Проблемы с 5 осевой обработкой на DMU DMG
elmar_fsapr2000
elmar_fsapr2000
Доброго времени суток.
Решили попробовать 3+2 обработку на DMU DMG monoblock со стойкой Heidenhain ITNC 530
Программируем в POWERMILL. Постпроцессор опробован на аналогичном станке, то есть рабочий
Выводит коды с 19м циклом.
BEGIN PGM 1 MM
BLK FORM 0.1 Z X-75.6 Y-75.6 Z-17.05
BLK FORM 0.2 X75.6 Y75.6 Z0.0
L M129
LBL 170
CYCL DEF 7.0 DATUM SHIFT
CYCL DEF 7.1 X0.0
CYCL DEF 7.2 Y0.0
CYCL DEF 7.3 Z0.0
CYCL DEF 19.0 WORKPLANE
CYCL DEF 19.1
LBL 0
; TOOL NUMBER : 7
; TOOL TYPE   : DRILL
; TOOL ID     : 2
; TOOL DIA. 6.250  LENGTH 70.000
TOOL CALL 7 Z S1500 DL+0.0 DR+0.0
M135
CYCL DEF 32.0 TOLERANCE
CYCL DEF 32.1 T0.100
CYCL DEF 32.2 HSC-MODE:0 TA0.5
L M03
L M129
CALL LBL 170
CYCL DEF 7.1 IX+0.0
CYCL DEF 7.2 IY+0.0
CYCL DEF 7.3 IZ+0.0
CYCL DEF 19.0 WORKING PLANE
CYCL DEF 19.1 A+0.0 B-0.375 C+0.0
L B-0.375 C0.0 F1000 M126
; TOOLPATH  : 1
; WORKPLANE : 1
L M08
L X-0.056 Y+0.0 F3000
L X+0.488 Y+70.210
L Z+5.654
L Z-17.074 F1000
L Z+10.495 F3000
L M127
CALL LBL 170
; BEGIN RTCP SECTION
L M128
L X+0.419 Y+70.210 Z+10.498 B-0.375 C0.0
L X+0.125 Y+0.0 Z+10.495 C-180.0
; END RTCP SECTION
L M129
CALL LBL 170
CYCL DEF 7.1 IX+0.0
CYCL DEF 7.2 IY+0.0
CYCL DEF 7.3 IZ+0.0
CYCL DEF 19.1 A+0.0 B+0.375 C+0.0
L B-0.375 C-180.0 F1000 M126
; TOOLPATH  : 1_1
; WORKPLANE : 2
L X+0.056 Y+0.0 F3000
L X-0.488 Y-70.210
L Z+5.654
L Z-17.074 F1000
L Z+10.495 F3000
L M127
CALL LBL 170
L M128
L X-0.419 Y-70.210 Z+10.498 B-0.375 C-180.0
L X+0.0 Y+0.125 Z+10.495 C-90.0
; END RTCP SECTION
L M129
CALL LBL 170
CYCL DEF 7.1 IX+0.0
CYCL DEF 7.2 IY+0.0
CYCL DEF 7.3 IZ+0.0
CYCL DEF 19.1 A-0.375 B+0.0 C+0.0
L B-0.375 C-90.0 F1000 M126
; TOOLPATH  : 1_1_1
; WORKPLANE : 3
L X+0.0 Y+0.056 F3000
L X+70.210 Y-0.488
L Z+5.654
L Z-17.074 F1000
L Z+10.495 F3000
L M127
CALL LBL 170
L M128
L X+70.210 Y-0.419 Z+10.498 B-0.375 C-90.0
L X+0.0 Y-0.125 Z+10.495 C90.0
; END RTCP SECTION
L M129
CALL LBL 170
CYCL DEF 7.1 IX+0.0
CYCL DEF 7.2 IY+0.0
CYCL DEF 7.3 IZ+0.0
CYCL DEF 19.1 A+0.375 B+0.0 C+0.0
L B-0.375 C90.0 F1000 M126
; TOOLPATH  : 1_1_1_1
; WORKPLANE : 4
L X+0.0 Y-0.056 F3000
L X-70.210 Y+0.488
L Z+5.654
L Z-17.074 F1000
L Z+10.495 F3000
L M09
L M127
CALL LBL 170
PLANE RESET STAY
L Z0.0 F MAX M92
L B0.0 C0.0 R0 F MAX M94
L M05
CYCL DEF 32.1
TOOL CALL 0
L M30
END PGM 1 MM
ИТД
Закидываем на станок и тут-то начинаются чудеса. Голова и система координат поворачивается нормально но инструмент сверлит отверстия не в нужном месте.
