840D mmc100.2 waiting for communicating partners
Hello,
I am Moez from Tunisia
I bought a second hand machine (Finnpower SG6 punching machine), the machine was dismantled and then reassembled, and in between the machine was stored about two years. The machine was in working condition before dismantling.
Now, upon power up the machine the screen goes black and says "MMC100.2 version 04.04.22 waiting for communicationpartners " and all LED's on Machine control panel (MCP) will flash.
The NCU is NCU 573.2 / 32MB 6FC5357-0BB33-0AE1
Attached a short video showing the screen when I turn on the machine.
https://youtu.be/R71KAeXGt9U
https://youtu.be/W4jFluomhEw
https://youtu.be/rocSytM4a6k
Please can you help me to make this machine works?
Thank you.
19 часов назад, Moez сказал:
If you have a backup for NC and PLC, then you need to clear NC and PLC
When you say "Clean", you mean NC & PLC Clear?
Like this...
1. Set S3 on the 840D NCU to position #1
2. Power on control.
3. When the control is fully powered up Press the “Reset” pushbutton on the 840D NCU
4. Wait for display on NCU to show #6
5. Set S3 to 0 and push the “Reset” pushbutton.
6. Wait for display on NCU to show #6
7. Turn S4 to Position #2 - PS LED is ON.
8. Turn S4 to Position #3 - PS LED is OFF.
9. When PS LED comes on turn S4 to Position #2 then immediately back to position #3.
10. PS LED should now be blinking.
11. Set S4 to position #0. – PR LED should go to a solid green after a few seconds.
** If it is not procedure was not done correctly. Repeat PLC steps #1 through 4.**
12. Set S4 to position #2
13. Press “Reset” pushbutton on 840D.
Then restore your archives!
Thanks you, I tried as indicating, it seems one is clean but the other is not, I have one green light and one red light ps is red.
Still no communication with the mmc100.2.
Still message waiting for communicating partners...
Please what shall I do.
Thank you.
18 часов назад, Moez сказал:
Send photos of the CNC state after power-on and when the message "waiting communicationpartners" appears on the MMC 100.2 screen.
Examine the status of your LEDs especially the status of the PLC according to the instructions in the attached file.
NCU Info.ZIP
    • ValeryMoscow
      подскажите пожалуйста, как запустить оболочку 3dexperience ?   никогда этим не пользовался
      Хороший фильм, сильно недооценённый всюду в мире.
      Проверяйте в работе. to dxf(mod_by_Snake-60_v01).swp Два нуля - это Имя вашей текущей конфигурации. Макрос сохраняет все существующие конфигурации и если убрать ее имя из названия, то он будет перезаписывать все файлы и останется только один, с непонятно-какой конфигурацией. Можно сделать чтобы он убирал только нулевую и По умолчанию, а остальные сохранял. Сделать так?
    • mikityuk2402@gmail.com
      Я не хочу нарушать конструкцию программы! Я наладчик. Программы для меня пишет программист который не особо горит желанием корректировать постпроцессор! В день по 3-4 программы отрабатываю по 10-15 инструментов в программе и вручную редактировать каждую нет времени. Если знать переменную которая отвечает за преднабор инструмента то можно было б не нарушать структуру программы! Куда еще больше вводной информации! Мне нужна переменная которая бы записала номер инструмента который будет следующий по программе допустим в переменную #100=#"номер инструмента который стоит в преднаборе"! Все!!! Если Вы ее не знаете, то так и скажите!
      @vovanheisvladimir Солид не сертифицирован на работу с игровыми видеокартами - это раз (Это не значит, что он не будет на них работать, у самого дома старенькая GTX 660) . И новые драйвера - это не значит лучшие - это два. Попробуйте хотя бы другие драйвера поставить...
    • vovanheisvladimir
      Так видеокарта GTX 1660 super, драйвера новые, тянет все новые игры а тут с какими то буквами позиции сдаёт. У меня была такая проблема на работе, с таким же солидом. Но видеокарта там была 1650.
      Очень похоже на проблему с видеокартой или ее драйверами...
    • Arkhipkin_Pavel
      Всем привет! возникла проблема с траекторией сверления. проблема заключается в том что необходим определенный порядок обработки, из того что предлагает арткам в авто режиме ничего не подходит, а функция вручную постоянно выдает ошибку. в стратегии обработки по профилю таких проблем не было с ручным определением через вектор который является путем порядка обработки, а со сверление определить вручную не выходит, кто сталкивался? есть ли какие решения или это баг програмы? всем спасибо!  В качестве примера на изображении указан путь по которому необходимо произвести сверление, но вопреки указанному пути арткам все дела
    • Кварк
      По мне, так их везде хватает. Однако, свой станок я собрал благодаря подсказкам оттуда. Правда, были товарищи, которые говорили, что у меня ничо не получится, это напрягало. Но таких везде хватает. Там объективно больше информации. Хотя, может и тут подскажут. Что я знаю, поделюсь.
      Еще один вариант - сохранить сборку (.SLDASM) как деталь (.SLDPRT)
