Сообщения
Автор: yunoleg · Опубликовано:
https://drive.google.com/file/d/1o5b62TuvZQalbDJ9_aG81fc6I_Ojsg7d/view?usp=drive_link, https://drive.google.com/file/d/17bjDQq5UQ9HaZRu9QIGNjD5Iy9rEQ9XB/view?usp=drive_link, https://drive.google.com/file/d/1v5rY8NXGV0dsvizuyDwHdnQE53M0QlRi/view?usp=drive_link, https://drive.google.com/file/d/1xCjwwPhNUiLshQmCz5GVwO6nwrL1teew/view?usp=drive_link, https://drive.google.com/file/d/1biXChIeRXUPkyRq-vUAX7QTYDSAFajwG/view?usp=drive_link, https://drive.google.com/file/d/1hmQcWIwtIMVSaAKob7ET6JHxK9BiN1XO/view?usp=drive_link, https://drive.google.com/file/d/1wyzqJB9iwENMyWHD1EQgyUCw7iED8Blm/view?usp=drive_link, https://drive.google.com/file/d/1WCtff2C-_jPQniOz8QPRVTEZ9lNIaXIZ/view?usp=drive_link, https://drive.google.com/file/d/1PNeqoEomozDWPtBuB7_BMwNQLdkd7F13/view?usp=drive_link, https://drive.google.com/file/d/1zWW6U-gzl9ypvOWv1AQcW18Xb4AVRJXB/view?usp=drive_link, https://drive.google.com/file/d/1mtitt98SGu63Fr_db5HSVfE43-j6utgG/view?usp=drive_link, https://drive.google.com/file/d/1TeWtLQYDtWxOnOphgJ82brZWgapoftxT/view?usp=drive_link, https://drive.google.com/file/d/1zWk7w8BxpU_uwj-LP0H23eoR8nphLeNQ/view?usp=drive_link, https://drive.google.com/file/d/1YCZDInHYxQyLo_xQQgc0sUOcuUNrv1c9/view?usp=drive_link, https://drive.google.com/file/d/16bIqWYg8ryKRFa8LTfSpaIySo1_4VdGs/view?usp=drive_link, https://drive.google.com/file/d/1x2xqlaFCfXRIwoTxvSjxciKuJ04Ao7-0/view?usp=drive_link, https://drive.google.com/file/d/18YxxWmy2zgUzbMai9lD4XTgQeJUbGVrd/view?usp=drive_link, https://drive.google.com/file/d/16ZBXioHIXFtlYMhBQFopycwDPRdDYC_x/view?usp=drive_link, https://drive.google.com/file/d/112_xqezNot4ecDOMbmvtLN_nOnEQR_tR/view?usp=drive_link, https://drive.google.com/file/d/1Qx6eOwQqD9dcxrpeudbXJL8HQTZzQe2l/view?usp=drive_link, https://drive.google.com/file/d/1tUJ14IpIHF49EXBQ85tdrEzrWDQ0zZSK/view?usp=drive_link, https://drive.google.com/file/d/1fJarfkIcPR1B2_pMod10R8iO09HqqpEn/view?usp=drive_link, https://drive.google.com/file/d/1LsWkJXPuwBL3HlhbzehJpCOjZ0Gf6Eaq/view?usp=drive_link, https://drive.google.com/file/d/1Nm2j1JAn3tTXxznxdY9Y6bpD_ZNhjy0_/view?usp=drive_link -
Автор: Леонид124 · Опубликовано:
Можно ли так экспортировать? -
Автор: karlf · Опубликовано:
В общем, сделал образ с родного диска, накатил его на новый диск и докинул туда недостающий файл и всё поехало -
Автор: vo.aand · Опубликовано:
Всем привет, я провожу простой расчет напряжений в SolidWorks, решила попробовать так, чтобы получить достоверную картинку, а не только значения по формуле, так вот результирующие в программе получаются в 10^4 раз больше. Размеры листовой детали L x B x H=6.5 x 1.4 x 0.016 м, размер выреза в детали L x B x H=2.5 x 0.7 x 0.016 м. Размеры модели в м, но при 500 000 Н напряжения получаются очень большими равными 89 670 МПа это максимум, в нейтральной зоне 67 680 МПа. Если считать через формулу то будет так σ=N/F= 500 000 Н/ (0.016 x 1.5) м^2 = 22 321 429 Па= 22,32 МПа Изображение по ссылке: https://disk.yandex.ru/i/jFPT3Yn7W8hlpA. -
я думал вы сами пересчитывали. а про параметры серво они вам ничего не сказали? может спросить отчего медленее едет.... -
Автор: ope@gusarm.ru · Опубликовано:
производители станка сказали какие поставить в зависимости от шага винта и редуктора. Линейно то правильно считает, значит тут все так должно быть. Если б тут была ошибка то при передвижении на метр ехало больше или меньше. -
как считали flexible feed gear а именно 2084\2085 программой? -
Автор: Guhl · Опубликовано:
Посмотреть хотя бы что предлагают. Цены увидеть. Может для себя присмотреть что-нибудь -
нет в ноль только в россии ушатывают причем в полный и по балансовой стоимости и по морально физическому состоянию. станки по 20 лет круглосуточно работают. вы на реставрацию берете?
