Получение TCComponent
pixel009
Добрый день! Подскажите, пожалуйста, как можно получить TCComponent по GUID или имени при написании плагина??
DataManagementService..::.LoadObjects
Teamcenter Component:
SOA Framework - The framework to expose the Teamcenter services to the clients. The framework provices the means to define service interfaces (through BMIDE) and exposes those in Java, C++, C# client bindings. The Session service is part of the framework.
Namespace:  Teamcenter.Services.Strong.Core
Assembly:  TcSoaCoreStrong (in TcSoaCoreStrong.dll)
C#
public virtual ServiceData LoadObjects(
    string[] Uids
Example:
DataManagementService dms = DataManagementService.getService(appSession.getConnection());
ServiceData loadObjectsResponse = dms.LoadObjects(new string[] {uid1, uid2});
for(int i = 0; i < loadObjectsResponse.sizeOfPlainObjects(); ++i) {
    ModelObject modelObject=(ModelObject)loadObjectsResponse.GetPlainObject(i));
    • streamdown
