Эйлеровский нагрев пластины
Здравствуйте.
Решил на досуге порешать простенькую задачу нагрева пластины по примеру из видео отсюда. Делал абсолютно одинаково(видимо нет).
Целый день сижу, не могу найти ошибку. Как это может быть недостаточно закреплений для термической задачи? Что-же это? На скрине элемент с ошибкой который  сидит в самой глубине.
large.1538175138_.JPG.b1cf3ffdcef8e3600e
"Solver pivot warnings or errors have been encountered during the solution.  This is usually a result of an ill conditioned matrix possibly due to unreasonable material properties, an under constrained model, or contact related issues.  Check results carefully."
"A solver pivot warning or error has been detected in the TEMP degree of freedom of node 26520 located in Solid. This is usually a result of an ill conditioned matrix possibly due to unreasonable material properties, an under constrained model, or contact related issues."  "Check results carefully. You may select the offending object and/or geometry via RMB on this warning in the Messages window."
"The model has no temperature, convection, or radiation conditions specified. One such specification is needed to enable a meaningful solution.  Please check your results carefully."
"The unit system of Command object(s) such as  Steady-State Thermal>Commands (APDL) at the time of creation, differs from the solver unit system.  Check your data and results accordingly."
unsaved_project--Steady-State Thermal (B4)
          ***** ANSYS ANALYSIS DEFINITION (PREP7) *****
 *********** Nodes for the whole assembly ***********
 *********** Elements for Body 1 "Solid" ***********
 *********** Send User Defined Coordinate System(s) ***********
 *********** Send Materials ***********
 ***************** Define Uniform Initial temperature ***************
 ***** ROUTINE COMPLETED *****  CP =         2.578
 --- Number of total nodes = 155021
 --- Number of contact elements = 0
 --- Number of spring elements = 0
 --- Number of bearing elements = 0
 --- Number of solid elements = 36000
 --- Number of condensed parts = 0
 --- Number of total elements = 36000
 *GET  _WALLBSOL  FROM  ACTI  ITEM=TIME WALL  VALUE=  17.8197222
 *************************    SOLUTION       ********************************
 *****  ANSYS SOLUTION ROUTINE  *****
 PERFORM A STATIC ANALYSIS
  THIS WILL BE A NEW ANALYSIS
 CONTACT INFORMATION PRINTOUT LEVEL       1
 DO NOT SAVE ANY RESTART FILES AT ALL
 DO NOT COMBINE ELEMENT MATRIX FILES (.emat) AFTER DISTRIBUTED PARALLEL SOLUTION
 DO NOT COMBINE ELEMENT SAVE DATA FILES (.esav) AFTER DISTRIBUTED PARALLEL SOLUTION
 ******************* SOLVE FOR LS 1 OF 1 ****************
 USE AUTOMATIC TIME STEPPING THIS LOAD STEP
 USE       1 SUBSTEPS INITIALLY THIS LOAD STEP FOR ALL  DEGREES OF FREEDOM
 FOR AUTOMATIC TIME STEPPING:
   USE     10 SUBSTEPS AS A MAXIMUM
   USE      1 SUBSTEPS AS A MINIMUM
 TIME=  6.0000
 ERASE THE CURRENT DATABASE OUTPUT CONTROL TABLE.
 WRITE ALL  ITEMS TO THE DATABASE WITH A FREQUENCY OF NONE
   FOR ALL APPLICABLE ENTITIES
 WRITE NSOL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE RSOL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE EANG ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE VENG ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE FFLU ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE CONT ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 CONVERGENCE ON HEAT BASED ON THE NORM OF THE N-R LOAD
   WITH A TOLERANCE OF 0.1000E-02 AND A MINIMUM REFERENCE VALUE OF 0.1000E-02
   USING THE L2 NORM (CHECK THE SRSS VALUE)
 ACTIVE COORDINATE SYSTEM SET TO         0  (CARTESIAN)
 ALSO SELECT ALL COMPONENTS
 *GET  EMAX      FROM  ELEM  ITEM=NUM  MAX       VALUE=  36000.0000
 *GET  EMIN      FROM  ELEM  ITEM=NUM  MIN       VALUE=  1.00000000
 SELECT ALL ENTITIES OF TYPE= ALL  AND BELOW
 PARAMETER QL =     1260.000000
 PARAMETER R0 =    0.6000000000E-02
 PARAMETER D =    0.5000000000E-02
 PARAMETER PI =     3.141000000
 PARAMETER ALPHA =     80.00000000
 PARAMETER VEL =    0.5000000000E-02
 PARAMETER TAU =     0.000000000
 PARAMETER R =    0.3000000000
 PARAMETER TIME_WELD =     6.000000000
 PARAMETER TIME_INC =    0.1000000000
 PARAMETER TIME_STEPS =     60.00000000
 USE THE FULL NEWTON-RAPHSON OPTION FOR  ALL DEGREES OF FREEDOM
   AND USE THE DEFAULT ADAPTIVE DESCENT OPTION
 *DO LOOP ON PARAMETER= I FROM  1.0000     TO  60.000     BY  1.0000
 PARAMETER WTIME =    0.1000000000
 TIME= 0.10000
 PARAMETER MCENTER =    0.5000000000E-03
 *DO LOOP ON PARAMETER= JJ FROM  1.0000     TO  36000.     BY  1.0000
 PARAMETER X =     1.966666667
 PARAMETER Y =   -0.5000000000E-01
 PARAMETER Z =   -0.3333333333E-01
 PARAMETER CSI =    0.3283333333E-01
 PARAMETER QLB =     0.000000000
 SPECIFIED BODY FORCE HGEN FOR ELEMENT       1 AT STARTING LOCATION      1
    0.00000000      0.00000000      0.00000000      0.00000000
 *ENDDO  INDEX= JJ
 *** NOTE ***                            CP =       6.891   TIME= 17:49:14
 The automatic domain decomposition logic has selected the MESH domain
 decomposition method with 6 processes per solution.
