RusF
Координатно-пробивочный пресс Alpha-1012 (LVD Strippit)
Pinned posts
Добрый день.
Просьба поделиться руководством по эксплуатации и руководством оператора (описание кнопок) на Координатно-пробивочный пресс Alpha-1012 (LVD Strippit).
Заранее благодарен.
Share this post
Обратитесь на LVD. Они с удовольствием вышлют нужную литературу за соответствующую денюшку.
Share this post
Разместил фото рабочей лицевой панели станка Alpha-1012 (LVD Strippit).
Может кто по фото подскажет назначение кнопок.
Буду признателен.
Share this post
ID: 4   Posted (edited)
700-800 евриков
5 часов назад, RusF сказал:
Буду признателен.
Buttons:
A-B-C-D-E-F
(a) Motor Start: This green-lighted button will start the hydraulic motor.
(b) Motor Stop: This red button will stop the hydraulic motor.
(c) Light guard reset: When staring up the machine, the operator has to check if the zone inside the light guards is clear. If so, the operator confirms this by pressing this blue button. If the light guards are not cleared, the light is illuminated.
(d) Single punch button: When pressing this button, the machine will perform a single punch operation. A single punch operation is allowed if the hydraulic motor is ON, if the light guards are cleared and if the toolholder is closed and locked.
The punch stroke for this operation is the last loaded punch stroke, if the machine is just started, the machine will use a very small punch stroke.
(e) Machine ON: this lamp is illuminated when the power supply of the machine is switched ON.
(f) Toolholder lock button: After loading a tool in the toolholder, the toolholder has te be closed. After it is closed, it also has to be locked to insure that the toolholder is positioned correctly under the ram. This button is used to lock/unlock the toolholder. The button is illuminated if the toolholder is unlocked.
Edited by xedex
Share this post
Спасибо за сообщение.
Прижали поставщиков - обещали дослать документацию.
Share this post
    • skysing
    • karachun
      @grek96 Вот еще ролик по переносу нагрузок между моделями. https://www.youtube.com/watch?v=imChtpormcw
    • kim96
      Предлагаем к поставке новые запчасти к станкам с гарантией 1 год: * Металлорежущие станки HAAS * Станки для лазерной резки Trumpf * Индустриальные 3D принтеры EOS * Siemens — блоки, модули, приводы, платы * Heidenhain — датчики, щупы, модули * Fanuc — панели, блоки, платы, сервоприводы, контроллеры, датчики * IFM — датчики, энкодеры, конроллеры, блоки, кабели, разъемы   Также есть возможность поставки восстановленных запчастей по привлекательным условиям: * Гарантия 1 год * Срочная поставка от 1 недели * Широкий ассортимент для различного оборудования * Цены до 1.5 раз выгоднее, чем новая деталь   Оборудование SIEMENS, доступное к поставке: Низковольтная коммутационная аппаратура: - Пуско-регулирующая аппаратура - Коммутационные устройства - Контакторы SIRIUS - Вспомогательные контакторы - Вспомогательные контакты - Принадлежности и аксессуары для контакторов - Твердотельные реле - Новые контакторы и автоматы Siemens Sirius Innovations - Модульная аппаратура - Устройства защитного отключения и дифавтоматы - УЗО, УОПД - Выключатели нагрузки Sentron - Модульные автоматические выключатели - Устройства плавного пуска - Плавный пуск SIRIUS - Защитные устройства - Автоматические выключатели SIRIUS - Реле перегрузки SIRIUS - Электронные реле перегрузки SIRIUS - Устройство управления и защиты электродвигателя SIMOCODE pro - Предохранители - Плавкие вставки - Фидерные сборки и комбинации контакторов - Пусковые комбинации Sirius - Фидерные сборки прямого пуска - Фидерные сборки реверсивного пуска - Пуск по схеме звезда-треугольник - SIRIUS NET: пусковые сборки с интерфейсом связи - Реле контроля SIRIUS - Реле времени - Реле контроля температуры - Реле термисторной защиты - Согласующие реле - Промежуточные (втычные) реле - Преобразователи аналоговых сигналов - Силовые реле - Реле безопасности 3TK28 - Аппараты распределения электроэнергии - Автоматические выключатели и разъединители - Компактные автоматы - Автоматические выключатели и разъединители нагрузки SENTRON - Выключатели нагрузки и разъединители SENTRON - Выключатели нагрузки с предохранителями - Узкопрофильные разъединители с предохранителями - Втычные узкопрофильные выключатели нагрузки с предохранителями - Выключатели нагрузки - Пластиковые распределительные системы - Система шинных адаптеров - Главные и аварийные выключатели Sentron - Шкафы, распределительные установки, шинопровод - Утройства подачи команд и сигналов, датчики - Электро-магнитные аппараты Электропривод: - Преобразователи частоты - Частотные преобразователи Siemens Micromaster - Частотные преобразователи Siemens Sinamics - Интеллектуальные панели оператора Siemens Sinamics Системы автоматизации: - Микросистемы LOGO! - Логические модули LOGO! - Микроконтроллеры SIMATIC S7 - Блоки питания SITOP - Программируемые контроллеры SIMATIC S7 - Системы повышенной надежности и безопасности (H/F-системы) - Системы визуализации панели оператора SIMATIC HMI - Кнопочные панели оператора Siemens SIMATIC PP - Панели оператора Siemens SIMATIC HMI Basic Panel 1 поколения - Панели оператора Siemens SIMATIC HMI Basic Panel 2 поколения - Панели оператора Siemens SIMATIC HMI Comfort Panel - Панели оператора Siemens SIMATIC HMI Mobile Panel - Тонкие клиенты для промышленности Siemens SIMATIC HMI Industrial Thin Client - Панели операторов Simatic HMI, снятые с поставок - Приборы оперативного управления и мониторинга - Распределенная периферия SIMATIC ET 200 - Станции распределенной периферии ET 200 - PC-based Automation - Системы компьютерного управления SIMATIC WinAC - Промышленные компьютеры, Программаторы и Мониторы - Программное обеспечение SIMATIC - Стандартные инструментальные средства - Инструментальные средства проектирования - Программное обеспечение Runtime - Промышленные сети SIMATIC NET - Промышленные Ethernet коммутаторы Siemens Scalance X - Промышленные Модемы и Маршрутизаторы Siemens Scalance M - Промышленный WiFi Siemens Scalance W - Промышленная Информационная Безопасность Siemens Scalance S - Сетевое оборудование Ruggedcom МЭК-61850 - PROFINET / Industrial Ethernet Витая пара, кабели и соединители - Волоконно-оптические кабели и соединители для PROFINET / Industrial Ethernet - Системы идентификации SIMATIC IDENT - Системы RFID идентификации Siemens HF/UHF для производства и логистики - Машинное зрение Siemens для Производства и Промышленности - Системы управления SIMATIC - Система управления процессами SIMATIC PCS7 - Интеграция и синхронизация всех деловых процессов с использованием SIMATIC IT https://steelcam.org/запчасти-для-станков
      zip@steelcam.org 8 (343) 382-52-03
    • piden
      скорость безразмерная? в любом случае, первая должна быть в 60 раз медленнее второй.. Так что снова что-то не то.
    • David123
      Уважаемый @andrey2147 ! Точно определив модель МСР, можно точно найти полное техническое описание панели и в том числе ТОЧНУЮ адресацию кнопок, переключателей (входов) и индикаторов (выходов), состояние интерфейсных кабелей. Я много раз просил проверить соответствие и работоспособность других кнопок МСР,  1) невозможно, если остальные адреса соответствуют таблице в документе. 2) Возможно, можно проверить имея проект электроавтоматики. Хочу уточнить, приведенные фото с разных станков, если с одного и того же, то чем отличается момент съемки.
    • Claus
      Да ошибся, скорость минутной 1/12 а секундной 1/180 я не правильно решил.
    • grek96
    • piden
      А координаты точек?   Если на одной из опор - то запросто так может оказаться. У вас же статически неопределимая система получается. Еще не известно, что SW понимает под "зафиксировано" в эскизе - это закреплены 3 степени свободы или все 6?
    • ev121
      Снижу ещё: 232т.р. Можно укомплектовать поворотной осью. Цена в комплекте с низкоскоростным шпинделем - обсуждаема. Видео работы:
    • Claus
      Да что то с секундной не так, там у меня переходы из градусов в минуты... В общем не верно посчитал
