NX не находит сервер лицензирования.
ExtraCOM
Здравствуйте Господа и Дамы, форумчане.
Нужна помощь.
Есть сервер лицензирования (отдельная машина):
>lmutil lmstat -A
lmutil - Copyright (c) 1989-2019 Flexera. All Rights Reserved.
Flexible License Manager status on Thu 12/29/2022 11:37
[Detecting lmgrd processes...]
License server status: 28000@VIDEO-MEETING
    License file(s) on VIDEO-MEETING: C:\Program Files\Siemens\PLMLicenseServer\splm11.lic:
VIDEO-MEETING: license server UP (MASTER) v11.16.4
Vendor daemon status (on VIDEO-MEETING):
    ugslmd: UP v11.16.4
Feature usage info:
splm_ugslmd.log:
 6:55:21 (lmgrd) Server's System Date and Time: Thu Dec 29 2022 06:55:21 RTZ 2 (ceia)
 6:55:21 (lmgrd) pid 13296
 6:55:21 (lmgrd) SLOG: Summary LOG statistics is enabled.
 6:55:21 (lmgrd) Done rereading
 6:55:21 (lmgrd) FlexNet Licensing (v11.16.4.0 build 252457 x64_n6) started on VIDEO-MEETING (IBM PC) (12/29/2022)
 6:55:21 (lmgrd) Copyright (c) 1988-2019 Flexera. All Rights Reserved.
 6:55:21 (lmgrd) World Wide Web:  http://www.flexerasoftware.com
 6:55:21 (lmgrd) License file(s): C:\Program Files\Siemens\PLMLicenseServer\splm11.lic
 6:55:21 (lmgrd) lmgrd tcp-port 28000
 6:55:21 (lmgrd) (@lmgrd-SLOG@) ===============================================
 6:55:21 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
 6:55:21 (lmgrd) (@lmgrd-SLOG@) Start-Date: Thu Dec 29 2022 06:55:21 RTZ 2 (ceia)
 6:55:21 (lmgrd) (@lmgrd-SLOG@) PID: 13296
 6:55:21 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.16.4.0 build 252457 x64_n6 ( build 252457 (ipv6))
 6:55:21 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
 6:55:21 (lmgrd) (@lmgrd-SLOG@) Listening port: 28000
 6:55:21 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
 6:55:21 (lmgrd) (@lmgrd-SLOG@) Is LS run as a service: Yes
 6:55:21 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
 6:55:21 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c C:\Program Files\Siemens\PLMLicenseServer\splm11.lic -l C:\Program Files\Siemens\PLMLicenseServer\splm_ugslmd.log -z -s
 6:55:21 (lmgrd) (@lmgrd-SLOG@) License file(s) used:  C:\Program Files\Siemens\PLMLicenseServer\splm11.lic
 6:55:21 (lmgrd) SLOG: FNPLS-INTERNAL-VL1-4096
 6:55:21 (lmgrd) Starting vendor daemons ...
 6:55:21 (lmgrd) Started ugslmd (pid 11700)
 6:55:21 (ugslmd) FlexNet Licensing version v11.16.4.0 build 252457 x64_n6
 6:55:21 (ugslmd) SLOG: Summary LOG statistics is enabled.
