I have a Cybelec DNC80 but i have problem with it when i turn on  and work with machine (press brake) some times switch off by itself
i think the problem come from  power supply because when the machine start work i get 5v from power but when switch of there is no (see the picture) i ask for this problem come from power supply or other thing and how repair it.tbco4444.jpg
You have to check if the voltage comes physically through the wire to this block not only to see at the indication LED.
After that, you can write the result down here.
Disconnect the wire after the light on the LED disappears and measure a voltage directly on the wire without load. How many volts shows your measuring device now?
Dear/Tad
i need your help
as I told before that we have a problem in the power supply. so we give the power supply to local electronic stores to repair it but when we installing a short circuit occurred.
See attached picture(1) after that he cancel six wires go out from power supply see attached picture (2)
the software run but the machine do not go on because we have problem in board for press brake see attached picture (3)  .
how we can get new one or repair it and is their documentation for it ,can you help me.
