Удалить вращение камеры NX Open
deh9hs
Здравствуйте. Подскажите, пожалуйста, какая функция в журнале отвечает за вращение камеры?
Я удалил такие части кода:
NXOpen.Point3d scaleAboutPoint1 = new NXOpen.Point3d(-16.215898023039518, 10.575585667199768, 0.0);
            NXOpen.Point3d viewCenter1 = new NXOpen.Point3d(16.215898023039664, -10.575585667199684, 0.0);
            workPart.ModelingViews.WorkView.ZoomAboutPoint(1.25, scaleAboutPoint1, viewCenter1);
            NXOpen.Point3d scaleAboutPoint2 = new NXOpen.Point3d(-12.972718418431583, 8.4604685337598333, 0.0);
            NXOpen.Point3d viewCenter2 = new NXOpen.Point3d(12.972718418431734, -8.460468533759741, 0.0);
            workPart.ModelingViews.WorkView.ZoomAboutPoint(1.25, scaleAboutPoint2, viewCenter2);
            NXOpen.Point3d scaleAboutPoint3 = new NXOpen.Point3d(-10.378174734745263, 6.7683748270078716, 0.0);
            NXOpen.Point3d viewCenter3 = new NXOpen.Point3d(10.378174734745398, -6.7683748270077837, 0.0);
            workPart.ModelingViews.WorkView.ZoomAboutPoint(1.25, scaleAboutPoint3, viewCenter3);
            NXOpen.Point3d scaleAboutPoint4 = new NXOpen.Point3d(-8.3025397877962099, 5.4146998616063069, 0.0);
            NXOpen.Point3d viewCenter4 = new NXOpen.Point3d(8.3025397877963183, -5.4146998616062154, 0.0);
            workPart.ModelingViews.WorkView.ZoomAboutPoint(1.25, scaleAboutPoint4, viewCenter4);
            NXOpen.Point3d scaleAboutPoint5 = new NXOpen.Point3d(-6.6420318302369541, 4.3317598892850535, 0.0);
            NXOpen.Point3d viewCenter5 = new NXOpen.Point3d(6.642031830237066, -4.3317598892849629, 0.0);
            workPart.ModelingViews.WorkView.ZoomAboutPoint(1.25, scaleAboutPoint5, viewCenter5);
            NXOpen.Point3d scaleAboutPoint6 = new NXOpen.Point3d(-5.3136254641895464, 3.4654079114280498, 0.0);
            NXOpen.Point3d viewCenter6 = new NXOpen.Point3d(5.3136254641896699, -3.4654079114279637, 0.0);
            workPart.ModelingViews.WorkView.ZoomAboutPoint(1.25, scaleAboutPoint6, viewCenter6);
NXOpen.Matrix3x3 rotMatrix1 = new NXOpen.Matrix3x3();
            rotMatrix1.Xx = 0.96533429702299545;
            rotMatrix1.Xy = 0.081373321601911852;
            rotMatrix1.Xz = -0.24800822067542638;
            rotMatrix1.Yx = 0.037268825544830277;
            rotMatrix1.Yy = 0.8974566731012108;
            rotMatrix1.Yz = 0.43952537418062437;
            rotMatrix1.Zx = 0.258342272254519;
            rotMatrix1.Zy = -0.43353189321845947;
            rotMatrix1.Zz = 0.86331301850996822;
            NXOpen.Point3d translation1 = new NXOpen.Point3d(-77.49478481461793, -30.874519473708904, -11.259821185011582);
            workPart.ModelingViews.WorkView.SetRotationTranslationScale(rotMatrix1, translation1, 7.8735770643394423);
Движений камеры стало меньше, но все равно при вызове API центрируется на начале координат.
IgP
не спец, но по аналогии:
вот эта " workPart.ModelingViews.WorkView.ZoomAboutPoint(1.25, scaleAboutPoint1, viewCenter1);"
строка (и подобные ей) делает изменение визуализации(изображения)
    • Кварк
      https://www.chipmaker.ru/topic/227862/?tab=comments#comment-4337643   Опасные участки можно отнести к ошибке численного расчета? Сингулярность, я так понял, это называют. Или эти участки действительно потекут? Если потекут, то нужно понимать: хрупкий или нет материал? Если хрупкий, то однозначно разрушение?
    • hlibhlib
    • _Shadow_
      ЛЮБАЯ катька портативная...
      У меня тоже кое что осталось после подключения барфидера к станку NOMURA с Mitsubishi   Барфидером управляет программа 5555 И вот образец программы изготовления детали из которой эта 5555 вызывается     5555 O8016
    • Artut
      Спасибо, помогло. Как тут плюсануть в репутацию?
    • Udav817
      Под полным скруглением вы подразумеваете вырождение плоскостей первоначального тела? Чтобы у пирамиды не осталось плоских граней? Ну такое Компас точно не может. Да и не только Компас. У меня в Solid Edge тоже ошибку выдаёт. Даже последовательное скругление не поможет. И, кстати, это в целом с геометрией так. Уберите цилиндр и попробуйте отдельно пирамиду так скруглить. И вас геометрическое ядро так же пошлёт учить матан и логику.  Это вам надо искать программу, которой геометрический движок позволит такое вытворять, вырождая поверхности полностью, даже не превращая их в точку (в точку, кстати, тоже не всякое ядро сможет).
      Для символа по ГОСТ доступ к полям не доступен через API. Можно попробовать поковырять через WinAPI.   Если речь об установках электронных компонентов, то там возможно проще блоки использовать, а в блоках на ставится элемент сварка/пайка/наклеивание и соответственно приходится использовать заметку и простой эскиз для значков.   Как вариант к заметке дорисовывать эскизы (как бы внутри элемента заметки - API это позволяет), но не уверен что можно будет нарисовать эскиз привязанный к направлению линии выноски. Возможно для контроля выноски и положения значка можно втиснуть в файл встроенный макрос, который будет следить за выноской и перерисовывать значок. Из минусов этого метода, что доступ к эскизам заметки только средствами API, но проблем с отображением на других машинах, где нет макроса, вроде быть не должно (ну только что без макроса редактировать/обновлять эскизы в таких заметках не получиться).   В Solidworks часто в записи бывает мало полезного. А вот уже готовые похожие примеры в справке по API попадаются.
      Возможно программа ранее задавала какие-то вопросы на которые вы поставили галочку БОЛЬШЕ НЕ СПРАШИВАТЬ и возможно в выборе было НЕ СОХРАНЯТЬ, вот и не сохраняет. Возможно стоит вернуть все или нужные запросы системы, что на этот раз ответить правильно или не ставить больше галочек БОЛЬШЕ НЕ СПРАШИВАТЬ.   Инструменты-Параметры...-Настройки пользователя-Запросы и уведомления (или как-то так)
      Зачем? Чем не устроил ГОСТ 13682-80 МЕСТА ПОД КЛЮЧИ ГАЕЧНЫЕ? Например:  и т.п.
      Окно точно полностью на экран умещается? Размер окна пробовали менять? Уменьшить за рамку (например, сверху рамки) или увеличить (например квадратик рядом с крестиком в правом верхнем углу заголовка окна). Возможно в какой-то момент было уменьшено разрешение экрана и окно перестало влезать на экран.
