После гибридной инициализации вылез варнинг, запустил на расчет - выдает ошибку. Что проверять и где может быть ошибка?
k-e, energy + и В ГУ: pressure-inlet, mass-flow-inlet, mass-flow-outlet, symmetry
Пробовал измельчить сетку, поменять метод симпл/куплед
iter scalar-0
1 1.000000e+00
2 2.932377e-04
3 7.967090e-05
4 3.773384e-05
5 1.638342e-05
6 8.934103e-06
7 5.847838e-06
8 6.430244e-06
9 7.217154e-06
10 1.305204e-05
11 1.631302e-05
12 3.244332e-05
13 3.988119e-05
14 8.472806e-05
15 9.941143e-05
16 2.251033e-04
17 2.570013e-04
18 6.087709e-04
19 6.956111e-04
20 1.659021e-03
21 1.906632e-03
22 4.575917e-03
23 5.074597e-03
24 1.244924e-02
25 1.365369e-02
26 3.403635e-02
27 3.824203e-02
28 9.342378e-02
29 9.136562e-02
30 2.240822e-01
31 2.869713e-01
32 5.659684e-01
33 3.068105e-01
34 7.069897e-01
35 3.706655e-01
36 8.110773e-01
37 3.624737e-01
38 5.445173e-01
39 7.102276e-01
40 5.722097e-01
41 5.995557e-01
42 5.982909e-01
43 6.358657e-01
44 6.045992e-01
45 6.424110e-01
46 6.173069e-01
47 6.619951e-01
48 6.259815e-01
49 6.820730e-01
50 6.353868e-01
hybrid initialization is done.
Warning: convergence tolerance of 1.000000e-06 not reached
during Hybrid Initialization.
Writing Settings file "C:\Users\User\AppData\Local\Temp\WB_JARVIS_User_3680_2\unsaved_project_files\dp0\FFF\Fluent\FFF.set"...
writing rp variables ... Done.
writing domain variables ... Done.
writing fff_solid (type fluid) (mixture) ... Done.
writing outlet (type mass-flow-outlet) (mixture) ... Done.
writing inlet2 (type mass-flow-inlet) (mixture) ... Done.
writing inlet1 (type pressure-inlet) (mixture) ... Done.
writing interior-fff_solid (type interior) (mixture) ... Done.
writing symmetry (type symmetry) (mixture) ... Done.
writing wall (type wall) (mixture) ... Done.
writing zones map name-id ... Done.
Writing "| gzip -2cf > FFF-Setup-Output.cas.gz"...
Writing temporary file C:\Users\User\AppData\Local\Temp\flntgz-62562 ...
1157746 tetrahedral cells, zone 2, binary.
2269498 triangular interior faces, zone 1, binary.
276 triangular mass-flow-inlet faces, zone 5, binary.
3463 triangular symmetry faces, zone 6, binary.
68 triangular mass-flow-inlet faces, zone 7, binary.
4078 triangular pressure-inlet faces, zone 8, binary.
84103 triangular wall faces, zone 9, binary.
215809 nodes, binary.
215809 node flags, binary.
Done.
iter continuity x-velocity y-velocity z-velocity energy k epsilon time/iter
reversed flow in 2034 faces on pressure-inlet 8.
# Divergence detected in AMG for epsilon: protective actions enabled!
# Divergence detected in AMG for epsilon, temporarily solve with BCGSTAB!
Error: Divergence detected in AMG solver: epsilon
Error Object: #f
8 часов назад, piden сказал:
На какие-нибудь мысли наводит?
Пробовал менять граничку - вышла такая ошибка
# Divergence detected in AMG for temperature: protective actions enabled!
# Divergence detected in AMG for temperature, temporarily solve with BCGSTAB!
Error: Divergence detected in AMG solver: temperature
Error Object: #f
@greshnov , как думаешь, что следует сделать, чтобы другим на форуме было легче ответить на твой вопрос?
21 час назад, piden сказал:
нуууууууу, я бы не стал жестко утверждать, что это и есть корень зла :)
Давайте погадаем. Как вы предпочитаете: на гуще, на зеркале, на яйце?..
22 часа назад, greshnov сказал:
дорогой автор, я имел больше слез, чем счастья с гибридной инициализацией. прежде всего, мне неясно, что "текучий" делает за кулисами видимого.
советую:
- запустить гибрид
- переключить кнопку на стандарт
- подкорректировать стоящие в полях значения до разумных, согласно заданию, значений
- еще раз инициализировать через стандарт и попробовать решать
в случае неудачи после поиграем с настройками "продвинутых" настроек :)
2 минуты назад, piden сказал:
если удача улыбнется, то на загруженном CAS :)
