post processor update for tnc426 for creo
Dear experts i have a issue with my post processor .. every time i have to put this value in my gcode file.. please check attachment..i desperately need avoid this editing.. please help me
Regards
Fsa
    • Koels
    • Ninja
    • Ninja
    • Koels
    • Slavdos
