G200 drilling cycle with iso programming
fisa
This drilling cycle in iso programming format with G200 Q parameter..some my machine not accept this format even i change machine programming format from Heidenhain to iso..... when i transfer this program from pc to machine there is a error come on G200 line need help regarding the issue
Regards
Asif
It can be wrong values of Q-parameters. Try to copy full values from malual and check the result. I have no more idea about this...
Seems to be, this machine doesn't support G200 cycles... Too strange for Heidenhain CNC... May be "HELP" buttion contains some info about driling cycles using by this CNC?
Or canned cycles wasn't bought for you machine, like an option (if it possible). Or this cycles was turned off by setup.
Yes its looking strange.....but as manual says that you can easily change program format form Heidenhain to iso ...and we also want to make in ISO format.. I have post processor for this machine which already tested another same machine...i also tested most of program sequence on this machine but ... drilling is a issue.....one more thing when i chose ".H" file type for editing or as new program.all cycle definition hard and soft key is enable ..and i can call G200 cycle only in (.H) format file type..but all cycle definition soft and hard keys is disabled when i work on(.i) file type.... I don't know if there is some parameter to enable G200 series cycle for iso programming..or something else.. still struggling..
Regards
    • EDYARD
      Добрый день! Есть клон и есть заводской CD. TNC надо уточнить, но они в принципе 400 и430 одинаковы.
    • Fixidea
      Там нет зубьев, это гладкий кулачёк   Причём. Конструкция складывается, пружины растягиваются, сила возрастает, задача профиля кулачка компенсировать и сделать момент постоянным   Все размеры и схема присутствуют в методичке. У меня такая же схема, только размеры отличаются.   Не хочу, это совсем другое   УКВЗ не работает на Феликса
    • Artas28
      Добрый день! 1)Как в NX сделать стандартную дюймовую резьбу в модели? Какая из них стандартная? 2) Как резьборезной её изготовить? резьба 1/4, 19 ниток на дюйм, шаг 1,337.  Для отверстия, указываю наружный диаметр 13.158 и шаг по Z 1.337? Резьбофреза 55 градусов. Оно?
      Чтобы подбирать другой, надо бы снять параметры со старого. Если у него силовая часть сгорела, то может есть возможность подать дежурное питание на управление? Снять параметры, проанализировать и подобрать другой.
    • ID_Hacker
      Не упускаю. Потому что сообщение 21612 с причиной 1 точно описывает что разрешение работы сброшено. Последующий аварийный останов от привода и ошибки контроля контура это подтверждают.   Дефекты энкодера, кабеля, разъёма приведут к своим ошибкам которых не наблюдается. Как и пропадание готовности привода приведёт к своим ошибкам.   В любом случае необходимо определять формирование DBX2.1.
    • Нурлан
      Здравствуйте.   Если были бы у нас поблизости компетентные люди разбирающиеся в током вопросе . Которые смогли бы помочь и правильно объяснить как с этой проблемой бороться, но увы таковых нет.
      Об авторах: Мария Золотова — BIM-специалист строительной компании, по первому образованию — театральный режиссер, Софья Минина — BIM-менеджер, по второму образованию — психолог, Владимир Талапов — BIM-эксперт, всего одно образование — математик. См. также BIM и Театр: искусство возможного. Часть 1, BIM и Театр: искусство возможного. Часть 2, BIM и Театр: искусство возможного. Часть 3. Информационное моделирование зданий и сооружений, как творческий процесс, имеет много общего с не менее творческим процессом постановки театральных спектаклей. Поэтому изучение театрального опыта, его наработанных взаимосвязей участников и методик их взаимодействия может существенно помочь становлению и использованию BIM в строительной отрасли. В этой части речь пойдет о тех, кто вроде бы непосредственно не участвует в постановке спектакля или информационном моделировании, но от кого эти процессы существенно зависят. «Кто платит, тот и заказывает музыку» Итак, кто же [...] View the full article
      Понятия не имею
    • Александр 36
      А где можно скачать русифицированную версию
    • BASH_HD
      В Москве) но вообще по мнению японцев станок в Германии) но это не точно...   Аукцон и BAFA знали куда продали.