 6:55:21 (ugslmd) SLOG: FNPLS-INTERNAL-CKPT1
 6:55:21 (ugslmd) SLOG: VM Status: 0
 6:55:21 (ugslmd) SLOG: FNPLS-INTERNAL-CKPT5
 6:55:21 (ugslmd) SLOG: TPM Status: 0
 6:55:21 (ugslmd) SLOG: FNPLS-INTERNAL-CKPT6
 6:55:21 (ugslmd) Server started on VIDEO-MEETING for:
 6:55:21 (ugslmd) NX91110 (consisting of:        NX91110_3d_to_2d_flattener
 6:55:21 (ugslmd) NX91110_assemblies NX91110_drafting NX91110_dxf_to_ug
 6:55:21 (ugslmd) NX91110_dxfdwg    NX91110_features_modeling NX91110_gateway
 6:55:21 (ugslmd) NX91110_grip_execute NX91110_iges    NX91110_nx_freeform_1
 6:55:21 (ugslmd) NX91110_nx_nastran_export NX91110_nx_sheet_metal NX91110_nx_spsd_stress
 6:55:21 (ugslmd) NX91110_nx_spsd_vibration NX91110_pcf_package_file NX91110_pstudio_cons
 6:55:21 (ugslmd) NX91110_pv_ugdatagenerator NX91110_sla_3d_systems NX91110_solid_modeling
 6:55:21 (ugslmd) NX91110_step_ap203 NX91110_step_ap214 NX91110_studio_visualize
 6:55:21 (ugslmd) NX91110_ug_kf_checker NX91110_ug_kf_execute NX91110_ug_nas_des
 6:55:21 (ugslmd) NX91110_ug_smart_models NX91110_ug_to_dxf NX91110_ug_web_express
 6:55:21 (ugslmd) NX91110_ugopen_menuscript) borrowing    gateway_id
 6:55:21 (ugslmd) ideas_integration nx_integration    nx_nas_bn_basic_dsk
 6:55:21 (ugslmd) teamcenter_admin server_id
 6:55:21 (ugslmd)
 6:55:21 (ugslmd) Licenses are case sensitive for ugslmd
 6:55:21 (ugslmd)
 6:55:21 (ugslmd) EXTERNAL FILTERS are OFF
 6:55:21 (lmgrd) ugslmd using TCP-port 49885
 6:55:21 (ugslmd) SLOG: Statistics Log Frequency is 240 minute(s).
 6:55:21 (ugslmd) SLOG: TS update poll interval is 600 seconds.
 6:55:21 (ugslmd) SLOG: Activation borrow reclaim percentage is 0.
 6:55:21 (ugslmd) (@ugslmd-SLOG@) ===============================================
 6:55:21 (ugslmd) (@ugslmd-SLOG@) === Vendor Daemon ===
 6:55:21 (ugslmd) (@ugslmd-SLOG@) Vendor daemon: ugslmd
 6:55:21 (ugslmd) (@ugslmd-SLOG@) Start-Date: Thu Dec 29 2022 06:55:21 RTZ 2 (ceia)
 6:55:21 (ugslmd) (@ugslmd-SLOG@) PID: 11700
 6:55:21 (ugslmd) (@ugslmd-SLOG@) VD Version: v11.16.4.0 build 252457 x64_n6 ( build 252457 (ipv6))
 6:55:21 (ugslmd) (@ugslmd-SLOG@) === Startup/Restart Info ===
 6:55:21 (ugslmd) (@ugslmd-SLOG@) Options file used: None
 6:55:21 (ugslmd) (@ugslmd-SLOG@) Is vendor daemon a CVD: No
 6:55:21 (ugslmd) (@ugslmd-SLOG@) Is FlexNet Licensing Service installed and compatible: No
 6:55:21 (ugslmd) (@ugslmd-SLOG@) FlexNet Licensing Service Version: -NA-
 6:55:21 (ugslmd) (@ugslmd-SLOG@) Is TS accessed: No
 6:55:21 (ugslmd) (@ugslmd-SLOG@) TS access time: -NA-
 6:55:21 (ugslmd) (@ugslmd-SLOG@) Number of VD restarts since LS startup: 0
 6:55:21 (ugslmd) (@ugslmd-SLOG@) === Network Info ===
 6:55:21 (ugslmd) (@ugslmd-SLOG@) Listening port: 49885
 6:55:21 (ugslmd) (@ugslmd-SLOG@) Daemon select timeout (in seconds): 1
 6:55:21 (ugslmd) (@ugslmd-SLOG@) === Host Info ===
 6:55:21 (ugslmd) (@ugslmd-SLOG@) Host used in license file: VIDEO-MEETING
 6:55:21 (ugslmd) (@ugslmd-SLOG@) HostID node-locked in license file: COMPOSITE=539F867*****
 6:55:21 (ugslmd) (@ugslmd-SLOG@) HostID of the License Server: "444553544f53 8c8caa7e74a2 1418c3db161d 1418c3db161e 1618c3db161d *********"
 6:55:21 (ugslmd) (@ugslmd-SLOG@) Running on Hypervisor: Not determined - treat as Physical
 6:59:45 (ugslmd) TCP_NODELAY NOT enabled
В общем нормальная "плавающая" лицензия для двух компов.
