потом загонять для сортировки в специфический софт создания перечней и спецификаций вроде GeeTeeSoft TDD, где отлажены способы сортировки, но не отлажены способы взаимодействия с механическими 3Д САПРами для взаимного обмена позициями элемнтов и некоторыми специфическими параметрами вроде форматов чертежей.   Если автоматизировать эти процессы, то взаимная  и постоянная связь не нужна (с возможность автоматического обновления туда-сюда), только что создать модуль проверки, который будет сверять имеющуюся спецификация с фактической моделью, сборочным чертежём (в плане позиций) и в случае наличия неточностей вносить изменения или строить новый отчёт по модели, сборочному чертежу не оглядываясь на старую спецификацию. Для сверки отчётов может быть создан отдельный модуль, что бы отследить изменения или случайные ошибки.
    • co11ins
      похоже затянул.
    • clavr
      @РоманВ  Такие фалы солид открывает коряво. советую открыть в компасе там поправить с сохранить в иджес или паросолид потом вот пример:
      @РоманВ Все гораздо проще. 1 PN350 BALL VALVE STEP (2).SLDPRT Надписи на плоской поверхности ручки. Удалить грань не катит. Используйте команду удалить\сохранить тело. Выбираете верхнюю плоскость ручки и плоские поверхности надписей. Если другие поверхности мешают выбору их можно скрыть, потом высветить обратно. Потом затягиваете плоской поверхностью по кромкам. Всё.
    • РоманВ
      Большое спасибо! Сам параллельно решил этот вопрос через костыли. Удалял что можно, сохранял с солид. Потом импортировал в X_T, открывал, исправлял, удалял, импортировал в IGS. Открыл и там уже не было этих артефактов.
    • sloter
      1 PN350 BALL VALVE STEP (2)_1.STEP
    • Дмитрий22
      Поставлю вопрос иначе. Существуют макросы для заполнения тех. требований чертежа. Чтоб не компилировать постоянно из шаблонов за полем чертежа, а, например, в макросе выбирать checkBoxom нужные требования и он будет автоматически формировать нужные пункты. Например, термообработку, покраску, неуказанные отклонения и т.д.
    • РоманВ
      Прошу помощи. Есть импортированная геометрия шарового крана. Открылось поверхностями. На ручке была маркировка направления откр-закр. Все, что смог - удалил. В закрашенном режиме ничего не видно в этом месте, в каркасном видно, что остались элементы надписи. Не могу выделить их, чтобы удалить функцией "Удалить грань". Так же не могу найти как разбить эту сложную поверхность на простые, чтобы удалить эти элементы как отдельные поверхности.  Вот так выглядит в закрашенном виде. Верхняя поверхность ручки отвалилась в отдельную, поэтому пока тут дыра А вот так выглядит в каркасном. И вот эту стрелку и остатки букв никак не могу поймать, выделить и удалить. Если пытаюсь выделить в каркасном - выделяет лежащую за ними поверхность. Если у кого-то получится удалить их и сохранить степ без них - буду весьма признателен. 1 PN350 BALL VALVE STEP (2).STEP
    • Stanislav
