Отключение линейки z на mikron hem500u itnc 530
Krychkow78
Krychkow78
Имеется станок mikron 500u с умершей линейкой по оси z , линейка endat , привод сименс тоже endat стойка itnc 530 , мог бы кто нибудь подсказать как это провернуть
17 минут назад, Krychkow78 сказал:
А что способ из сервис мануала не подходит?
SHB_iTNC530_September_2013_en.pdf
Krychkow78
Пробовал вот так
1) If possible move the axis to 0 o or reference point
2) Switch of control voltage
3) Service code: 807667
4) In parameter list via GOTO or search with arrow button Up/down.
Attention: don not press the enter or the return button in the parameter list
otherwise lines could be deleted
5) Set MP 110.4 to0
6) Set in MP 331.4 the Value from MP 1054.4
7) Set in MP 332.4 the Value of 2048
8) Setin MP 1350.4 the value of 5
9) Set in MP 1355 at Bit 5 (from the right to the left side) to 0
10) Consume the value from MP 1356.4 with the value of MP 960.4 (subtract or add)
and set in the new value in MP 960.4
Important: Change the display to Ref. the value must maybe written in with
reverse sign . Before plus after Minus contrariwise. Set afterwards MP 1356.4 to
11) Set in MP 1357 at Bit 5 to 0
12) Afterwards press END (not the Enter button) Values are stored and the system wil
be reboot.
13) If there will appears stillstand or motion error the axial direction has to be changec
in
MP 210 Bit 5 (B-axis) 0 or 1 depends to the value which is written.
14) Switch on the control voltage and reference the axis slowly.
15) Check position after the axis had found the reverence point
16) lf under Point 1 no possibility to refer the axis the reference point has to be
adjusted in MP 960
17) The motor have an absolute value encoder ,that means after switch on the
controller
The current position is present, you must not referencing
For Example: X-Axis if you know the old ref.point move by hand the machine to
This position otherwise you have to measure.Set now the parameter 960.0 to
zero
nove
55 минут назад, Krychkow78 сказал:
Пробовал вот так
А зачем вы пробовали с осью B если вам надо пробовать с Z?
Krychkow78
55 минут назад, gudstartup сказал:
Это инструкция к B а пробовал с Z
1 час назад, Krychkow78 сказал:
И что вышло?
Krychkow78
И что вышло?
Пр нажатии CE шла загрузка и стопорилось все на ошибке компиляции PLC
15 минут назад, Krychkow78 сказал:
Ясно значит ваш станкостроитель конфигурировал настройку контура ОС через ПЛК, надо разбираться с его модулями и конфигурацией
Krychkow78
А не подскажите как это сделать , и ещё такой момент не могу зайти в диагностику приводов пишет plclogin : проверьте не занято ли это другим приложением
47 минут назад, Krychkow78 сказал:
На страницах форума это невозможно как невозможно за день изучить программирование и конфигурацию ПЛК Хейденхайн.
Станкостроитель имеет массу путей для ограничения действий пользователя в ПЛК панели (кнопки и окна не будут активны или вообще отображатся) пока вы не введете нужный код доступа, часть файлов защищены от изменений в зашифрованном разделе PLCE или функции осей контролиируются safety plc и т.д..
53 минуты назад, Krychkow78 сказал:
Отмените код 807667 и проверьте маску подсети в ip интерфейсе /
должно быть в последнем байте 0 (например 255.255.255.0)  иначе диагностика вообще не запускается
      Экспорт мухоморов из России активно растет, так как на Западе и в Азии этот гриб стал популярным сырьем для альтернативной медицины и биодобавок.  Основные причины и цели экспорта: Фармакология и косметология: За рубежом компоненты мухомора (после специальной обработки) используют для создания мазей от ревматизма, артрита и кожных заболеваний. Тренд на микродозинг: В ряде стран (например, в США) существует высокий спрос на сушеные шляпки для употребления в сверхмалых дозах. Сторонники метода утверждают, что это помогает бороться с бессонницей, тревожностью и депрессией. Альтернативная медицина: Интерес к грибам резко подскочил в период пандемии, когда люди начали искать нетрадиционные способы укрепления иммунитета. Доступность сырья: В России мухомор распространен повсеместно, а его сбор и экспорт в сушеном виде юридически не запрещены (если вид не занесен в Красную книгу).  Основные покупатели российских мухоморов — США, Филиппины, Германия, Италия и Киргизия. Только из Пермского края в 2023 году вывезли более полутонны сушеных грибов.    Во тема для бизнеса .  Летом и осенью их как грязи в лесу :)  На внутреннем рынке цены на красный мухомор (Amanita muscaria) в среднем составляют: Опт (заготовители): от 10 000 до 15 000 рублей за килограмм. Розница (маркетплейсы и спецмагазины): от 18 000 до 35 000 рублей за килограмм (в пересчете из мелкой фасовки по 50–100 г). Пантерный мухомор (Amanita pantherina) стоит значительно дороже — от 50 000 до 80 000 рублей за кг, так как он более редкий и содержит более высокую концентрацию действующих веществ.    В Германии В Европе мухоморы позиционируются как экзотическое сырье для коллекционирования или косметологии, что диктует более высокую стоимость: Средняя цена: от 400 до 600 евро за килограмм (около 40 000 – 60 000 рублей). Мелкая розница: на европейских сайтах и в специализированных «этноботанических» магазинах цена может достигать 1–1,5 евро за грамм (до 1000–1500 евро за кг), если товар позиционируется как продукт высшего качества (Grade A).  Почему такая разница? Основная наценка в Германии связана с логистикой, необходимостью прохождения таможенного контроля (который становится всё строже) и рисками, связанными с правовым статусом продукта в разных странах ЕС.  Важно: Помните, что мухомор является ядовитым грибом. В России его продажа в качестве пищевого продукта запрещена, а употребление может привести к тяжелому отравлению.     Для мухоморов и большинства трубчатых грибов действуют следующие пропорции: Коэффициент усушки: в среднем 10:1. Вес: из 10 кг свежих грибов получается примерно 1 кг сушеных. Если говорить конкретно о мухоморах, то их шляпки теряют в весе чуть меньше, чем ножки, но общее правило сохраняется. Чтобы получить 1 кг сушеного продукта, который в Германии стоит 400–600 евро, заготовителю нужно собрать и переработать не менее 10–12 кг свежего сырья. Ай да ИИ  всему научит :)  5 кГ собрать в сезон в день вообще не проблема, а легкая прогулка. А это 250 евриков в день. За 20 дней 5000 евриков. А если организовать бабушек в деревне на сбор и платить по штуке евриков примерно в месяц, то за сезон можно лимон евриков заработать :)
