Wildfire 3
Finist
Установил сегодня новую вышедшую версию F000, опять была задница с лицензией :blink: , пришлось заново вытаскивать с сайта PTC.
Вручена награда читаем правила п15
2 all Заканчивайте с кряками.
Изменено пользователем Booster
2zeppelin
Description
Granite-based Cross-Release Interoperability (referred to hereafter as GCRI) was developed based on PTC’s Granite Interoperability Kernel. The Granite Kernel, the fundamental cornerstone of Pro/ENGINEER’s geometry model, is a software library that has the ability to read (or write) geometry, geometry attributes, layer information, user-defined parameters, and assembly structure from (or to) a Pro/ENGINEER part (.prt) or assembly (.asm) file without Pro/ENGINEER being present.
PTC has created a Granite plug-in module to replace the neutral file approach to cross-release interoperability in Pro/ENGINEER Wildfire 3.0. This plug-in module can be provided to a Wildfire 2.0 user and, when installed in the Wildfire 2.0 loadpoint, will allow that Wildfire 2.0 user to read the Wildfire 3.0 model directly via Granite. This is without the need for the Wildfire 3.0 user to create an intermediate neutral file. All of the information that can be read from the Pro/ENGINEER model by the Granite kernel can now be leveraged by the Wildfire 2.0 user.
A unique feature of GCRI is the ability of Wildfire 3.0 users to take new features that have been added to the image model by the Wildfire 2.0 user and graft those features onto the original, fully-featured master model. This is very similar to how a UDF works, except references need not be selected for the UDF to be placed; GCRI functions handle this placement automatically.
Additional Information
GCRI Setup
Before setting up GCRI, the application component "readnewermodels.dll", which is not yet shipped to customers, will need to be obtained. Please contact Asa Trainer, Product Management, PTC (atrainer@ptc.com, 781-370-6258) in order get access to a ProjectLink project to download and evaluate this capability. The subject of any emails should be "GCRI".
Note that GCRI is currently only available for Windows and Sun platforms.
Additional information can be found in the GCRI White Paper which is also available (and will be continually updated) in the aforementioned ProjectLink project.
1) Obtain the Wildfire 3.0 "readnewermodels.dll" application component and place this application component in the <machine_type>/obj directory below the Wildfire 2.0 loadpoint as shown below.
For example: <loadpoint>/i486_nt/obj/readnewermodels.dll
2) Add the following config options to the Wildfire 2.0 config.pro PRIOR to launching Wildfire 2.0.
topobus_enable yes
atb_show_log off
atb_auto_check_on_update off
atb_auto_check_on_retrieve on
3) Add the following config option to the Wildfire 3.0 config.pro PRIOR to launching Wildfire 3.0.
cri_grafting_enable yes
4) Launch Wildfire 2.0 and check to see that the #File > #Associative Topology Bus is available.
5) Validate the installation by checking for the following:
When a Wildfire 3.0 model is retrieved in Wildfire 2.0, the message "You are opening a Pro/ENGINEER Part created in Pro/E Wildfire 3.0. Would you like to proceed opening it as a granite model?".
After retrieving a Wildfire 3.0 model in Wildfire 2.0, select any feature, RMB > #Info > #Feature. Under the "Comments" section, the message "FEATURE IS READ-ONLY" is displayed.
GCRI Operational Use
There are three elements in the workflow for GCRI. They are:
1) The reading of a newer release model into an older release;
2) The use of ATB functionality to check the status of a model read using GCRI or updating such a GCRI model to match its master model;
3) The grafting of features, added to the GCRI model, back onto the master model from which it was created.
Reading a Wildfire 3.0 model into a Wildfire 2.0 Session:
Select #File > #Open. From within the File Open dialog, select any Pro/ENGINEER part or assembly file for opening. If the user selects a part or assembly that is either Wildfire 2.0 or earlier, it will be read into session directly. If a Wildfire 3.0 part or assembly file is selected, the normal error message, “<model_name> cannot be retrieved”, will be replaced by the message "You are opening a Pro/ENGINEER Part created in Pro/E Wildfire 3.0. Would you like to proceed opening it as a granite model?", indicating that the model is a GCRI model, and asking for confirmation to open it. This confirmation is simply to inform the user that they are opening a GCRI model, not a native one, and that certain model behavior and content differences exist between these two model types.