Перестал запускаться NX1926
На рабочей станции на которой запускается NX,
"Ошибка лицензии NX: не удается установить соединение с системой сервера лицензий.
Сервер (Imgrd) не запущен или переменная SPLM_LICENSE_SERVER задана для недопустимого port@host. [-15]
"Siemens PLM software licensing tool" также выдает:
ошибка -15
На хосте системная переменная прописана
сервером лицензирования указан 28000@VIDEO-MEETING
порты ОТКРЫТЫ на обоих машинах (сто раз проверял), в фаерволе дырку сделал на TCP 28000 )))
Есть ещё у кого нибудь предположения, почему трабла?
2 минуты назад, ExtraCOM сказал:
Нужна помощь.
>lmutil lmstat -A
    ugslmd: UP v11.16.4
Feature usage info:
splm_ugslmd.log:
 6:55:21 (ugslmd)
 6:55:21 (ugslmd)
ошибка -15
а да, ещё, с хоста пробовал телнетом на сервер на 28000 - просто влетело..
    • FitchKrause
      Ошибка происходит даже если станок простаивает, его не клинит после смены инструмента, 30 минут работает без вопросов, а затем просто выдает ошибку и блокирует серво-турель. И проблема только с этим, по осям x и z, в режиме jog, ref и handle ходит спокойно. Манометры тоже не показывают каких либо проблем. "Кулачок", который держит заготовку тоже работает исправно.
      Не корректировать надо, а разбираться в причине перегрузки. Может у вас голова клинит где-то. Зажим у нее вроде бы гидравлический, по симптомам вполне возможно, что тут проблема.
    • TVM
      Согласен, что не всё так уж страшно, но повторюсь, не все так просто.
    • Koels
      Всем привет. Фанук Professional 3. Станок Makino V 55. Передодически вылазит ошибка "609 Z axis: inv. Radiator fan Failure". Вылазит она в рандомное время, может во время работы, может в простое станка. Менял вентеляторы на Ориг. Все привода включая этот полностью вымывал, до блеска. Сам по себе привод не горячий. Ещё до меня говорили, что эта ошибка была и раньше, они просто меняли привод на новый, тот работал пол года, выскакивала опять ошибка и по старой схеме, новый привод и на пол года. Щас мне нужно разобраться в чем дело, и сам понять не могу. Может можно как то в параметрах забить максимальную температуру для привода,  в книжках не видел такого
    • The_22nik
      Доброе время суток, коллеги!   Решил попробовать ускорить процесс создания разрезов на чертеже. Для больших сборок процесс занимает по 2-5 минут, неприятно. Можно сделать разрез в самой модели и перетащить её в чертеж. Все относительно нормально, но не получается отобразить обстановку (конверт) на таком разрезе.
    • FitchKrause
      Посмотрел по контроллеру ошибку(контроллер veichi sd700-5r5a-fa-d), в документации следующее Получается происходит перегрузка, теперь вопрос состоит в том как его подкорректировать,
    • FitchKrause
      Так залез значит в заднюю часть станка и там он мне пишет ошибку Er.720. Так я полазил и ещё нашел книжку по серво-туреле, но она то ли на китайском, то ли японском.
      Программа которой вы пользуетесь определяет М ПЕРВЫХ собственных чисел и векторов для матриц размером NxN. М много-много меньше N. Поищите в интернете алгоритмы, которые решают именно эту задачу. И вы увидите и поймете, что нужно сделать численную факторизацию матрицы жесткости.
      Много что есть на белом свете...:=) Если собственная частота = 0, а это тот случай о котором идет речь, то как вы найдете единственный собственный вектор. Только не говорите в качестве аргумента, что кто-то что-то знает....:=)
    • __GAR__
      Здравствуйте. Город Курск. В данный момент возьмем детали на фрезеровку массой до 80 кг, и тела вращения без ограничений.
