в программе не прописывается подача
iivanov
 G50 S1500
5    G96 G98 S180 M4
5    M8
5    G0 X150.0 Z150.0
5    X56.0 Z-23.1
5    G1 X46.457 F0.
5    G0 X56.0
5    Z-25.1
5    G1 X46.457 F0.
5    G0 X56.0
5    Z-27.1
5    G1 X46.457 F0.
5    G0 X56.0
5    Z-29.1
5    G1 X46.457 F0.
5    G0 X56.0
5    Z-31.1
5    G1 X46.457 F0.
5    G0 X56.0
5    Z-23.1
5    G1 X42.914 F0.
5    G0 X52.457
5    Z-25.1
5    G1 X42.914 F0.
5    G0 X52.457
5    Z-27.1
5    G1 X42.914 F0.
5    G0 X52.457
5    Z-29.1
5    G1 X42.914 F0.
5    G0 X52.457
5    Z-31.1
5    G1 X42.914 F0.
5    G0 X52.457
5    Z-23.1
5    G1 X39.371 F0.
5    G0 X48.914
5    Z-25.1
5    G1 X39.371 F0.
5    G0 X48.914
5    Z-27.1
5    G1 X39.371 F0.
5    G0 X48.914
5    Z-29.1
5    G1 X39.371 F0.
5    G0 X48.914
5    Z-31.1
5    G1 X39.371 F0.
5    G0 X48.914
5    Z-23.1
5    G1 X35.829 F0.
5    G0 X45.371
5    Z-25.1
5    G1 X35.829 F0.
5    G0 X45.371
5    Z-27.1
5    G1 X35.829 F0.
5    G0 X45.371
5    Z-29.1
5    G1 X35.829 F0.
5    G0 X45.371
5    Z-31.1
5    G1 X35.829 F0.
5    G0 X45.371
5    Z-23.1
5    G1 X32.286 F0.
5    G0 X41.829
5    Z-25.1
5    G1 X32.286 F0.
5    G0 X41.829
5    Z-27.1
5    G1 X32.286 F0.
5    G0 X41.829
5    Z-29.1
5    G1 X32.286 F0.
5    G0 X41.829
5    Z-31.1
5    G1 X32.286 F0.
5    G0 X41.829
5    Z-23.1
5    G1 X28.743 F0.
5    G0 X38.286
5    Z-25.1
5    G1 X28.743 F0.
5    G0 X38.286
5    Z-27.1
5    G1 X28.743 F0.
5    G0 X38.286
5    Z-29.1
5    G1 X28.743 F0.
5    G0 X38.286
5    Z-31.1
5    G1 X28.743 F0.
5    G0 X38.286
5    Z-23.2
5    G1 X25.2 F0.
5    G0 X34.743
5    Z-25.175
5    G1 X25.2 F0.
5    G0 X34.743
5    Z-27.15
5    G1 X25.2 F0.
5    G0 X34.743
5    Z-29.125
5    G1 X25.2 F0.
5    G0 X34.743
5    Z-31.1
5    G1 X25.2 F0.
5    G0 X34.743
5    X31.2 Z-30.424
5    G1 X25.2 F0.
5    G0 X31.2
5    Z-31.1
5    G1 X14.251 F0.
5    G0 X56.0
5    Z-22.512
5    G1 X50.024 F0.
5    X48.849 Z-23.1 F0.
5    X25.4 F0.
5    G2 X25.2 Z-23.2 R0.1
5    G1 Z-30.424 F0.
5    X23.849 Z-31.1 F0.
5    X10.602
5    G0 X56.0
5    (  OPERATION:  FINISH  GROOVE: OUTER  КАНАВКА3  )
5    G0 Z-22.441
5    G50 S3000
5    G96 G98 S213 M4
5    M8
5    G0 X56.0 Z-22.441
5    G1 X49.883 F0.
5    X48.883 Z-22.941 F0.
5    G3 X48.6 Z-23.0 R0.2
5    G1 X25.4 F0.
5    G2 X25.0 Z-23.2 R0.2
5    G1 Z-30.3 F0.
5    G3 X24.883 Z-30.441 R0.2
5    G1 X23.883 Z-30.941 F0.
5    G3 X23.6 Z-31.0 R0.2
5    G1 X10.602
5    G0 X150.0
5    M5
5    M9
5    G28 U0
5    G28 W0
5    M30
    • Arhgeo
      Спасибо, всё заработало!
