G200 drilling cycle with iso programming
fisa
This drilling cycle in iso programming format with G200 Q parameter..some my machine not accept this format even i change machine programming format from Heidenhain to iso..... when i transfer this program from pc to machine there is a error come on G200 line need help regarding the issue
Regards
Asif
It can be wrong values of Q-parameters. Try to copy full values from malual and check the result. I have no more idea about this...
Seems to be, this machine doesn't support G200 cycles... Too strange for Heidenhain CNC... May be "HELP" buttion contains some info about driling cycles using by this CNC?
Or canned cycles wasn't bought for you machine, like an option (if it possible). Or this cycles was turned off by setup.
Yes its looking strange.....but as manual says that you can easily change program format form Heidenhain to iso ...and we also want to make in ISO format.. I have post processor for this machine which already tested another same machine...i also tested most of program sequence on this machine but ... drilling is a issue.....one more thing when i chose ".H" file type for editing or as new program.all cycle definition hard and soft key is enable ..and i can call G200 cycle only in (.H) format file type..but all cycle definition soft and hard keys is disabled when i work on(.i) file type.... I don't know if there is some parameter to enable G200 series cycle for iso programming..or something else.. still struggling..
Regards
      Вы не слышите, то что вам говорят. :=) И поэтому у вас проблемы. И Ансис и СВ и Настран и ИСПА и ... делают численную факторизацию матрицы при определении первых собственных частот незакрепленной конструкции.  Подождите немножко, я подготовил пример на две степени свободы для незакрепленной конструкции и будем его решать.
    • Orchestra2603
      Нулевая собственная частота означает нулевое собственное значение матрицы M^-1 * K, а значит нулевок СЗ у К (или бесконечно большое СЗ для M, но такого я не встречал никогда в реальных задачах). Т.е. матрица К - вырожденная. Это равнозначные утверждения про вырожденность матрицы жесткости и нулевую частоту. Почитайте работу по ссылке. Там рассматривается случай вырожденной матрицы M и алгоритм получения вектров. Случай с вырожденной К также приводится к этому случаю простыми манипуляциями.   Работа опубликована в 1972 году! Модальник Ансис, например, работает с вырожденной матрицей жесткостью вполне нормально. Он показывает 6 первых нулевых СЗ (для свободно "парящей" системы) и показывает формы соответствующие перемещениям, как жесткого целого. Все остальные СЗ (в подавляющем большинстве случаев, за исключением случаев некорректной постановки расчета) соотвтетсуют ожидаемым частотам. Не работал в Simulation, но я не буду удивлен, если там это работавет так же. Матлаб и Маткад тоже вполне умеет находить СЗ и СВ для случая с одной вырожденной матрицей. У вас не возникает ощущения, что вы ищете проблему, где ее нет?   Да, где интересуют очень высокие формы, там возникают вопросы, связанные с корректностью выбора функции формы, размеров элемента и т.п.  В моей практике с этим не сталкивался, но, наверное, если кто-то стоячие волны, например, исследует в ультразвуковом диапазоне - там, наверное, действиетолно возникают проблемы. Но это проблема самого МКЭ, а не каких-то алгоритмов или методов отыскания СЗ и СВ.   Так, по-вашем, что такое я  прислал? Это какая-то не такая факторизация?  Я же показал, есть такие методы факторизации. У меня нет оснований полагать, что все вокруг по всему миру идиоты, этого не знают, и только я молодец. У вас есть?
