G200 drilling cycle with iso programming
fisa
This drilling cycle in iso programming format with G200 Q parameter..some my machine not accept this format even i change machine programming format from Heidenhain to iso..... when i transfer this program from pc to machine there is a error come on G200 line need help regarding the issue
Regards
Asif
It can be wrong values of Q-parameters. Try to copy full values from malual and check the result. I have no more idea about this...
Seems to be, this machine doesn't support G200 cycles... Too strange for Heidenhain CNC... May be "HELP" buttion contains some info about driling cycles using by this CNC?
Or canned cycles wasn't bought for you machine, like an option (if it possible). Or this cycles was turned off by setup.
Yes its looking strange.....but as manual says that you can easily change program format form Heidenhain to iso ...and we also want to make in ISO format.. I have post processor for this machine which already tested another same machine...i also tested most of program sequence on this machine but ... drilling is a issue.....one more thing when i chose ".H" file type for editing or as new program.all cycle definition hard and soft key is enable ..and i can call G200 cycle only in (.H) format file type..but all cycle definition soft and hard keys is disabled when i work on(.i) file type.... I don't know if there is some parameter to enable G200 series cycle for iso programming..or something else.. still struggling..
Regards