 *****  ANSYS SOLVE    COMMAND  *****
 *** WARNING ***                         CP =       6.891   TIME= 17:49:14
 Element shape checking is currently inactive.  Issue SHPP,ON or
 SHPP,WARN to reactivate, if desired.
 *** NOTE ***                            CP =       6.938   TIME= 17:49:14
 The model data was checked and warning messages were found.
  Please review output or errors file (
 C:\Users\3D\AppData\Local\Temp\WB_3D_3D_7492_2\_ProjectScratch\Scr9154\
 \file0.err ) for these warning messages.
 *** ANSYS - ENGINEERING ANALYSIS SYSTEM  RELEASE 2019 R3          19.5     ***
 DISTRIBUTED ANSYS Mechanical Enterprise
 01071875  VERSION=WINDOWS x64   17:49:14  DEC 21, 2021 CP=      6.953
                       S O L U T I O N   O P T I O N S
   PROBLEM DIMENSIONALITY. . . . . . . . . . . . .3-D
   DEGREES OF FREEDOM. . . . . . TEMP
   ANALYSIS TYPE . . . . . . . . . . . . . . . . .STATIC (STEADY-STATE)
   OFFSET TEMPERATURE FROM ABSOLUTE ZERO . . . . .  273.15
   NEWTON-RAPHSON OPTION . . . . . . . . . . . . .FULL
   GLOBALLY ASSEMBLED MATRIX . . . . . . . . . . .SYMMETRIC
 *** NOTE ***                            CP =       7.234   TIME= 17:49:15
 The conditions for direct assembly have been met.  No .emat or .erot
 files will be produced.
     D I S T R I B U T E D   D O M A I N   D E C O M P O S E R
  ...Number of elements: 36000
  ...Number of nodes:    155021
  ...Decompose to 6 CPU domains
  ...Element load balance ratio =     1.000
                      L O A D   S T E P   O P T I O N S
   LOAD STEP NUMBER. . . . . . . . . . . . . . . .     1
   TIME AT END OF THE LOAD STEP. . . . . . . . . . 0.10000
   AUTOMATIC TIME STEPPING . . . . . . . . . . . .    ON
      INITIAL NUMBER OF SUBSTEPS . . . . . . . . .     1
      MAXIMUM NUMBER OF SUBSTEPS . . . . . . . . .    10
      MINIMUM NUMBER OF SUBSTEPS . . . . . . . . .     1
   MAXIMUM NUMBER OF EQUILIBRIUM ITERATIONS. . . .    15
   STEP CHANGE BOUNDARY CONDITIONS . . . . . . . .    NO
   TERMINATE ANALYSIS IF NOT CONVERGED . . . . . .YES (EXIT)
   CONVERGENCE CONTROLS
      LABEL   REFERENCE    TOLERANCE  NORM     MINREF
       HEAT    0.000       0.1000E-02   2     0.1000E-02
   PRINT OUTPUT CONTROLS . . . . . . . . . . . . .NO PRINTOUT
   DATABASE OUTPUT CONTROLS
      ITEM     FREQUENCY   COMPONENT
       ALL       NONE
      NSOL        ALL
      RSOL        ALL
      EANG        ALL
      VENG        ALL
      FFLU        ALL
      CONT        ALL
 SOLUTION MONITORING INFO IS WRITTEN TO FILE= file.mntr
            **** CENTER OF MASS, MASS, AND MASS MOMENTS OF INERTIA ****
  CALCULATIONS ASSUME ELEMENT MASS AT ELEMENT CENTROID
  TOTAL MASS =  0.12560E-06
                           MOM. OF INERTIA         MOM. OF INERTIA
  CENTER OF MASS            ABOUT ORIGIN        ABOUT CENTER OF MASS
  XC =  0.31612E-15      IXX =   0.3348E-06      IXX =   0.8358E-07
  YC =  -1.0000          IYY =   0.3348E-06      IYY =   0.2092E-06
  ZC =  -1.0000          IZZ =   0.3348E-06      IZZ =   0.2092E-06
                         IXY =  -0.1588E-21      IXY =  -0.1985E-21
                         IYZ =  -0.1256E-06      IYZ =   0.7815E-20
                         IZX =  -0.2118E-21      IZX =  -0.2515E-21
  *** MASS SUMMARY BY ELEMENT TYPE ***
  TYPE      MASS
     1  0.125600E-06
 Range of element maximum matrix coefficients in global coordinates
 Maximum = 5.29584373 at element 1793.