    • Radon
      Считают и лопатку турбины и диск турбины с пластичностью, уже лет с десяток как, да и работают они с пластикой тоже. Ознакомьтесь как считают циклическую долговечность с использованием уравнений мэнсона коффина и что в это уравнение входит, прежде чем ёрничать.
    • sloter
      @clavr У меня размеры и пропорции получились другими. Поэтому и показалось, что разница между исходными габаритами и развёрткой мизерная. Выкладывал скрин выше.
      Я пришёл. И не буду томить в ожидании. @clavr  где линии гиба?
      Ну и косяки небольшие поправьте в конце.
      Сейчас придет maxx2000 и спросит, где линии гиба.
    • clavr
    • Vladimir_Gorshkov
    • Arhgeo
      Всем привет. Снова нужна помощь. Хотел переделать макрос, чтобы задавать название NC-файла, но в итоге выходит "$newname100sled". Вот макрос: FORM STRATEGYSELECTOR IMPORT TEMPLATE ENTITY TOOLPATH TMPLTSELECTORGUI "Finishing/Constant-Z-Finishing.002.ptf" EDIT TPPAGE SWBlock EDIT BLOCK ZMIN UNLOCK EDIT BLOCK ZMIN "-0,4" EDIT BLOCK ZMIN LOCK EDIT BLOCK ZMAX UNLOCK EDIT BLOCK ZMAX "39" EDIT BLOCK ZMAX LOCK EDIT BLOCK RESETLIMIT "20" EDIT BLOCK RESET EDIT TPPAGE TOOL ACTIVATE TOOL "6sv" EDIT TPPAGE SWConstZFinishing EDIT PAR 'AxialDepthOfCut.UserDefined' '1' EDIT PAR 'Stepdown' "50" EDIT PAR 'Tolerance' "0,05" EDIT PAR 'CutDirection' 'any' EDIT PAR 'Thickness' "0" EDIT TPPAGE SWPointDistrb EDIT TOOLPATH POINTDIST 'Filter.Factor' "0,035" EDIT TPPAGE SWLeadsLinks EDIT TPPAGE SWLeadIn EDIT TOOLPATH LEADS LEADIN NONE EDIT TPPAGE SWLink EDIT TOOLPATH "1" CALCULATE FORM ACCEPT SFConstZFinishing STRING NewName =  INPUT "Введите имя модели" CREATE NCPROGRAM "$NewName+100sled" EDIT NCPROGRAM "$NewName+100sled" APPEND TOOLPATH "1" DEACTIVATE NCPROGRAM\r FORM STRATEGYSELECTOR IMPORT TEMPLATE ENTITY TOOLPATH TMPLTSELECTORGUI "Finishing/Constant-Z-Finishing.002.ptf"
    • Дмитрий2000
      Здравствуйте , уважаемый форум. Купили машину Deckel Maho 100 V (DMC 100V) с системой управления DIALOG 112. При попытке сдвинуть любую ось либо отправить станок на референт появляется желтая ошибка "M01 operation error ". В более развернутом меню определил вероятный код ошибки "M01 operation error 0004". Через сервисное меню получилось сдвинуть только инструментальный магазин. Проверил реле, из PILZ PNOZ не загорается только один PILZ A190. Так же на машине имеется ошибка "EMG not aus" , стоит открыть и закрыть дверь станок включается, ошибка снимается только после запуска. Стоит нажать красную кнопку выключения , "EMG not aus" возвращается и чтобы снова запустить станок нужно перезапустить его с рубильника. Цепь аварийной остановки проверена мультиметром, она в порядке. Может есть способ отключить блокировку M01? В руководстве нашел код ошибки, там говорится следующее:
