ABI Research Names PTC a Leader in Enterprise Augmented Reality Platforms
Powerful and Class-Leading, PTC’s Vuforia Recognized for Its Strength in Innovation and Implementation BOSTON --(BUSINESS WIRE)--Nov. 14, 2019-- PTC (NASDAQ: PTC) today announced it has been named a leader in the Enterprise Augmented Reality Platforms market for its Vuforia ® augmented reality (AR)
Просмотр полной статьи
    • kkk
    • karlf
    • YuriySt54