 Minimum = 5.29584361 at element 27617.
   *** ELEMENT MATRIX FORMULATION TIMES
     TYPE    NUMBER   ENAME      TOTAL CP  AVE CP
        1     36000  SOLID90       1.359   0.000038
 Time at end of element matrix formulation CP = 7.8125.
     HT FLOW CONVERGENCE VALUE=  0.5473E+60  CRITERION=  0.5473E+57
 DISTRIBUTED SPARSE MATRIX DIRECT SOLVER.
  Number of equations =      155021,    Maximum wavefront =     81
  Local memory allocated for solver              =    208.329 MB
  Local memory required for in-core solution     =    182.481 MB
  Local memory required for out-of-core solution =     59.621 MB
  Total memory allocated for solver              =   1444.064 MB
  Total memory required for in-core solution     =   1262.874 MB
  Total memory required for out-of-core solution =    425.737 MB
 *** NOTE ***                            CP =       9.172   TIME= 17:49:17
 The Distributed Sparse Matrix Solver is currently running in the
 in-core memory mode.  This memory mode uses the most amount of memory
 in order to avoid using the hard drive as much as possible, which most
 often results in the fastest solution time.  This mode is recommended
 if enough physical memory is present to accommodate all of the solver
 data.
 Distributed sparse solver maximum pivot= 21.1833747 at node 129892
 TEMP.
 Distributed sparse solver minimum pivot= 1.479657598E-11 at node 26520
 TEMP.
 Distributed sparse solver minimum pivot in absolute value=
 1.479657598E-11 at node 26520 TEMP.
 *** ERROR ***                           CP =      11.250   TIME= 17:49:19
 There is at least 1 small equation solver pivot term (e.g., at the TEMP
 degree of freedom of node 26520).  Please check for an insufficiently
 constrained model.
 NUMBER OF WARNING MESSAGES ENCOUNTERED=          1
 NUMBER OF ERROR   MESSAGES ENCOUNTERED=          1
 ***** PROBLEM TERMINATED BY INDICATED ERROR(S) OR BY END OF INPUT DATA *****
+--------- D I S T R I B U T E D   A N S Y S   S T A T I S T I C S ------------+
@Jesse это если модель склеена по общим узлам. А если не склеена то тоже будет деление на ноль. И нужно записать уравнения для температур, для статики записать уравнения для перемещений, для динамики ...
Лучше сразу делать модель по общим узлам.:biggrin:
3 часа назад, Aldar сказал:
приложил сам расчет. Может кто найдет ошибку.
1 variant eror element.zip 1 \u041c\u0431 · 2 скачивания
1 минуту назад, Aldar сказал:
Да кому этот ваш расчет нужен. У нас тут уже такое обсуждение теории решения тепловых задач пошло, что и без вас весело.
52 минуты назад, ДОБРЯК сказал:
задавал и температуру и конвекцию, на всякий единицы измерения. чет не идет...
22.12.2021 в 08:39, Aldar сказал:
1 variant eror element.zip 1 \u041c\u0431 · 5 скачиваний
Вопросов, как обычно, больше чем ответов. Что вы пытаетесь смоделировать?
У вас там написана внушительная командная вставка. Вы её сами писали, или скопировали откуда-то? Понимаете, что там у вас происходит?
Вот например, один из конкретных вопросов к коду. Откуда возьмётся значение i для расчёта WTIME, если цикл закомментирован?
Или другой. Вы прикладываете тепловыделение через BFE. Никаких других граничных условий нет, стока теплоты нет, задача стационарная. Ответьте сами, какое равновесное тепловое состояние брусочка, тепло в который приходит и никуда не уходит?
3 минуты назад, Graf Kim сказал:
Это было понятно с самого начала. Но ТС пишет, что
1 час назад, Aldar сказал:
И та же ошибка...:biggrin:
21.12.2021 в 14:13, Aldar сказал:
закрепления - это граничные условия первого рода - граничные условия, задающие конкретные величины искомых степеней свободы. в тепловой задаче это температуры.
или словами Добряка - действительно, нет точки отсчета.
словами графа - нет стока тепла.
23.12.2021 в 12:39, Aldar сказал:
чет не верится.
  • 4 месяца спустя...
О, забыл про эту тему. Чтобы решить его, использовал ansys apdl, там почему то идет. А в workbech не пошло. Не стал искать причину.
ps не правильно тема была, надо было "гауссово распределение тепла" а не Эйлерово, извините
