RAC Delta Generation
Krusty
Ребята, привет!
вот https://download.industrysoftware.automation.siemens.com/download-n.php/teamcenter/product_updates/Tools/RACDeltaGenerator_v1.zip
если кратко, штука позволяет вам получить дельту между текущей версией RAC-а и тем, что в апдейте, зачем? что бы сократить пакет обновки.
Several months ago you installed the Teamcenter 11.2 four-tier rich client to all of your Teamcenter
users' machines. In this example you have 1000 user machines located around the world in various sites.
Teamcenter 11.2.1 is now available and you want to update your 1000 user client machines with the
latest four-tier rich client software from the 11.2.1 kit. On average, this kit is about 122 MB in size. So,
you copy the 122 MB kit to each machine. Copying a 122 MB kit to 1000 machines consumes excessive
bandwidth while you are copying. Suppose you plan a downtime tomorrow and you start the copy too
late, not realizing the size of the kit. You might prepare for this by starting the copy weeks ahead of time
to get the files in place before your system downtime. All of this takes advanced planning when it
comes to updating your rich client machines.
The table below displays some examples of the size of Teamcenter kits for a series of Teamcenter
releases. You can see that the kit size starts at 122 MB and grows up to 173 MB in the Teamcenter
11.x.x series. If you are planning to upgrade to one of these releases, multiply the kit size by the number
of rich clients you have to estimate how much data needs to be copied to support the update.
Будет работать с 10 с 11 и с 12
Merry Christmas!
    • Siber
      Доброго времени суток. Ситуация: Есть две детали соединённые: сквозной паз-шип. Ширена шипа определяется шириной паза с учетом зазора, привязка размерами: стенка шипа-стенка паза. Но при изменении ширены паза, ширена шипа не меняется, а выносная линия размера привязанная к стенке паза "отклеивается" и остается на месте. В сборке где эти детали, в других местах встречается такая же беда. В общем, привязка есть но не работает. Подскажите пожалуйста, как решить эту болячку?
      если есть бэкап plc раздела то залейте чтобы исключить вероятность в разделе plc у меня например есть вот такие файлы они занимаются обслуживанием ключа   возможно также повредился файл регистрации ключа
    • karlf
      Посмотрю в понедельник. Ну а какова вообще вероятность того, что дело в ПО, а не в железе?
    • vladimir.songin
      Так между прочим, кто-то на форуме фотографии очень похожего преса показывал. У них в поле энкодера значение энкодера.   Вся электросхема пожалуста.  GLADIATOR E3A 115-33 schema elettrico.pdf
    • v-david
      Вы выбрали конфигурацию, но не активировали ее:       Set swCustPropMgr = CmpDoc.Extension.CustomPropertyManager(CompConfig) '------------------------------------------------------------------------------- lRetVal = CmpDoc.ShowConfiguration2(CompConfig) '-------------------------------------------------------------------------------     lRetVal = swCustPropMgr.Get4("Наименование", False, Val, ValOut)     If ValOut = Empty Then         Set swCustPropMgr = CmpDoc.Extension.CustomPropertyManager("")         lRetVal = swCustPropMgr.Get4("Наименование", False, Val, ValOut)
    • hlibhlib
      При двойном клике на имеющийся Размер для редактирования и последующем подтверждении действия слетают Настройки CAD на дефолт. ===> Бесит! Этого не было в предыдущих версиях. Может какие-то настойки нужны?  Сталкивался-ли кто с такой ситуацией?  Как выход из положения настроил линии и дуги в настройках Атрибутов. Вроде работает, но в меню Главная Цвет и ширина каркасной геометрии Дефолтная.
      Импортозамещение
      Нет, просто отключаете, и забываете о ней   Не надо ничего делать   Откуда приходит сигнал 24 вольта на 7 вход сервоусилителя? Фото другой страницы схемы
    • vladimir.songin
      То есть отключаю аналоговую обратную связь от аналогового входа, и подключаю вместо энкодера? Так не делал но сомнения у меня: Вход энкодера может  быть 12 или 5 вольт. У нас 12. Два пина питание, два пина Каналы A B соответственно, один пин REF (непонятно что он означает и как работает). Остальные соеденены вместе. На какие из них подавать аналаговый вход обратной связи дефлектора.  сигналы от энкодера приходят, проверял осцилографом на самом разьёме непосредственно на входе DM02, и некое значение уже могло бы отобразиться в поле энкодера при отключенном аналаговом входе.  Если отключить аналоговый вход, то видим единичку в обоих полях, но уже писал об этом.