При разных углах обработки смещение разное. По программе должны сверлится 4 отверстия на равном расстоянии от центра
Жду совета в чем дело
Говорящий Огурец
Сильно не вникал в код, но какая-то у вас, на первый взгляд, мешанина: и разворот СК планом, и работа через контроль кончика инструмента в М128...
Ander
На такой вопрос может быть только один ответ - ждите, помощь идёт.
elmar_fsapr2000
Ждать то ждем, но и сами не сидим сложа руки. правда пока безрезультатно
      На Западе иная концепция. Мне доводилось проектировать фундаменты для больших станков из железобетона. Там изготовитель станков давал просто план приямков и всяких закладных. И требования на прогибы. При стотонной нагрузке приложенной в некоторых точках прогиб в других точках 0.5 мм. Они размещают такое оборудование в горах на скалах и там нет проблем, а мы , чтобы спасти гидроэнергетику страны, должны были разместить на берегу Невы в болоте, по существу .  Ничего справились :)
    • Plumber
      Не знаю, какая цель преследуется при использовании данного инструмента, но повторюсь - SW не совсем та программа, в которой необходимо делать подобные манипуляции. Для качественной векторизации растровых исходников, лучше всего использовать инструменты, которые это делают намного лучше, к примеру CorelDRAW.
      Если у вас нет dual safety check то и кнопка вам не нужна в противном случае  она как правило активирована Ее можно временно отключить но для этого нужно знать пароль 3225 если он введен то изменить 1902 параметр не удастся.   А также нужно удалить DSC ладдер  иначе будет ошибка
    • alex0800
      G54 G40 G49 G80 G90 #1=124.0 #2=120.0 #3=60.0 #4=105.0 #5=[COS[#3]*#2] #6=[SIN[#3]*#2] #7=[COS[#3]*#4] #8=[SIN[#3]*#4] T1M6 G0X-[#1+20] Y0.0 S4000M3  G43 Z30.0 H1 G1 Z3.0F2000 G1 Z-15.0 F1000 G41 Y-20.0F2000D1 G3X-#1 Y0.0 R20.0 G2 X0.0 Y#1 R#1 G2X#1 Y0.0 R#1 G2X0.0 Y-#1 R#1 G2 X-#1 Y0.0 R#1 G1 X-[#1+20.] Y20. G0 Z30.0 G40 T2M6  S4000 M3 G0 X0.0 Y110.0 G43 Z30.0 H2 M97 P100  G68 X0.0 Y0.0 R-90.0 M97 P100 G68 X0.0 Y0.0 R-180.0 M97 P100  G68 X0.0 Y0.0 R-270.0 M97 P100 G69 G28 X0Y0Z100. M30 N100 G0 X0.0 Y100.0 G1 Z-1.5 F1000 G1 Y#2 G0 Z5.0 G0 X#7 Y#8 G1 Z-1.5 F1000 G1 X#5 Y#6 G0 Z5.0 G0 X-#5 Y#6 G1 Z-1.5 G1 X-[#7] Y#8 G0 Z5 m99
    • davidovka
      А кнопка "Правит таблицу ссылок" серая как будто нажата? Иногда при проблемах с окнами помогает Файл - Опции - Настройки окна - Сброс расположения панелей
      А почему она замирает именно при редактировании циклов вы не находите это странным? Во все других режимах ведет себя нормально?
    • shodan
      Мда..."засорять эфир" нечитабельными картинками...это некорректно как минимум.
    • shodan
      Самая подробная информация на сайтах  www.exaflow.de и www.i-mold.com. Там же можно скачать и 3D-модели литников.
    • Chuk
      У кого был глюк (или это не глюк) при попытке замены компонента в сборке на несвязанный - при попытке вызова таблицы ссылок для привязок ничего не происходит.  Само окно тупо не появляется.
      22 ошибка по памяти, надо произвести снова сброс и инициализацию параметров, при условии исправной батареи.  Ошибка 274 Futterspannung, возможно надо подвинуть один сенсор на прижимной цилиндре патрона. Находятся в задней части шпинделя 2 штуки. Оба должны светится.