Performing an ATB Check Status or Update Operation:
Although the Wildfire 2.0 user does not own the fully featured model, the model can still be used for any other downstream use. Examples of such use include Pro/MECHANICA analyses, cable routing, manufacturing, annotation, rendering, or even the addition of new modeling features. Because of ATB associativity, rapid updating of the model based on changes made to its master model are handled quickly and easily.
The normal flow of operations here are to check the status of the GCRI model relative to its master model. Click #File > #ATB > #Check Status. The ATB functionality in Pro/ENGINEER will check the status of the Wildfire 2.0 image model relative to its Wildfire 3.0 master model. The result will be a change in the color of the ATB icon for that part from blue to red (and the presentation of a warning message in the message bar) if the model is out-of-date relative to its master model. The user can choose to act on that notification right away or simply wait until a more convenient time to perform the second operation, the update.
To update the model, click #File > #ATB > #Update. The ATB functionality will replace the existing Wildfire 2.0 image model with the latest version of the Wildfire 3.0 master model and reattach, automatically, any Wildfire 2.0 features added to the model. Similarly, any downstream uses of the updated image model (manufacturing, analysis, routing) will associatively update.
For more information the ATB and how to customize ATB operations using config settings, refer to the Pro/ENGINEER Help Center.
Grafting Features added in Wildfire 2.0 back onto the Wildfire 3.0 Master Model:
Once features are created in Wildfire 2.0 and the model is saved, those features can be grafted back onto the original Wildfire 3.0 model. Retrieve the original Wildfire 3.0 master model. Click #File > #Graft Features, and within the File Open dialog, select the Wildfire 2.0 image model that corresponds to the master model in session.
В WildFire3.0 можно сразу сохранить чертеж в PDF - Save as PDF. Только вот как установить при выводе толщину линий?
Так не сохраняет - вот и все впечатления...
<{POST_SNAPBACK}>
Странно.. :g:
Некоторое время назад где-то здесь (не нашел где) кто-то утверждал, что сохраняет.. с сохранением дерева модели.. :rolleyes:
<{POST_SNAPBACK}>
Именно в 2001 или это относится и к WF1, WF2 ?
Через "Сохранить копии" нету возможности выбирать формат сохранения. Да и врятли младшие версии поймут некоторые созданные фичеры в WF3.
Тупой машинный перевод части текста, представленного выше SVB:
Ptc создавал модуль гранита вставляемый для того чтобы заменить нейтральный подход к архива крест-vypuskaet interoperability в Pro/ENGINEER Wildfire 3.0. Этот вставляемый модуль можно снабдить потребитель Wildfire 2.0 и, после того как я устанавливан в loadpoint Wildfire 2.0, позволит тому потребителю Wildfire 2.0 прочитать модель Wildfire 3.0 сразу через гранит. Это без потребности для потребителя Wildfire 3.0 создать промежуточный нейтральный архив. Вся из информации можно прочитать от модели Pro/ENGINEER стерженем гранита могут теперь быть leveraged потребителем Wildfire 2.0.
Как можно понять, речь, похоже, идет только о WF2 и в том смысле, что нужно для него устанавливать какое-то дополнение, позволяющее читать и, возможно, редактировать файлы WF3.. :g:
....и, возможно, редактировать файлы WF3....
Увы....Без возможности.
Все улучшение только в том, что:
....без потребности для потребителя Wildfire 3.0 создать промежуточный нейтральный архив....
