Biofuel Machine
Helengriffin11
wood briquette making machine
What is wood briquette machine?
Wood briquette machine is used for making cylindrical, cuboid or hexagonal rod briquettes from biomass waste like wood, sawdust, grass, hay, cotton stalk, and other crop waste, etc. The biomass briquettes are widely used as biofuel for heating industrial boiler, producing electricity from steam in power plants, BBQ, and so on. The biomass briquettes are often carbonized into charcoal for easy storage and transportation as well as high combustion rate.
The application of wood briquette :
Technical  parameter :
NoManufacturerJingsu Kingwood Industrial
1Model No.JWZL688
2Capacity2.5-3T/H
3Mainly motor200 KW
4Lubrication pump motor0.37KW
5Cutter motor3KW
6Cooling motor2.2KW
7TypeHorizontal ring die
8Dimension of machine3530-1580-2390mm
9Weight of machine9.5t/h
10Output pellets diameter4mm, 6mm, 8mm, 10mm,as you request
11Length of pellets1-10cm,as you request
12Pellets density1.0-1.4g/cm3
13Suitable materialsWood, Sawdust, Rice husk, EFB, Palm fiber, Sunflower husk, Stalk, Grass….
The process of wood briquette making machine
Kingwood factory :
1) Quality control
2) Installation and debuggingBiofuel Machine
website:http://www.kingwood-china.com/biomass-pellet-mill-machine/biofuel-machine/