    • yunoleg
      https://drive.google.com/file/d/1o5b62TuvZQalbDJ9_aG81fc6I_Ojsg7d/view?usp=drive_link, https://drive.google.com/file/d/17bjDQq5UQ9HaZRu9QIGNjD5Iy9rEQ9XB/view?usp=drive_link, https://drive.google.com/file/d/1v5rY8NXGV0dsvizuyDwHdnQE53M0QlRi/view?usp=drive_link, https://drive.google.com/file/d/1xCjwwPhNUiLshQmCz5GVwO6nwrL1teew/view?usp=drive_link, https://drive.google.com/file/d/1biXChIeRXUPkyRq-vUAX7QTYDSAFajwG/view?usp=drive_link, https://drive.google.com/file/d/1hmQcWIwtIMVSaAKob7ET6JHxK9BiN1XO/view?usp=drive_link, https://drive.google.com/file/d/1wyzqJB9iwENMyWHD1EQgyUCw7iED8Blm/view?usp=drive_link, https://drive.google.com/file/d/1WCtff2C-_jPQniOz8QPRVTEZ9lNIaXIZ/view?usp=drive_link, https://drive.google.com/file/d/1PNeqoEomozDWPtBuB7_BMwNQLdkd7F13/view?usp=drive_link, https://drive.google.com/file/d/1zWW6U-gzl9ypvOWv1AQcW18Xb4AVRJXB/view?usp=drive_link, https://drive.google.com/file/d/1mtitt98SGu63Fr_db5HSVfE43-j6utgG/view?usp=drive_link, https://drive.google.com/file/d/1TeWtLQYDtWxOnOphgJ82brZWgapoftxT/view?usp=drive_link, https://drive.google.com/file/d/1zWk7w8BxpU_uwj-LP0H23eoR8nphLeNQ/view?usp=drive_link, https://drive.google.com/file/d/1YCZDInHYxQyLo_xQQgc0sUOcuUNrv1c9/view?usp=drive_link, https://drive.google.com/file/d/16bIqWYg8ryKRFa8LTfSpaIySo1_4VdGs/view?usp=drive_link, https://drive.google.com/file/d/1x2xqlaFCfXRIwoTxvSjxciKuJ04Ao7-0/view?usp=drive_link, https://drive.google.com/file/d/18YxxWmy2zgUzbMai9lD4XTgQeJUbGVrd/view?usp=drive_link, https://drive.google.com/file/d/16ZBXioHIXFtlYMhBQFopycwDPRdDYC_x/view?usp=drive_link, https://drive.google.com/file/d/112_xqezNot4ecDOMbmvtLN_nOnEQR_tR/view?usp=drive_link, https://drive.google.com/file/d/1Qx6eOwQqD9dcxrpeudbXJL8HQTZzQe2l/view?usp=drive_link, https://drive.google.com/file/d/1tUJ14IpIHF49EXBQ85tdrEzrWDQ0zZSK/view?usp=drive_link, https://drive.google.com/file/d/1fJarfkIcPR1B2_pMod10R8iO09HqqpEn/view?usp=drive_link, https://drive.google.com/file/d/1LsWkJXPuwBL3HlhbzehJpCOjZ0Gf6Eaq/view?usp=drive_link, https://drive.google.com/file/d/1Nm2j1JAn3tTXxznxdY9Y6bpD_ZNhjy0_/view?usp=drive_link c воздухом все в порядке. Все концевики проверены. тоже все в норме
    • Леонид124
    • karlf
      В общем, сделал образ с родного диска, накатил его на новый диск и докинул туда недостающий файл и всё поехало
    • vo.aand
      Всем привет, я провожу простой расчет напряжений в SolidWorks, решила попробовать так, чтобы получить достоверную картинку, а не только значения по формуле, так вот результирующие в программе получаются в 10^4 раз больше.  Размеры листовой детали L x B x H=6.5 x 1.4 x 0.016 м, размер выреза в детали L x B x H=2.5 x 0.7 x 0.016 м. Размеры модели в м, но при 500 000 Н напряжения получаются очень большими равными 89 670 МПа это максимум, в нейтральной зоне 67 680 МПа. Если считать через формулу то будет так σ=N/F= 500 000 Н/ (0.016 x 1.5) м^2 = 22 321 429 Па= 22,32 МПа Изображение по ссылке: https://disk.yandex.ru/i/jFPT3Yn7W8hlpA.
      я думал вы сами пересчитывали. а про параметры серво они вам ничего не сказали? может спросить отчего медленее едет....
    • ope@gusarm.ru
      производители станка сказали какие поставить в зависимости от шага винта и редуктора. Линейно то правильно считает, значит тут все так должно быть. Если б тут была ошибка то при передвижении на метр ехало больше или меньше.
      как считали flexible feed gear а именно 2084\2085 программой?