Вот соответствующий TPI:
TPI_132326.pdf
    • mactepnew
      Вот я тоже так думал, пока не столкнулся с обратным) Как еще столкнусь, пришлю скриншот. Хаос еще в том, что порядок в дереве построения весьма условный. операция, которая стоит перед групой, имеет бОльший timestamp(пардон, не знаю как это в переводе), чем эта группа, и выполняется позже. При этом все операции в группе имеют timestamp на пару сотен меньше и выполняются раньше, чем две группы, стоящие перед ней. Логика?  Если в эскизе все элементы определены, то можно поставить еще один размер (хочешь переопределить эскиз - да пожалста!), изменить его - и NX самостоятельно выберет, какой размер или ограничение отпустить и весь эскиз летит к чертям. Это ли не хаос?   Назовете хоть один CAD, которым можно пользоваться так? Любой из встреченных мной имеет много неочевидных нюансов, которые конечно не проявляются при выполнении университетского или базового курса. В Creo я на протяжении 5 лет находил всё новые фишки, которые не прописаны в документации. Огромная благодарность Ruslan за пояснения тонкостей. Даже Компас и Solidworks, которые считаются самыми дружественными, оказалось непросто обуздать, когда проходил собеседования и делал тестовые. А ведь университетский курс знал на отлично!   Возвращаясь к NX - вот сегодняшний пример. Утром деталь была оранжевая, единая. Изменил пару уклонов и толщин, стала желтая с элементами оранжевого и частично твердотельной, частично листовой. Я даже не знаю, как сформулировать вопрос в поддержку.
    • Mikhail_Podgornyj
      Добрый день, кто может поделиться SKF Bearing V1.6 (ANSYS App)? Заранее благодарен!
    • kkk
      Короче, как сделать автоматом не нашел. Раскрасил нужные грани нужными цветами. Затем на вкладке с цветом модели можно выбирать нужный цвет, тогда в модели выбираются грани, покрашенные этим цветом. Можно еще сохранить выбор этих граней, но смысла не вижу, т.к. все легко выбирается по цвету. Затем либо в инструменте Измерить смотрим площадь и как-то ее используем, либо можно макросом (что выкладывал Kir95 ) внести площадь в свойства (на вкладку Конфигурации). Можно еще внести выбранные грани в датчики, но как использовать их в свойствах не нашел.    Макрос прикрепляю.     Площадь выбранных граней в свойства.swp
    • IgnatvKudrin
      Для нашего производства требуются постоянно инструментальные пружины для штампов. Сейчас заказы обрабатываются довольно долго - до 2-х месяцев. А у нас сроки на штампы 1-2 месяца с испытанием, доработкой и т.п. Хотелось бы найти поставщика, у которого уже есть склад с данными пружинами или кто может доставить за 1 месяц.   Пружины стандартные по ISO, но на всякий случай приложил каталог. Вот список пружин, которые нужны очень срочно:   LR 32 x 44 - 1 шт. LR 25 x 51 - 2 шт. LB 63 x 89 - 7 шт. LB 32 x 102 - 10 шт. LB 32 x 89 - 20 шт. LB 32 x 76 - 12 шт. LB 32 x 51 - 6 шт. LB 25 x 127 - 9 шт.   Готов выслушать все предложения. Возможно даже есть те, кто сможет изготовить подобные пружины с такими же параметрами. 20231101.pdf
    • bubblyk
      Знатоки форума, подскажите, как смоделировать простую (на первый взгляд) задачу термомеханики в упругой постановке.   Есть брусок правильный формы ака кирпич, в котором генерируется НЕРАВНОМЕРНОЕ удельное тепловыделение (HGEN). Задняя и передняя поверхности конвективно охлаждаются с известными (но различными) коэффициентами теплоотдачи и температурами жидкости/газа. Свойства кирпича (теплофизика + механика) принимаются зависящими от температуры. Постановка - стационарная Собственно вопрос : как грамотно смоделировать температурное поле в кирпиче с учетом температурного расширения?   Исходный код приложил.     Надеюсь на коллективный разум и опыт! EPTH2D.mac p.s.   Если есть опыт решения этой задачи в Ansys WB, тоже можно сюда приложить командные вставки.
    • OutXL
      Это было давно использовал NC-Link  и данную инструкцию. The Maho.docx
    • Mikhail_Podgornyj
    • alexqwq10
      В данных корпусах ничего лишнего быть не должно. Максимум шпильки заземления, в количестве предусмотренном для конкретного корпуса. Рассматривал очень много подобных корпусов разных производителей и данная проблема актуальна для подавляющего большинства.
    • MFS
      Коллеги, приветствую, нужно штамповать на горячую из алюминиевого сплава (АК6 или около того) заготовки размером 280*180*12. Подскажите, пожалуйста, параметры пресса для такой заготовки - размеры, усилия. А есл дадите пример такой марки и модели, более менее подходящей для этой работы (нашего или импортного), то будет и еще лучше. Заранее спасибо!
