Проблемы с 5 осевой обработкой на DMU DMG
elmar_fsapr2000
Доброго времени суток.
Решили попробовать 3+2 обработку на DMU DMG monoblock со стойкой Heidenhain ITNC 530
Программируем в POWERMILL. Постпроцессор опробован на аналогичном станке, то есть рабочий
Выводит коды с 19м циклом.
BEGIN PGM 1 MM
BLK FORM 0.1 Z X-75.6 Y-75.6 Z-17.05
BLK FORM 0.2 X75.6 Y75.6 Z0.0
L M129
LBL 170
CYCL DEF 7.0 DATUM SHIFT
CYCL DEF 7.1 X0.0
CYCL DEF 7.2 Y0.0
CYCL DEF 7.3 Z0.0
CYCL DEF 19.0 WORKPLANE
CYCL DEF 19.1
LBL 0
; TOOL NUMBER : 7
; TOOL TYPE   : DRILL
; TOOL ID     : 2
; TOOL DIA. 6.250  LENGTH 70.000
TOOL CALL 7 Z S1500 DL+0.0 DR+0.0
M135
CYCL DEF 32.0 TOLERANCE
CYCL DEF 32.1 T0.100
CYCL DEF 32.2 HSC-MODE:0 TA0.5
L M03
L M129
CALL LBL 170
CYCL DEF 7.1 IX+0.0
CYCL DEF 7.2 IY+0.0
CYCL DEF 7.3 IZ+0.0
CYCL DEF 19.0 WORKING PLANE
CYCL DEF 19.1 A+0.0 B-0.375 C+0.0
L B-0.375 C0.0 F1000 M126
; TOOLPATH  : 1
; WORKPLANE : 1
L M08
L X-0.056 Y+0.0 F3000
L X+0.488 Y+70.210
L Z+5.654
L Z-17.074 F1000
L Z+10.495 F3000
L M127
CALL LBL 170
; BEGIN RTCP SECTION
L M128
L X+0.419 Y+70.210 Z+10.498 B-0.375 C0.0
L X+0.125 Y+0.0 Z+10.495 C-180.0
; END RTCP SECTION
L M129
CALL LBL 170
CYCL DEF 7.1 IX+0.0
CYCL DEF 7.2 IY+0.0
CYCL DEF 7.3 IZ+0.0
CYCL DEF 19.1 A+0.0 B+0.375 C+0.0
L B-0.375 C-180.0 F1000 M126
; TOOLPATH  : 1_1
; WORKPLANE : 2
L X+0.056 Y+0.0 F3000
L X-0.488 Y-70.210
L Z+5.654
L Z-17.074 F1000
L Z+10.495 F3000
L M127
CALL LBL 170
L M128
L X-0.419 Y-70.210 Z+10.498 B-0.375 C-180.0
L X+0.0 Y+0.125 Z+10.495 C-90.0
; END RTCP SECTION
L M129
CALL LBL 170
CYCL DEF 7.1 IX+0.0
CYCL DEF 7.2 IY+0.0
CYCL DEF 7.3 IZ+0.0
CYCL DEF 19.1 A-0.375 B+0.0 C+0.0
L B-0.375 C-90.0 F1000 M126
; TOOLPATH  : 1_1_1
; WORKPLANE : 3
L X+0.0 Y+0.056 F3000
L X+70.210 Y-0.488
L Z+5.654
L Z-17.074 F1000
L Z+10.495 F3000
L M127
CALL LBL 170
L M128
L X+70.210 Y-0.419 Z+10.498 B-0.375 C-90.0
L X+0.0 Y-0.125 Z+10.495 C90.0
; END RTCP SECTION
L M129
CALL LBL 170
CYCL DEF 7.1 IX+0.0
CYCL DEF 7.2 IY+0.0
CYCL DEF 7.3 IZ+0.0
CYCL DEF 19.1 A+0.375 B+0.0 C+0.0
L B-0.375 C90.0 F1000 M126
; TOOLPATH  : 1_1_1_1
; WORKPLANE : 4
L X+0.0 Y-0.056 F3000
L X-70.210 Y+0.488
L Z+5.654
L Z-17.074 F1000
L Z+10.495 F3000
L M09
L M127
CALL LBL 170
PLANE RESET STAY
L Z0.0 F MAX M92
L B0.0 C0.0 R0 F MAX M94
L M05
CYCL DEF 32.1
TOOL CALL 0
L M30
END PGM 1 MM
ИТД
Закидываем на станок и тут-то начинаются чудеса. Голова и система координат поворачивается нормально но инструмент сверлит отверстия не в нужном месте.
При разных углах обработки смещение разное. По программе должны сверлится 4 отверстия на равном расстоянии от центра
Жду совета в чем дело
Говорящий Огурец
Сильно не вникал в код, но какая-то у вас, на первый взгляд, мешанина: и разворот СК планом, и работа через контроль кончика инструмента в М128...
